I got 6,000 miles, so I was thinking of replacing the brake pads?
Discussion in 'Mechanics Garage' started by sunofwolf, Jun 29, 2014.
  1. duccmann
    exactly Grey.....
    Sent from my SGH-T679 using Tapatalk 2
    #41
  2. Badbilly
    I'm glad you used the term "novice". It fits better than "neophyte". Some harleydoods who are vocabulary challenged think that a neophyte is a dude who goes for shemales.
    #42
  3. thegreatnobody
    thegreatnobody New Member
    Little Rock
    Oh, so you mix gas, too? That must really help. Since you never fill up the tank you put in what, 1 gallon of each? You know that the first quart or so in the lines going to your bike will be whatever the last guy filled up his tank with, FYI.
    Not to derail this thread anymore, but please share with us your experience by mixing gas or by running premium instead of standard. Surely the higher the octane number means it makes more power, right? I mean, after all, it's called premium.
    Proof would also be accepted, but your unfounded reasoning is preferred.
    #43
  4. sunofwolf
    sunofwolf New Member
    No where man, MY methods work for me, but may not work for other folks. I got the bugs out of the used bike and it works excellent that's all I need to know- NoWhereman.:banana::deadhorse::bluesbros::drinkers:
    #44
  5. Glenngt750
    Glenngt750 New Member
    Edmonton, Alberta, Canada
    WAIT A SECOND! The Honda pads are probably the best pads made. They spray the back of the pad with a ceramic plasma coating. Slicker than shit! All the racers were even running them a few years back, because they stopped well, and were gentle on the rotors. Here's a funny one, my 800lb. ST1100 finally got a new set of front pads at 60,000k.m. I had bought them a year earlier, and finally put them in, with the stock pads still having 20% left. I do not ride my ST gently either.
    #45
  6. sunofwolf
    Long lasting pads don't mean great stopping pads as noticed by many running ebc HH:ninja: copper backed ebc pads are made for hard stopping, Honda pads-arte made to last not stop.
    #46
  7. duccmann
    where the hell did this guy come from anyways?FI
    #47
  8. 34468 Randy
    If Honda brake pads quickly apply enough force on the rotors to cause the ABS to kick in, then I suggest they have all the stopping power anyone here is going to need. Fuck man!
    #48
  9. Badbilly
    Son Of Wolf might have come from Roman stock. The story of Romulus and Remus tells of that. Another and possibly more accurate account might be found in a shemale version of one of those pads where ya got two mommies and two daddies. Then again, falling over all those times may have caused head injuries. Or, he just needs a good laxative.
    #49
  10. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    For Sunofwolf:
    STOP TECH | MC GARAGE
    What You Didn’t Know About Brake Pads and Fluids
    Written by: Jerry Smith
    As good as they are, stock brakes can often be better. And considering their life-saving responsibilities, there’s no shame in wanting the best. When your pads wear out and you replace both of them and the brake fluid—which you should do unless your bike’s service manual specifies replacing the fluid sooner—you have to look past the market-speak to get the real skinny if you’re going to get the improvements you want. Here’s how to tell what you’re getting and whether it’s really an improvement.
    Virtually all modern streetbikes come with sintered metal pads, which are hard to beat for everyday street riding. They grip hard when they’re cold—which they almost always are in emergency stops—and they efficiently channel water away from the surface of the brake rotor in wet weather. Their high-temperature performance is usually as good as you’ll need at anything less than Lorenzo-versus-Marquez speeds.
    Sintered metal pads start as a fine powder containing friction materials, a dash of lubricant, and ground-up magic braking beans. The recipe can be tweaked to provide more initial bite, more progressive feel, or better wet-weather performance in the final product. The powder is put into a mold, heated and compressed until it fuses into a solid block, then bonded to a steel backing plate.
    Brake pads are rated for their friction coefficient on a scale of A to H; A is the rough equivalent of dragging a stick in the dirt to slow down your apple-crate go-kart, and H is the best you can get. Sintered metal pads achieve HH status, meaning both their cold-stop and hot-stop ranking is the highest. As with tires, a brake pad’s compound is tailored to the way it’s meant to be used, and although two different brands of pad may have the same rating, they can act quite differently on the motorcycle. One HH-rated pad might have more initial bite or could have a more progressive force/friction curve than another. Ratings alone don’t tell the whole story.
    Organic and semi-metallic brake pads are made of different stuff than sintered metal pads and are typically softer and less grippy; most rate no higher than GG, a full step below sintered metal. They have their uses, though, such as on older bikes that didn’t come with sintered metal pads and whose brake rotors would wear faster with more aggressive pads. Some are made for dual-sport riding where gritty mud gets between the pad and rotor; the softer pad wears instead of the rotor. Organics don’t stop as well when cold, so they contain bits of metal such as copper or bronze that hold onto heat, keeping the pads warmer between stops. Poor cold stops are also common in some racing pads, which work much better hot than cold; their GH rating gives you that hint. Switching to an organic or semi-metallic pad can also make a sensitive rear brake a bit less so.
    Brake fluid comes in two types. The most common is polyglycol-based, and is designated DOT3, DOT4, and DOT5.1. DOT4 is an upgrade of DOT3 and can––and should––be used to replace the older fluid. DOT5.1 differs from DOT3 and DOT4 in that it’s less viscous. It’s specified for ABS brakes because it cycles back and forth in the system more easily. Note that the other type of brake fluid, DOT5, is not a polyglycol, but a silicone fluid, and does not mix with them.
    A characteristic of polyglycol fluid is that it’s hygroscopic, which means it absorbs moisture out of the air, sucking it through the fluid reservoir vents and past the caliper piston seals—just popping the cap on the bottle starts the contamination process. Each class of fluid has a “dry” and “wet” boiling point. Dry fluid in a sealed container has one boiling point; fluid with 3.7 percent moisture is considered wet and has a lower boiling point. It takes the fluid in the average streetbike about a year to degrade to where the wet boiling point is the one that matters. This happens sooner if you ride a lot in the rain or if you race the bike and subject the fluid to short periods of very high temperatures punctuated by long periods of sitting in the garage.
    There are drawbacks to racing brake fluids just as there are with racing brake pads. The higher the dry boiling point, the more hygroscopic a fluid tends to be, so you need to change it more often. The reality is that on the street you’re extremely unlikely to ride hard enough to heat either the stock brake pads or brake fluid past their upper limits. Just keep an eye on pad wear—low fluid level in the reservoir’s sight glass is the tip-off—and change the fluid every two years to keep your brakes working at peak performance.
    Quick Facts
    Sintered metal pads work better in wet weather because on a microscopic level their surface is granular. Water trapped between a flat pad and rotor initially has nowhere to go but through the slots or holes in the rotor itself. You apply the brake, not much happens, then the water is squeezed out and everything happens at once. Sintered pads allow the water to flow between the grains, giving another path of escape.
    #50
  11. sunofwolf
    stock pads aren't copper backed
    #51
  12. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    elf reincarnated once again....been here under many names over the years :troll:
    #52
  13. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    ^^^^, LOL, that's funny. i was just thinking as I read through this thread:
    Elf
    GoForaRide
    Deepdish
    Wasn't there others?
    This is awesome - where else can you get this kind of entertainment on a daily basis for free?
    #53
  14. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    emptyskull was one
    #54
  15. Arnzinator
    If you can't see the pads then how do you know?
    #55
  16. thegreatnobody
    Little Rock
    #56
  17. sunofwolf
    you painted the pads copper
    #57
  18. Arnzinator
    Yep, had the copper paint on the shelf next to the winter oil.
    #58
  19. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Slick 50 or 51 I'll bet. That is high heat copper paint,eh?
    #59
  20. Arnzinator
    Absolutely, rated to 10,000 degrees. Got it from ACME Industrial coating. Salesrep was covered in fur & worked out of a strange lab. He seemed pretty smart. His business card says "Super-Genious" ;)
    #60
