Incorrect reading on LCD temp display on outside air temps?
Discussion in '5th Generation 1998-2001' started by Shmerick, Apr 26, 2013.
  1. Shmerick
    Shmerick New Member
    Kennesaw, Georgia
    Yes I checked the forum and could not find the info I hope is available.
    I did recently flush my coolant system and could possibly make the connection that somehow I affected internal engine temperature reading but I doubt it.
    I've noticed in the last week or so that my once reliable temperature display ( Gen 5 ) is now off by at least 10 degrees F and sometimes as much as 20 F. This occurs with the outside air reading, but could also be happening with internal engine / coolant temps display as well but I have not verified that ( although now perhaps i will verify with my IR temp gun).
    Forgive the noob, are there two separate sensors or one? Where are they / is it located? Is there some cleaning or adjustment that can be done?
    Is there a thread or 12 on this subject and I'm not using the correct key words?
  2. Shmerick
    Shmerick New Member
    Kennesaw, Georgia
    I have now found several threads.
    Air temp sensor is on right inner fairing above radiator. I will check and see if I impacted in in some fashion. Moderator feel free to delete.
  3. Badbilly
    Your IR gun may be off, needing calibration.
    Are you factoring in wind chill?
  4. Shmerick
    Shmerick New Member
    Kennesaw, Georgia
    I haven't used the IR gun yet, I was saying that I would do so to verify engine temp sensor was dispolaying accurate data.
    How would the sensor be accounting for windchill?
  5. diVeFR
    diVeFR New Member
    Spring, TX
    You have to forgive BB... he has a dry sence of humor..you may just need to replace the outside temp sensor.... here in Texas, Great State of, there are only two temps we worry about here.... Damn nice day for a ride and Fuckin hot as hell but still going to ride.
  6. Badbilly
    Ahhh Texas! What is it they say there? Now I remember.. "Fuck em if they cain't take a joke"
    I thought the dude may have whipped out his IR pistol and verified that perceived increase in temperature.. Guess not.. Wind chill is wind chill. The calculation is a little hairy but a mired nomograph tells the tale.
    Back to Texas.. Managed to get through the UofH, Rice and 95 N 95 more than a few times.
  7. Skifreak
    Skifreak New Member
    Washington State
    I also have noticed my outside air temp gauge is also consistently 10 degrees to high. I thought it was just like a hand grenade: close is good enough.
    Is there a fix for this or are they all that way?
  8. mello dude
    Romania
    My 5th gen air temp sensor is screw ball in that it only close while your moving down the road. At low speeds and at a stop,
    radiator heat start hitting it and raising the temps.
  9. Shmerick
    Shmerick New Member
    Kennesaw, Georgia
    Part of the problem I discovered was nothing more than dirt in the sensor. Some of it is probably just road dirt, some of the issue was definitely my fault. I forgot that a week or so ago I attempted to set front fork sag and was dusting the forks with chalk from my chalk line to give me a visual mark on fork dive. Aside from that being a stupid was to tune the suspension it also seems to have caused a problem with the air temp sensor. Solution= aerosol contact cleaner liberally sprayed into the sensor and then alternatively blown out with compressed air, repeat. The sensor is now reading only about 3 degrees high, which I can live with.
    And as it turns out my suspension was pretty well dialed into where I needed it to be in the first place. Go figure.
  10. Badbilly
    Problem solved. If the sensor somehow gets clogged again, could you use your IR gun?
  11. Shmerick
    Shmerick New Member
    Kennesaw, Georgia
    Yeah I will if it acts up again.
  12. Badbilly
    Be careful if there are any LEO's lurking. They might think you are texting.
  13. PWH
    PWH New Member
    This problem is usually very simply fixed. Your inner fairing is not sitting flush against the side fairing, creating a gap and engine heat hitting the sensor. Check the mating surfaces of the inner fairing usually the front side. This always fixes this problem for me. No replacement necessary
  14. John451
    John451 Member
    Mine was reading high after a static fall due to the plastic clips popping on the inner plastic dropping the sensor closer to the right side radiator, repositioning and new clips sorted it.
  15. diVeFR
    diVeFR New Member
    Spring, TX
    Who needs the outside temp reading anyways. This is the "bike" way on how to determine weather...the redneck way.
    Bike in mist = Foggy
    Bikes wet = Raining outside
    Bike on fire = to hot to ride
    Bike has ice on it = cold
    cant see bike = its late/night time
    Bike in tornado = its windy
    Bike on ground = its Randys (or earthquake) :funky:
  16. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Randy is going to be busting out that button...
