i think im the only 5th gen rider in the philipines. bike wont start :(
Discussion in 'Mechanics Garage' started by immasmoke, Oct 15, 2012.
  1. immasmoke
    immasmoke New Member
    Baguio City
    thank you sirs. i'll get this sorted out with your help no doubt. i already removed r/r from the bike after reading your replies.
    View attachment 20080 View attachment 20081
    the 3 yellow wires from stator leading to the r/r are thinner than the ones on the r/r. is that normal?
    will check r/r diodes and grounding and give you an update later. need to sleep
  2. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Might just be me, but I can't see what the attachment is.
    Anyway, yes, it is "normal" that the 3 yellow wires from the stator are thinner than those on the R/R. This is actually part of the initial problem; Honda used cheap shit wiring resulting in continuous problems.
    My suggestion (and many others would agree) would be to solder the 3 yellow wires from the stator to the R/R wires. It does not matter what order they are soldered together in. Soldering the wires will absolutely make a difference in efficiency and how long the replacement R/R lasts.
  3. immasmoke
    Baguio City
    Guys sad to say i will have to put the sorting of the bike on hold, have to leave for malaysia next week and will stay there for about 2weeks. would still love to get more advices and suggestions from you guys though. hope you guys could still help me once i get back. TIA. will still be checking the forums regularly to get more ideas
  4. tinkerinWstuff
    troubleshooting is a step by step process, not an exercise in brainstorming. Ideas confuse the issues. The next step is checking the ground. The results of that step will lead to the next one in the process. It's not even worth worrying about what the next step is until we know the results of this one.
  5. immasmoke
    Baguio City
    oh ok sir tink thanks. also got a question about that vfrness? do i need it? what does it do precisely and can i make my own since its kinda pricey.. :biggrin:
  6. tinkerinWstuff
    You can make your own, it's highly recommended, it's heavier gauge wire and connections for the charging system, it's highly unlikely that it has anything to do with your no-start problem at this point.
    I built my own and soldered everything in directly.
  7. immasmoke
    Baguio City
    sorry for being a bit eager. i just want my bike to run the way i want it, and also my girlfriend will come visit me this november so im trying to find out what parts i need ( or might need ) so i could ask her to get it for me. she's from winston-salem,NC. i called up this MC parts store in manila and asked how much for 5th gen parts. ecm alone was 45,000 pesos ($1,200 and it has to be shipped from japan) :crazy:
  8. immasmoke
    Baguio City
    thats great news. ok thanks. we'll get to that once i get the bike running
  9. tinkerinWstuff
    It's not likely that the ECU is faulty. Through methodical troubleshooting you can zero in on the root cause without buying parts just for the sake of buying parts. Working eBay units are substantially cheaper.
    And if you believe that guy in te '98 upgrade question thread, then a European ECU is worth 10hp! /sarcasm
  10. immasmoke
    Baguio City
    NAh i havent seen that thread yet hehe. ok, so i'll just update you guys once i get back home in 3 weeks time. thanks again for all the input
