Is the stator wiring really suspect?
Discussion in '6th Generation 2002-2013' started by dennisgb, Nov 4, 2016.
  1. Terry Smith
    The letter code (SH or FH) tells you the type of design. SH are the older Shunt-type RR, which dissipate a lot more heat and hence have a shorter life. The FH is a MOSFET design which produces a lot less heat and so should have the longest life.
  2. MasterHo
    MasterHo New Member
    KC Metro
    Thanks, guys. I'll be ordering the FH and wiring kit.
  3. NormK
    NormK New Member
    And as has been stated, don't use the connector because eventually it will fail. If somebody still made a bakelite connector this problem would not keep happening, until then solder and heatshrink seem the best option
  4. squirrelman
    Posting this classic from my '86 700.......
    The wiring is fine but the connections tend to fry.
  5. thx1138
    thx1138 New Member
    Perth
    My generation 4 has been running fine with a Pentium 4 fan on top for a couple of years. No sign of the fan burning out.
    Also check the three phase wires regularly since cleaning them up and tightening the blade connectors. All look good so far.
  6. thx1138
    thx1138 New Member
    Perth
