Jim's 1988 VTR250 Interceptor
Discussion in '1st & 2nd Generation 1983-1989' started by Jim McCulloch, Jun 30, 2024.
  1. sixdog
    Hmmm the cct sounds like the culprit
    My 94 CBR1000f has a noisy cct until it warms up…sounds like an engine knock
    not very likely with only 9k miles but well see o_O
    unless the engine did run low on oil, the cams should look perfect. in one worst-case scenario, a tappet adjusting screw might have fallen out---due to mechanical irresponsibility by some crackhead on parole.
  3. bmart
    bmart Member
    Charlotte, NC
    I've owned three of them. Absolutely lovely bikes!
    Bazza and Jim McCulloch like this.
  4. RogueRC24
    :Pop2:
    Bazza likes this.
  5. Jim McCulloch
    Jim McCulloch Member
    Stripping it down to get to the cams....Dirty as heck, probably never been cleaned under the seat.
    RogueRC24 and Bazza like this.
  6. sixdog
    So far so good
  7. Jim McCulloch
    Bunch of boring pictures right now, but good for historical purposes anyway. This thing is totally original.
    The more I look at that engine , it is such a trip that it is 1/2 of a VF500.
    I have a gasket kit left over from the VF500 build and it looks like at least the 250 bottom end is a direct match.
    Other than the cable clutch mechanism (vs hydraulic on the 500) and the oil sight glass the RT side cover is the same. I am going to get a VF500 Rt cover from my stash and see if the are a direct match up.
    RogueRC24 likes this.
  8. flattrack
    flattrack New Member
    as you said, it's half a vf500....many of the valvetrain part numbers are the same, which means you might have the same cam/follower failure causing your knock, knock, knock!
  9. Jim McCulloch
    I hope that is all the knock is. Work keeps getting in the way of working on the bike, dying to know what the problem actually is.
  10. bmart
    bmart Member
    Charlotte, NC
    A Supertrapp can is pretty excellent on that bike.
    Jim McCulloch likes this.
  11. squirrelman
    any photos ?
  12. bmart
    bmart Member
    Charlotte, NC
    None from the track, unfortunately, but:
    Jim McCulloch, squirrelman and Thumbs like this.
  13. RogueRC24
    looks nice with the rotor. :)
    I took my CA drivers license test on one of these. Aced it. I will forever be grateful for the VTR250!
    My buddy just adapted an 87 CBR600F rear wheel and disc brake to his 1990. Looks killer.
    Jim McCulloch and RogueRC24 like this.
  15. Jim McCulloch
    Got an Update....pulled the cam covers off and .......it is spotless. Looks like they did the 600 mile check on it and it was never touched again,
    One cam lobe is a little "rough" but nothing too exciting. A couple of the valves are really tight, like hard to get a .002" Under there.
    See what you think.... Cam chain is tight also, no slop in it. Plugs look like shit.
    This is the worst lobe. The rest are spotless. It has a spot that is kind of "not smooth"
  16. bmart
    bmart Member
    Charlotte, NC
    Did you mention how many miles? Be sure that you have the timing right when measuring for the valve clearance. That may be your knock...
  17. squirrelman
    a good modification idea if done for looks only ? i dunno. doesnt improve that 250 at all, bike does not need a heavier, wider rear tire for no practical reason.
    JIM, maybe time for a compression test ?
  18. Jim McCulloch
    9460 miles
  19. Jim McCulloch
  20. squirrelman
    HF near you :cool:
