Jim's 1988 VTR250 Interceptor
Discussion in '1st & 2nd Generation 1983-1989' started by Jim McCulloch, Jun 30, 2024.
  1. Jim McCulloch
    Jim McCulloch Member
    My research tells me the 1982 ONLY VT250F rods are the same as the VF500F. Rod bearings are the same as are the crankshaft bearings. BUT.....information is sketchy on the 82 model, and everything after that YM has a different P/N for the conrod for the 250. Also note the front and rear conrods are different. I have yet to firgure out why. Everything seems the same????? V-4 Hondas appear to all have different conrods front and back FYI.
    It also appears that the conrod and crank bearings are readily available all over the world due to this engine being in production for so long!
    I am not scared of the parts situation at all right now. CMSNL and Webike seem to have everything I need. But at a fairly stiff price!
    flattrack and RogueRC24 like this.
  2. RogueRC24
    CMSNL and Web!ke to the rescue! What scares me is when they don't have something. eeeek!
  3. Jim McCulloch
    For sure....I am not ready to dip into the Chinese knock offs just yet, Though I am sure they will be fine.
  4. chuntera
    chuntera New Member
    Connecticut, USA
    I bought a large socket and used a dremel to make the notches. Not a precision tool but it did the job.
    Jim McCulloch likes this.
  5. sixdog
    Excellent!!!
  6. Jim McCulloch
    Very good job on that! I wish I had tried that.
  7. Jim McCulloch
    Still waiting on parts....got a lot of cleaning to do to get all the metal shavings out from the spun bearing.
    Honing the cylinders with my $25 Harbor Freight hone.....
  8. squirrelman
    what r u doing to find a good crank and rod ?
  9. Jim McCulloch
    Got a crank from a junkyard in PA, the rod is coming from Germany.
    Gonna be a while!
  10. Jim McCulloch
    Work got in the way of a good time AGAIN but work is progressing. Going to pasti-gauge the main and conrod bearings tomorrow.
    Lot of cleaning to get any traces of metal out of the crankcases.
  11. rc24dk
    rc24dk New Member
    Denmark
    Is the crank one piece?
  12. Jim McCulloch
    Correct, one piece.
    rc24dk likes this.
  13. Jim McCulloch
    Plastigauge....wierd stuff. I had this laying around for 10+ years and it appears to be still good.
    Not sure if most people have ever seen this stuff. Pretty amazing and simple. Just put a line of it on the bearing journal and assemble the lower crankcase. Torque to spec and then remove the crankcase and check how much the plastic was smashed by the bearing.
    It is really thin, almost a thread.
    squirrelman, Bazza and rc24dk like this.
  14. Jim McCulloch
    Bazza likes this.
  15. squirrelman
    ive used p.g. on several sportscar engines ive built, good stuff ez 2 use on mains, not ez on rods.
  16. Jim McCulloch
    I hear that. What a PIA it was to do the conrods today. I am super glad the clearance came out good. Not sure what I would have done if the clearance did not come out right. The bearing inserts are expensive a hell and luckily I got a good set of inserts on the used conrods I got bought.
  17. Jim McCulloch
    Short block is finally finished....moving on to the heads now!
    Lucky I have a lot of experience rebuilding the VF500 engine so this one was a snap to assemble. IMG_0278.JPG
    RogueRC24, chuntera, Bazza and 4 others like this.
  18. sixdog
    Dare I say
    It’s beautiful!
  19. squirrelman
    hell, my dinner plates arent that clean. nice work. :cool:
    Bazza likes this.
  20. Jim McCulloch
    Thank you! Will be even more beautiful when it actually runs!
