How far do you ride your first gen?
Discussion in '1st & 2nd Generation 1983-1989' started by jake691980, Jan 27, 2010.
  1. jake691980
    jake691980 New Member
    Wilmngton , North Carolina
    I am sure that there will be someone to help me espcially since I am more than likely going to the NC mountians and there seems to be quiet a few mountia riders from that area on here. Once I get word from my boss which weeks are open for vaction this year i wil be making plans. I have never been able to ride there and it would be a great way to see them.
  2. Cyborg
    Cyborg New Member
    The fix I've heard the most about is a kit to increase oil flow to the cams...
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    I hear that if you keep the RPM's below 9.000rpms and always make sure you aren't low on oil and keep up on your oil changes that'll help.
  4. crustyrider
    crustyrider New Member
    North Country, New York
    Oh, yeah...I ride mine from point A to point B distance is not a factor......just how I got there..
    cheers
    Crusty
  5. captb
    captb New Member
    I've put 3K miles part city, part hiway on my 2nd gen since I restored it, it's run flawless. If everything is in good shape I wouldn't worry.
  6. jake691980
    I don't think that I have too much to worry about since I have had a bike I have kept the maintance up and I normally dont ride it too hard. So I am pretty confindent in my bike. My only real concern is that I don't have a clue as to what was done to it or how hard it has been ridden before i got. I do know that it has had several owners.
  7. calicojack
    calicojack New Member
    Italy
    ITALY
    most i've done is about 450 miles in one trip ,
    perfect trip, but high fuel consumption
  8. Cyborg
    Cyborg New Member
    My longest on a Gen1 was a little over 1400 miles in two days - Alamogordo NM to Montgomery Al, by way of El Paso Tx...
  9. tri4874
    tri4874 New Member
    Garvin, Ok
    i do all my work om my 84vf700f,and i would trust it on any ride against any other newer bike. like they have said "any bike can break down",when it does ,fix it !! don't just slap a patch on it !!!! fix it right,the difference between a great job and a half ass job is about 5 min and $5...i have not done the oil mod yet ,but will soon..but i do not rev real high and do not hold high speeds for looong periods of time...RIDE IT....!!!you go to blue ridge let me know ,may be interested..
  10. jake691980
    Can anyone tell me if you can tell if the cam oiling kit is installed on the bike? The first I have heard of it is in this forum. Also do you know where to get the kit from?
  11. tri4874
    tri4874 New Member
    Garvin, Ok
    look to see if you have hoses from the oil filter to the heads,there will be an adapter plate under the oil filter that the hoses connect to....i have some picks if you would like ...pm me with your email.....
  12. crustyrider
    I accftually had the same concerns with mine...(gen2) when I got it. I pulled the carbs and replaced them tires of course.and since maintanence was unknown I had the valves checked..they were a Little out (intakes) and a hair tight(exhaust) but not out of spec.TOE put them closer to spec and I am more confident in the bikes ability to keep me safe...now to tighten the axle nuts..........
  13. vfr89
    vfr89 New Member
    Italy
    last year I've done 550km in one day from Milan through swiss alps with my RC24II....so confortable, wonderful to ride...above 2400mt too...
    and I've done several 300kms+ sunday trips...only 1 time it let me down...see below...
    remember only 2 things you should check....the regulator rectifier (it is a bitch...mine charged battery badly and only over 4000rpm...it let me down 100km from home..., and the starting clutch...if when you press starter you hear some strange noises....change it immediately!
  14. craveman85
    craveman85 New Member
    st. johnsville ny
    i took an 81 cb750 from central ny to maryland for my first trip over 100 miles. go for it
  15. beedleblt
    beedleblt New Member
    Modesto, California
    2nd IBA saddlessore last fall
    Late on the response here, but, I did my second 1000 mi. in 24hrs. last year on my First Gen. Modesto, Ca. to Cedar City, Ut. the first day was 1038 miles. Rolled over 35k that first day of our 2500 mile trip. Day 2 into Zion N.P. and down to Vegas, day 3Boulder Dam and up past Death Valley and then home on day 4. No problems with my old girl but I do spend a lot of time with her in the garage. As the others have stated just make sure your bike is in good mech. shape (we really should do this no matter how long the rides we take are) and ride!! [​IMG][​IMG][​IMG]
  16. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    The cam issues were with the first generation bikes, '85 and earlier. If yours is a second gen '86 it shouldn't be a concern.
  17. jake691980
    That helps alot I wasn't quite sure where my bike fell into. I knew that it was right in the center but i did not know when the 2nd gen started thanks
  18. skymon
    skymon New Member
    Ojai CA
    I put a total of 85K on my '83 VF750F, including a 4000 mile loop around the western US. Even though I was often warned, I never had a problem with the cam chain tensioners or hard facing on the cams. I finally gave it to a friend who said he'd give it a good home. It probably has 90K+ on it now. Great bike.
  19. deepdish
    deepdish Banned
    if you have good tires fresh oil new plugs clean airfilter good brakes chain etc..if bike is running fine now a cruise down the highway is the best thing for them, in town stop and go getting them hot is the worst besides flat out racing it...nobody ever knows when their bike or car will break we just ride or drive them until they do..good luck and carry a cell phone in case no worries..
  20. 86INTERCEPTOR500@NCSU
    86INTERCEPTOR500@NCSU New Member
    Cliffside, NC
    Same here, I plan on making lots of blue ridge trips this summer, I am about 30min ride tops from the parkway.
