I bought another VF500F
Discussion in '1st & 2nd Generation 1983-1989' started by NuggyBuggyVFR, Oct 12, 2025.
    They certainly can get stuck as described. Usually from old fuel varnish.
    Typically a rap on the bowl with a plastic screwdriver handle pops them loose. I rarely have had to pry them, but sometimes they are quite stuck.
    NuggyBuggyVFR and sixdog like this.
  2. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    OK you said float BOWL. Some are and I lightly tap them on their side and that usually helps free them up.
  3. squirrelman
    if needed, the key # can be found by removing the top triple clamp or on the rear of seat latch/ helmet lock.
  4. NuggyBuggyVFR
    NuggyBuggyVFR New Member
    Took a few light raps today to see if I could free them. No go yet.
    Is there a solvent I could apply from the outside maybe to loosen things up? Would MMO work its way in? Quick Google search suggested it is generally safe for plastics and rubber.
    I'm figuring I will definitely be needing a few sets of gaskets, since at least 2 of my bowls are stuck. The one bowl I was able to open, the gaskets are pretty much flat and hard.
    Suggestions for kits that won't break the bank? I see kits going from $20 to 10 times that.
