Jim's $400.00 1986 VF500F
Discussion in '1st & 2nd Generation 1983-1989' started by Jim McCulloch, Jun 25, 2019.
  1. squirrelman
    used this rig to remove valves, we'll see if it's ok for re-installing later. :cool: anything to keep from spending money, right ?
  2. Diving Pete
    Well done Jim, my valve spring compressors are now at 35 years old & were about the same price then..
    certain jobs you dont need a pro tool if its infrequent use.
    Keep the updates coming..
  3. Jim McCulloch
    Jim McCulloch Member
    Yep, keep it cheap! I think I am in for about $800.00 including the price of admission. That is a pretty nice rig job going on there!
  4. Jim McCulloch
    Thank you sir! Targeting having the engine back together in 2 weeks.
  5. Jim McCulloch
    Need some advice regarding engine case sealant. I have used HondaBond in the past. I searched around and the interwebs say that it the same as Permatex Ultra Grey. Is this true? If not what is the word on sealant these days?
    Hondabond.
    I've heard that about the permatex too but my friend thought it still had a silicone quality about it and didnt like it. But Im sure it would work just fine.
    ThreeBond 1184 is a true Hondabond equivalent.
    Mind_Surfer likes this.
  7. Jim McCulloch
    I have to agree with your friend on that. It seems to be silicone. I wish Threebond was more readily available around here, I think I will go to the Stealership and get the Hondabond.
    Is Yamabond the same also?
    Yamabond is the same
  9. Jim McCulloch
    Need some advice again. I am installing the rings on the pistons and cannot figure out which ring goes in the 1st and 2nd ring groove.
    I understand the "R" on the ring goes up. The issue is the Helms manual shows the 2nd ring to have an angle cut on the OD. I cannot see this on the ring set I got. The only differences is one of the rings has a silver ring around it and the other does not. See pictures.
    Isn't that "silver" ring the bevel cut?
  11. Jim McCulloch
    I have taken several close ups and I cannot tell. Hate to get this wrong.
  12. Jim McCulloch
    Made some big progress today. Had to stop because the gasket kit from Japan did not come with the oil pump orings!!! Another order to BikeBandit!
  13. Brian Rodgers
    Brian Rodgers New Member
    Jarrell, Texas
    I am enjoying this thread ! Great photos. I may be rebuilding a '97 engine in the future...
    Brian
    So... did you decide that was the bevel?
    And the oil pump can be installed at anytime.
    Nice progress!!!
  15. Jim McCulloch
    Awesome! It is not too hard if you have an OEM Manual. At least you will be able to get parts a lot easier than on this '86. Nothing comes easy on this bike.
  16. Jim McCulloch
    Thanks!
    I had another set of eyes look at it and it appears the "Dark" or non-silver ring was the bevel cut. The bevel was so subtle as to be almost non existent.
    I am NOT 100% sure this was correct for future reference. I hope I did the right thing! I will know when I start it up (I think).
  17. Jim McCulloch
    IMG_9582.JPG IMG_9584.JPG More progress! Got the cams timed. Still sweating it out as this is something you CANNOT get wrong. Rolled it over several times and checked and it is still in time. No way to be sure until it starts!
    View attachment 83331 View attachment 83331
  18. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    If you are methodical, it is impossible (but very easy!) to get it wrong. Make sure you follow the updated procedure in the manual.
    http://v4hondabbs.com/index.php?topic=62900.msg634007#msg634007
    I had a phase when I was doing the timing on all my VF500 engines. Really enjoyed doing it. Something satisfying seeing it all come together.
  19. Jim McCulloch
    Thank you! I just registered for that site. It would not let me view the link without a registration.
  20. Jim McCulloch
    It looks like I got the timing right, adjusted the valves and nothing crashed as I turned it over several times by hand. YAY!
    Just need to get my oil pump orings and I can button 'er up and put it in the frame. Big job almost over! IMG_9585.JPG
