Jim's $400.00 1986 VF500F
Discussion in '1st & 2nd Generation 1983-1989' started by Jim McCulloch, Jun 25, 2019.
  1. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    Make sure the gaskets don't restrict the coolant flow. Those channels need to flow as much as possible.
  2. Jim McCulloch
    Jim McCulloch Member
    Thank you for that advice, it never even occurred to me to do that. I will get my Dremel tool out and address that.
  3. Jim McCulloch
    Good call on that one @jeremyr62, the water holes on the head gasket were a long ways off....Spent over an hour with a dremel getting them close.
  4. Jim McCulloch
    Engine is DONE. Ready to install.
    Now the hard part. As may times as I have done this it still sucks to install the engine. I have no idea how they did it at the factory without scratching the paint somewhere. Probably had a $50,000 fixture or something.
  5. Colddevil
    Colddevil Member
    Wisconsin
    What do you mean? Take that inflatable chair off the hood of that car, deflate it, lay it under the engine in the frame, and start pumping!
    Looking good! Anxious to hear about how this goes because I know it's in my future.
    Jim McCulloch likes this.
  6. Diving Pete
    Trolley jack & couple of pieces of wood do the job very easily. Now to protect the frame then cut up old plastic milk containers & masking tape them to it. Works surprisingly well.
  7. straycat
    I believe at the factory, the frame was installed around the engine. the engine is the foundation and starting point, everything gets built around it. When I did my VF1000R restoration, it was hell getting the 200lb Lump out via a trolly jack and 2 people, so I knew installing in the reverse manner would be nigh on impossible, so I did it how the factory did it. However the 500 mill is much lighter and I have installed them easily with the trolly jack as suggested.
    NorcalBoy likes this.
  8. Jim McCulloch
    I totally agree that mounting the frame to the engine was the way to go. But since I am in Texas we do everything our own way so this is what I came up. Did it all by myself with a floor jack AND an engine crane. Went in with no issues.
    Engine installed!!!!
    sixdog and Colddevil like this.
  9. Jim McCulloch
    After that I think an Ale and swim are in order!
  10. straycat
    Right On !!, congrats
    Nice!!!! Great job
  12. NorcalBoy
    Way to go! Getting close to the finish line, way to finish strong. Excellent.
  13. Jim McCulloch
    Well, it took all day and a few naps but I got it running! Cautiously optimistic that things will work out. It had horrible compression (60 PSIG all cylinders) when I checked it before the initial start but I fired it anyway. It started right up and after a few minutes settled out OK. After it warmed up It started smoking again but F it, I am moving forward to rag on it until the rings seat. I know it needed new pistons and a bore but no parts can be found. The ring gap was in spec but on the high side.
    I put the fairing on to keep me motivated that this is actually a real bike an not some figment of my vivid imagination. So much work left to do but hopefully the worst is over.
    SzBalogh likes this.
  14. NorcalBoy
    Give it a chance! Excellent that you've made it this far.
  15. Jim McCulloch
    Thanks!
    I was pretty stressed after I did a dry compression check.
    I still have to sort out the fuel tank issues, as this is an 86 and I was given an 85 tank with the bike. Not exactly compatible petcocks.. Plus the tank was severely rusted. I did the Red Kote deal but it is still leaking ever so slightly. Going to do another coat tomorrow. Bad as it is, this bike is still helping me keep my sanity!
  16. straycat
    Nice work !! Congrats on getting running, that was a complete tear down and rebuild. Impressive!
  17. Colddevil
    Colddevil Member
    Wisconsin
    How big was your smile after it fired? I imagine even bigger than mine after reading that! That frame looks really nice too. Congrats on getting it running, that's a hell of an achievement--especially when you go back and read through this thread to see how much work you put in to get to this point.
  18. Jim McCulloch
    Thank you! Not quite ready to quit my day job to be a mechanic......YET
  19. Jim McCulloch
    Thank you sir! There was a little bit of a smile in between the anxiety attacks!
  20. Jim McCulloch
    So while waiting on the fuel tank RED KOTE to cure I noticed that the tail section has dropped by about 10mm. No idea how it happened but the rear tail section did not line up right with the side panels. A judicious use of the old "Cheater Pipe" or as Management makes me call it "mechanical advantage device" brought the tail section back in line. While I had it apart I painted the rear fender. It was really tired and faded. I gave up trying to restore faded black '80's plastic and just paint it now.
