HRC Swingarm Upgrade...
Discussion in 'Mechanics Garage' started by Busy Little Shop, Jun 5, 2009.
  1. Busy Little Shop
    Busy Little Shop New Member
    Sacramento Ca
    Honda's HRC Swingarm is a worthy upgrade for an RC45 and it's an easy
    bolt on Mod if you happen to have all the kit parts specified in the
    HRC manual... like HRC kit shock... HRC kit suspension linkage... HRC
    kit brake hanger and so on... but if you don't have the parts then
    it's a pain in the butt to interface one kit part with all the other
    stock parts... so it was up to my own skills to engineer and machine a
    list of parts to interface the HRC swingarm with the stock Honda
    parts... consequently Mr.RC45 has been up on blocks for a couple of
    months while the Lathe and Mill turned out the these parts... enjoy
    the picture show...
    Modified parts along side the stock Honda parts...
    7075 T6 aluminum swingarm axle and nut...
    7075 T6 aluminum lock nut and socket...
    7075 T6 aluminum axle installed...
    7075 T6 aluminum nut installed...
    Aluminum block interfaces stock linkage with HRC swingarm hard
    point... titanium hardware...
    It took 9 days of sanding and polishing to remove all the rough
    casting marks and bring out the luster of the aluminum...
    Home made brackets and aircraft Adell clamps now hold a custom ordered
    Spieglar steel braided line...
    525 DID chain and modified 43t steel Kawasaki sprocket... titanium axle nut and sprocket nuts & bolts...
    Machining a hanger for a billet 4 pot Brembo caliper...
    Finished hanger and torque arm to fit HRC swingarm and home made 7075
    T6 7M thread aluminum shoulder bolt...
    I covered the titanium exhaust with the new titanium warp...
    Ohlins shock and 4mm spacer that adjust ride height to correct Honda's
    error in trail...
  2. ZenMoto
    ZenMoto New Member
    Moorpark, CA
    Nicely done. I can't wait to see the whole bike put back together! :)
  3. deepdish
    deepdish Banned
    :thumbsup::thumbsup:Man that is great work awesome job can not say that enough.. I have a qwestion do you think you could make a different set of clipons out of aluminum as like the helibar?? I have someone I know and am trying to get into making a custom pair maybe up 2 inches and back 3 out of aluminum...or should we cut stock bar heli wield a spacer in between where the grips go and the tree mount to move the bar up and back ..??? please PM me that is great work....:thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::biggrin:
  4. RVFR
    One Word Sweet! that and you have been one busy boy there Larry. nicely done.
  5. crustyrider
    crustyrider New Member
    North Country, New York
    you missed a spot ...polish it right if your gonna do it................LOL
    Looks good bro!
  6. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Great now I have to go find some titanium wrap ...Ebay?
  7. Busy Little Shop
    Sacramento Ca
    My billet bar risers are $450 a set...
  8. Busy Little Shop
    Sacramento Ca
  9. julianivfr
    julianivfr New Member
    Alberta
    If you don't mind me asking, what is the benefit of the HRC swing arm if the dimensions are the same as stock?
  10. Busy Little Shop
    Sacramento Ca
    Weight and stiffness...
    Stock arm weights 11 lb 7.5 oz but the HRC arm weights 11 lb 2 oz
    The HRC aluminum swingarm is stiffer internally with more webs to
    resist the loads during the rigors of WSBK racing but it actually
    weights in less due to it's extensive use of aluminum and titanium
    bits...
    bits...
    HRC Swingarm with extra internal webs...
    Stock RC45 Swingarm without the extra internal webs...
  11. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Larry:
    I have two questions brother!
    Where did you find a HRC swingarm?
    Do you do track days on your RC45?
    BZ
  12. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    And, would that RC45 swingarm bolt up to an RC46?? :biggrin:
  13. Busy Little Shop
    Sacramento Ca
    BUBBA!!! do you still post in STN???
    It all started with an personal message in VFRD... the sender wanted
    to know if this strange swingarm he found on Ebay could be modified to
    fit his VFR... I took one look at it and gasped... here was a $2,500
    HRC swingarm with a $200 reserved because the seller thought it was a
    VFR swingarm... I sniped it at the wire for $220 delivered...
    The seller sent this info on the swingarm:
    "Larry, My neighbor works for a trade show company that does a lot of
    trade shows for Honda. This was on display at one of the trade shows,
    and one of the Honda guys told my nieghbor that he could take it home.
    He asked me to list this for him, so I will check with him to find out
    if he has any more parts. I myself do not have any items that go with
    this swingarm."
    Mr.RC45 and I have done track days at Laguna Seca and Thunder Hill...
  14. Bubba Zanetti
    Delaware
    Larry:
    I think you have the wrong Bubba Zanetti. I don't know what STN is? lol!
    Anyway, very cool score for you brother! I was curious where a race swing arm like this would pop up. Not suprised about ebay. I've seen some interesting things pop up on their too.
    You have my utmost respect for taking your RC45 to the track. It has always bothered me when people score a neat or unique bike and don't actually ride it. Especially something like a RC45. Man that thing has to be fun to take on the track.
    Post up some track pics if you have any sometime.
    And thanks for answering my quries brother.
    BZ
  15. Busy Little Shop
    Sacramento Ca
    You're welcome BZ... check out this profile in STN...
    Login - Sport-Touring.Net
  16. ZenMoto
    ZenMoto New Member
    Moorpark, CA
    ...someone converted their RC45 to belt drive??? :confused:
  17. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    ^ Its top secret!!!! Keep it on the down low till the kit come out.....
  18. great white
    great white New Member
    Psssstttt.....
    :ninja:
  19. ZenMoto
    ZenMoto New Member
    Moorpark, CA
    Ah, so you put an RC45 swinger on you 500. :)
  20. Busy Little Shop
    Sacramento Ca
