Ignition Change on 6th gen
Discussion in '6th Generation 2002-2013' started by Chicky, Aug 21, 2011.
  1. Chicky
    Chicky New Member
    Kingman, AZ, United States
    Anybody change the ignition on a 6th gen? Seems easy enough, just two bolts that I have to get to from the underneath. Problem is, I can't see underneath, even with a mirror, to see what tool I need. I thought it was hex, but with a mirror the inside looks round. Anybody do this or have suggestions on where to get info? I know I've seen the service manual in electronic format somewhere on here, but I haven't been able to find it when searching today. Any help would be GREATLY appreciated!!! Thanks!!
  2. 34468 Randy
  3. 34468 Randy
    "Sned" is UFRR's equivelent to "send" with our particular accent.
  4. Chicky
    Chicky New Member
    Thnak oyu Radny!!
    I am attempting to learn your language... perhaps we can converse in your native tongue and you can correct me and help me learn faster? :rolleyes:
  5. stoshmonster
    stoshmonster New Member
    Karen,do you mean you're trying to remove these bolts to swap out the ignition switch?
    If so those bolts require a special tool called a T40 Torx bit. Just a heads-up,those bolts have Loctite on the threads and are screwed in there freakin' tight.
  6. Chicky
    Chicky New Member
    Yes, the ignition switch... sorry for lack of clarity, but thanks for your clarity... wait, wahuuuuuuttt? :) Thanks so much for the pics StoshMon!! I got those tools! And thanks for the warning... I may have to enlist the help of someone stronger than I... but I'll give her a whirl first.
