How-To: Gen-8 Tail Tidy Installation Guide
Discussion in '8th Generation 2014-Present' started by NZCam, Jul 20, 2015.
  1. NZCam
    NZCam New Member
    Melbourne, Victoria, Australia
    Tail-tidy Installation Guide
    Step 1:
    Using an Allen key, loosen & remove the bolt from each side as shown in the red circle in Picture 1.
    Picture 1: Attachment bolt location / Mudguard side piece (Aus/NZ models)
    Picture 2: Threaded plate & plastic surround
    Important: When turning the Allen key, check the threaded plate shown in Picture 2;- if you see it rotating more than a few degrees, do not force the Allen key or you will warp the plastic surround that the plate sits in, and make removal much more difficult. Some owners have reported that this bolt/threaded plate combination has been sealed with Loctite. If you suspect that to be the case, I recommend using a focused heat source (such as a butane jet-burner) for 3-4 seconds to loosen the Loctite, as shown in Picture 3. Do so sparingly to avoid melting the surrounding plastic.
    Picture 3: Apply focused heat to locking plate & bolt
    Picture 4: Vertical bolt location
    Once you have removed the bolt and threaded plate from both sides, pop them in a safe place for later and move on to Step 2.
    Step 1A (Aus/NZ models only):
    This step applies to VFRs with the extra mudguard side pieces (see yellow circle in Picture 1), which includes Australian and New Zealand models. As well as the side bolts, you will need to unscrew the vertical bolts (see yellow circle in Picture 4). You should now be able to remove the mudguard side pieces completely. Keep all your parts as your new tail-tidy will work with these parts if you wish to reinstall them.
    Step 2:
    Using a small 10mm socket tool, loosen and remove the hex-nut holding the factory reflector in place. The nut is found on the inside of the mudguard, facing the tyre. Once the nut is removed, you will be able to detach the reflector (See Picture 5).
    Picture 5: Remove factory reflector
    Picture 6: Remove washer
    Remove the washer found behind the reflector as well (see Picture 6). You should now be able to remove the factory fender/numberplate mount completely (see Picture 7). Detach your numberplate from the mounting, and keep the fastenings used with your numberplate.
    Picture 7: Remove fender & numberplate mount
    Step 3:
    Not all numberplates have mounting holes drilled in the same place. For this reason, your tail tidy has not been pre-drilled, in order to cater to the maximum range of different numberplates (see Picture 8). To complete this next step, you will need a drill, and a metal-use drill bit of a size that matches your numberplate bolts.
    Picture 8: Where you will need to drill numberplate holes once marked
    First, place your numberplate over your tail-tidy so that the top edge of your plate aligns with the widest part of the tail tidy. Only the reflector tab should be visible at this point. Use a pencil or paint-pen to mark where the existing holes in your numberplate correspond to the arms of the tail-tidy (see Picture 9).
    Picture 9: Marking your numberplate holes
    Picture 10: Prevent drill from wandering by making indentation
    Once you have marked where you want to drill holes for your numberplate fasteners, use a punch or a nail to leave an indentation (see Picture 10). This will prevent your drill bit from wandering as you start making your holes. Take due care and safety measures when drilling.
    Step 4:
    Once your tail-tidy has been prepared, check its’ fitment to your bike. Start by sliding the attachment tabs inside the factory mount at roughly a 45 degree angle (see Picture 11), then rotate the tail-tidy upward so that the reflector tab sits flush with the mount (see Picture 12).
    Picture 11: Start at a 45° angle
    Picture 12: Rotate until flush
    Now gently slide the tail tidy all the way up so that the reflector tab lines up with the numberplate light housing (see Picture 13). It should be a snug fit.
    Picture 13: Correctly located tail-tidy
    Replace the factory side bolts and threaded plates that you kept earlier. If you have the extra mudguard pieces from Step 1A, decide if you wish to re-install them, and remember to replace the vertical bolts (from Picture 4) for those pieces as well. Check that everything fits correctly before tightening.
    Step 5:
    Attach your numberplate to the tail-tidy using the same fasteners/bolts used with the factory fender.
    Help & Support:
    For feedback, help, and queries, contact nz.cam@hotmail.com
  2. pbg07
    pbg07 New Member
    Nice one nzcam. When will you be taking payment??
  3. NZCam
    NZCam New Member
    The production articles came back from the laser-cutters last Friday, and on the weekend I did all the welding, riveting, and tolerance testing. Next step is the powdercoating, and then they'll be ready to send.
    For riders in the US, the exchange rate between USD and Aussie Dollar really favours the US at the moment, so if you want to organise payment now via PayPal, that's fine. I'll mark you as paid and send your tail-tidy the moment they're ready (just depends on how much of a backlog my powdercoat contact has).
    Cheers - Cam
  4. pbg07
    pbg07 New Member
    Cam here is a couple before and after pics of my install. Thanks for getting them to me so quick. Fit and finish is fantastic! uploadfromtaptalk1439940194718.jpg uploadfromtaptalk1439940327943.jpg
  5. blackboyd
    blackboyd New Member
    Are these still available?
  6. NZCam
    NZCam New Member
    Sure are, should be ready to send any day now.
  7. blackboyd
    Price and PayPal info please
  8. Bubba Utah
    Bubba Utah Member
    Utah
    Ok, I have read the instructions. But like a dumbass I stripped both side on the plastic. I can not seem to get anything up there to help remove the bolt. Plyers, metal plates, screwdrivers. What the hell. I am about to break out the oscillating tool and cut the bitch off. Any advise or am I the only one that is inept on working with plastic bullshit?
  9. NZCam
    NZCam New Member
    Hi Bubba,
    Refer back to Picture 3 in the above instructions;- it sounds like you're having the same issue I initially had which turned out to be due to Loctite being used on the thread, and the soft plastic surround.
    What I did was to heat up the thread using a butane micro-jet, which melts the Loctite. Because there's no room to get a normal set of pliers in to stop the plate from turning once the plastic is smooshed, the way I solved that was slide 2 pieces of thin, hard metal above and below the plate edge. I fashioned the metal from a ruler which gave me something thin but relatively firm and non-brittle (I snapped a steel mini-file first try), and gave the plate something to push against and be prevented from turning with the bolt.
    Hope this helps.
  10. Lint
    Lint Member
    Simi Valley, Ca.
    Great looking product and man those directions!!!
  11. mello dude
    Netherlands
    On the 8th gen is that a storage area on the tail where the key is? Or....?
    :bruce2:
