How to fix common regulator/Stator failures
Discussion in '5th Generation 1998-2001' started by Rubo, Jul 7, 2012.
  1. rjgti
    rjgti New Member
    regina sk
    measure stator output hot at 5000 rpm
  2. VFRnewbie
    VFRnewbie New Member
    Devon, UK
    Hey rjgti. What would you expect to see as a healthy output at 5000rpm?
    Thanks.
  3. rjgti
    rjgti New Member
    regina sk
    above 60v ac
  4. VFRnewbie
    Devon, UK
    So, just checked: 54 to 56v AC at 4000rpm, 60 to 61v AC at 5000rpm.
  5. rjgti
    rjgti New Member
    regina sk
    was the engine at operating temp as the stator can break down when warm. if so then output looks fine
  6. VFRnewbie
    Devon, UK
    Yup, it was up to temperature. Do you know what it is that can cause stators to fail only at higher temperatures?
  7. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Thermal expansion
    Sent from my A0001 using Tapatalk
  8. rjgti
    rjgti New Member
    regina sk
    actually the insulation breaks down under heat and cause internal winding shorts.
  9. VFRnewbie
    Devon, UK
    "Thermal expansion"
    "actually the insulation breaks down under heat and cause internal winding shorts."
    Well, I reckon as I could imagine thermal expansion causing the resin-stuff they coat the windings in to open and split as it expands due to the temperature increase, I can see how it might be that you are both right...
    Either way, can you see a way that it might be that my RR is the culprit even though it seems to check out under test? If the stator's output is ok then I struggle to see what else it could be :confusion:
  10. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    And then it unbreaks down after it cools off? Lol
  11. rjgti
    rjgti New Member
    regina sk
    yes it does regain its insulating properties
  12. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Lmfao
  13. rjgti
    rjgti New Member
    regina sk
  14. rjgti
    rjgti New Member
    regina sk
    When the electric field is high enough a dielectric may suddenly loose its property of non-conduction, permanently or temporarily, showing an electrical breakdown
  15. rjgti
    rjgti New Member
    regina sk
    want anymore evidence candyred
  16. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Yeah not at less than 100 volts lol
  17. rjgti
    rjgti New Member
    regina sk
    I see you didn't apply the calculus for the temp coeffieciant
  18. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Lol buddy your are trying way too hard to sound smart here. Trust me its not complicated. The bike heats up. Things expand. Clearances get tight. Parts rub. You get a crack in the insulation and an electrical short develops. Then you turn the bike off, it cools down. The parts contract and the short opens. That's it. Sorry, I am an ME/EE and I'm not impressed with your forum engineering, but I am having a good laugh at it, so keep it up if you want.
  19. rjgti
    rjgti New Member
    regina sk
    ok camdyred....nuff said. chat later
  20. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Try a diode test on your rr
