Jumper cables hooked up backwards '97 VFR750
Discussion in '3rd & 4th Generation 1990-1997' started by kenwood, Jul 10, 2014.
  1. kenwood
    kenwood New Member
    San Diego, California
    It blew when I hooked up a portable jumper backwards on the dead battery for 30+ seconds (+ to- and - to +) and hit the starter. Why that would cause the fuse to blow? My guess is that Honda, in it's infinite wisdom, placed a circuit inline that grounds out & blows the fuse when reverse polarity is applied. I'd have to spend some time with the wiring diagram to figure that one out. I'm very glad it did tho as the transistors in the R/R and the ECU would have taken the brunt of the reversed polarity. $$$$
  2. TOE CUTTER
    I love a happy ending........I'm all verklempt. :Cry:
  3. kennybobby
    kennybobby New Member
    The reversed polarity jumper was essentially wired in as a series battery to double the voltage. [edit] The battery positive goes thru the 30 Amp fuse to the RR where this higher voltage gets directly bled off to ground thru the regulator zener diode--too much current blows the fuse.
  4. Scubalong
    Amen..............Glad you got it fix without breaking the bank account :thumb:
  5. squirrelman
    You didn't study the FSM, that's for sure if you didn't know about the main fuse.
  6. squirrelman
    Me, i'm no rocket-building scientist, but i believe the starter motor is NOT fused through the main 30 amp fuse, has no fuse at all unless i'm wrong (again).
  7. kenwood
    kenwood New Member
    Clymers states that there is a fusable link inline with the positive battery cable. I couldn't find it (duh). The connector doesn't look much like a fuse holder!
    Anyway, I know now, thanks to you. In the future I'll just bump start it if necessary.
    Took Fang out today, she ran like a scalded cat.
  8. Allyance
    Allyance Insider
    Brazil
    East Bay, California
    Squirrelman is correct:
  9. kennybobby
    Squirrel is right--ignore what i said, i was thinking about cleaning that rack after looking at Jev's avatar and nearly blacked out...
    i think the path is thru the fuse to the RR and the overvoltage is bled off to ground--that's how the fuse gets blown.
  10. kenwood
    kenwood New Member
    Best Forum on the net, this is.
    Yoda
  11. NormK
    NormK New Member
    Sounds most likely good call
