It's Alive! My CBR600RR Tail Project Lives!
Discussion in '1st & 2nd Generation 1983-1989' started by Oakley_burn, Jun 16, 2008.
  1. mpadgett88
    mpadgett88 New Member
    medford, oregon
    Nvm i see it now. I what's the specs on the welded piece?
    How you do yours fatso
  2. fatso1277
    fatso1277 New Member
    South Suburb IL.
    pretty much the same as oakley burns. except i used the vfr subframe versus the flat bar he used. i did use the thicker flat bar and an 18mm wrench to make the eyelets.
    1) cut the upper vfr subframe right before rear tank mount. (in retrospect shoulda been AFTER rear tank mount.) put the made eyelets into the tube of the upper vfr rail and bolted it so i could have it welded later. and then mate it to upper cbr subframe and vfr rails. put the tank on and leveled the top of tank with the top of cbr rear fairing with pinion seat on. (i raised mines a little higher cause that how i liked it but it did effect how the cbr600rr side panels fit. hinsight is 20/20).
    2) then cut the lower angled rails of the vfr subframe and LOOSELY bolted them to frame right behind rearset how they go...and angled them to mate up with lower cbr subframe. made sure to insert the eyelets. so i could get the right angle and chopped them down until i got the right length and bolted everything up.
    3) then used 3/4 inch sqaure tubing to make crossmember...and tack welded them.
    then took to pro welder and had them welded up
    spray painted and then had to figure out a new home for the various parts. i dont have any pics of the process but i can definitely walk you thru the steps best as possible...also might work a lot easier if u have a welder
  3. mpadgett88
    medford, oregon
    awesome. I cant wait to get this done. need to locate the plastics first. and a welder lol
  4. Oakley_burn
    Oakley_burn New Member
    Glad this thread has provided some joy for others. I did this to start with coz i didn't like the rear end of the '88 - too boxy for my liking.
    Underseat exhaust pics will follow soon. I have been meaning to post them but my life recently (isn't anybodies?) has been mental.
    Will update soon
  5. Oakley_burn
    Just a quick snapshot of the bike on New Years Day. Please excuse the puncture - country roads are NOT cool
  6. tinkerinWstuff
    Like it a lot!
  7. douglasthecook
    douglasthecook New Member
    Tucson, AZ
    Looks good!!!
  8. fatso1277
    South Suburb IL.
    oakley_burns...did you decide against the cbr600f2 swap...and where did you put yout FUEL PUMP!!! i got everything else pretty much in a place...but the damn fuel pump...lol
  9. Oakley_burn
    I have decided against the CBR f2 swap, mostly as i had just refurbed the VFR ones and i had no issues with them. I did drop the bike a 1/2" on the front which has made my riding position and handling in the corners better.
    The fuel pump. The VFR pump i had died. I know that the pump and the R/R are the two most 'unreliable' items on the bike so i got a 12V inline fuel pump from a RaceTech Landrover (£12 on Ebay), it's water proof and has no moving parts inside it to corrode or be shaken about. It seems to operate in a 'pulsing' action - no idea what that means, but it's been in the bike for 18mths now and it has always started first time and i have no fuelling issues during the whole of the rev range.
    See pics for more:
  10. fatso1277
    South Suburb IL.
    NICE!!! thanks for the ideas...yours
    turned out great...
  11. artee
    artee New Member
    Rochdale,
  12. gj6n68
    gj6n68 New Member
    Hello Everyone,
    Oakley, your bike looks as stunning as oakley sun-glases :D
    I've always thought VFRs with slimmer tail would make it look so so better. And the results are evident.
    I am so tempted to do similar conversion on my 1998Fi VFR800. The tails on this viffers are very bulky, but a slim version like cbr would make it look real head turner. Any idea if anyone has done something like this already ?? I've search and not found anything so far.
    And now I'll keep an eye for your bike on roads of London, might have missed out it seems.
    All the best and well done.
  13. fatso1277
    South Suburb IL.
    You can look at customfighters.com they have lots of tail section swaps
  14. gj6n68
    gj6n68 New Member
    On there now :wink:
    Thanks for leading me there..
  15. beetgabby4
    beetgabby4 New Member
    Belize
    did my own tail conversation with the 05-06 fireblade tail[​IMG]
    Sent from my 2201116SG using Tapatalk
  16. EliSpb
    EliSpb New Member
    Russian Federation
    Аbout fuel pump. You can use pump from Yamaha XTZ-750 or TDM-850 and you will foget about it forever. Air itake from
    carburetor manifolds.
