Interchangeable waterpumps?
Discussion in 'Mechanics Garage' started by callahanj617, May 27, 2011.
Tags:
  1. callahanj617
    callahanj617 New Member
    watertown CT
    my 84 VF500 needs a new water pump. i have an 86 vf500 donor bike . are the water pumps interchangeable? i know that many parts are but some are not. any advise will be awesome
    One good way to check something like this is to see if part #s match, but sometimes #s get updated, so not always reliable.
    In the case of your VF, i would very strongly suspect the pumps are the same, and change- over would be easy once the cooling system is drained.
    "Invisible Cities" has paid his dues and has the definitive answer to most VF500 questions..........
  3. callahanj617
    watertown CT
    thanks squirrel , i checked bike bandit and there stock numbers are the same for both years. visually they look the same but i wanted to be sure before i ripped everything apart.
