Kansas to Prince Rupert, BC, Canada or Bust!
Discussion in 'Trips & Events' started by A.M, May 23, 2016.
  1. A.M
    A.M Moderator Staff Member
    Had another amazing day! No rain and my moto behaved. :)
    I woke up at 4 am and decided to get loaded up and head to Banff. The ride was amazing and the areas just beautiful!![​IMG]
    I love seeing the nature over touristy shopping so I didn't do anything in the town of Banff.
    I saw Moraine Lake first. I've never seen a more beautiful place in all my life.
    [​IMG][​IMG][​IMG]
    I went to Lake Louise just because I was so close and had to see it myself. It was pretty, but not breathtaking to me. Plus it was jammed with tourists. I prefer quiet places to enjoy.
    [​IMG][​IMG]
    I did do a touristy thing and did the Banff Gondola. I'm glad I did!! The views were spectacular and the hike up the boardwalk was fun. I saw some mountain hamsters as zoom-zoom calls them. Lol
    [​IMG][​IMG][​IMG][​IMG]
    I called VF1000fe from the gondola boardwalk to arrange our meeting for the night.
    He met me outside of Calgary and led me through amazing country roads to his home.
    I met his wife, her friend, and one of his sons. We enjoyed dinner outside, tea, and immediately went to work on the bike.
    That wiring harness he fiddled with and added solder. He replaced my lever and successfully bent back the banana one. Sorry, Jeff, no more laughing at it now.
    We changed the oil and checked over the moto.[​IMG][​IMG][​IMG]
    My favorite thing was him teaching me how to properly use a torque tool. Every time I used it in giggled when it clicked. I love learning new things and working in garages so this was a treat. VF1000fe is a super teacher too!! He also had helpful trick for the oil funnel!
    I've been enjoying tinkering in the garages, I'll miss doing that with you friends!!!
    Thank you VF1000FE for teaching me, hosting me, letting me stay in your camper, and riding with me!! I cannot wait to come back to see you and your family again!!!!
    Sent from my SM-G930T using Tapatalk
  2. Gator
    Gator Member
    Moraine lake is a wonderful place. I think it's photo is on the back of one of the Canadian paper monies. I have climbed Mt Temple and looked down on it, amazing beauty. Glad your having good weather for this part of your trip.
  3. 34468 Randy
    I kinda remember that. We change our paper money so many times it is hard to keep track. But we don't have paper money anymore. It is plastic now. Clear see through sections. The one dollar denominations is a coin and so it the $2. Moose Jaw Hoer money. Pennies....gone...yah.
  4. zoom-zoom
    zoom-zoom Member
    BC, Canada
    Keep the photos coming AM. Glad the rest of your trip is continuing on with fun, excitement, and more breath taking scenery.
  5. A.M
    While I have service, I'll post this for you all to chew on.
    This morning with VF1000fe, we stopped for gas. Bike wouldn't start just like on the Yellowhead when I had to be rescued.
    I rapidly flipped the killswitch back and forth several times and kept trying. It finally started, then I was able to pull around the pumps to continue the ride.
    Stopped in Pincher Creek, Alberta for last lunch at Timmies. Same thing. No start. I check all the obvious. All good. So here I go flipping killswitch again. After a few tries it started right up.
    My phone has also been plugged in since 9:30. Says it's charging, but phone battery charge is actually decreasing.
    Wut the WUT!!??
    I should add that this time though, FI kicked on each time as well as all dash, no weird sounds from under dash. So the problem appears to be morphing.
  6. 34468 Randy
    When you were here, you had removed that switch casing did you not? I didn't see what was going on, but helped hold it in place while your were replacing it. Were you actually looking at the workings of that switch? If that switch was faulty, that could explain a constant draw that would also lead to the heat problem.
  7. Allyance
    Allyance Insider
    Brazil
    East Bay, California
    That could very well be the culprit:
    The 'BL' wire is the supply wire to the bike. Haven't had my 6th gen for a couple of years.
  8. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    No. I have over 300lbs on my bike in gear. Didn't bottom once or rub. My preload is maxed front and rear.
    Sent from my A0001 using Tapatalk
  9. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I'll take a look myself at her electrical as well when she gets here. Hopefully on Wednesday so we can ride for a day.
  10. zoom-zoom
    zoom-zoom Member
    BC, Canada
    I only ask because my 5th gen has a JD sourced CBR929 rear shock and the main wire look comes down the left side of the bike and it is VERY tight between the inside of the main frame spar and the edge of the remote reservoir on the shock. If I load too much weight on the bike the shock moves slightly rearward as it compresses. Not much but if there was extra weight plus linkage movement maybe something is being pinched I in behind where it can't be easily seen.
    When end I was at Randy's on the weekend I was looking at the wiring diagram and the wire, which was getting very hot, routes up behind the dashboard (where she heard noises) and then into a switch block but I can't remember which one. As Randy mentions, maybe a faulty start switch could be causing havoc everywhere. Wouldn't be hard to get some moisture into that switch assembly if you spent long enough in the driving rain, and lord knows AM hasn't been riding in any rain. LOL. Maybe a bit of excess moisture and dirt has collected in the switch pod lower assembly and is getting in the way of the contacts. Maybe some preventative maintenance like removing switch assembly and spraying in some contact cleaner making sure it is cleaned out.
    Really do despise intermittent electrical issues.
  11. 34468 Randy
    OK then. So what I am seeing in that diagram is that there is power going to two switches side by side. One switch is normally open while the other is normally closed. When the normally open switch is close during the start process, the other switch should mechanically go to the open position preventing power through both switches at the same time. The power to these two switches is from the same source. Hence that black dot indicating those wires actually splice and not just go around each other. (electrical schematics seem to have changed a bit since my school days).
    I assume one of those switches acts as a starting position while the other as a running position. Naturally you want the starting switch closed when engaging the starter yet to release soon as you release the starter button at which time the run switch would close. If they both remained closed, as in one was sticking or faulting, then you have double the amperage going to the same location which would cause the wires somewhere in the system to heat up more than they should, much like what AM is experiencing near the battery. That would make zoom-zooms suggestion that the next step would be to take apart that switch and clean it up. Once apart, one should be able to see signs of the problem in the contacts. Maybe a new switch might be needed.
    I would think that repeated testing of that switch with an ohm meter with the switch in both positions should indicate there is a problem. In one position, there should be resistance in one switch and not the other, while if the switch is in the next position, the resistance should also be opposite to the first test.
  12. VF1000Fe
    VF1000Fe New Member
    Alberta
    Hot Wire
    When her bike was in my garage, it performed perfectly. Started immediately, sounded fine.
    I wish it woulda failed,,.. I gots the know how and tools to run it down, Pit Bull Mode.
    What we did do was remove a short wire that went to the 30A fuse under the seat.
    She said it would get so Hot it burned her finger, yet it was not discolored.
    Newer Insulation can take the heat, but it shouldn't even get Warm.
    We removed the brass from both Plastic Shells, cleaned, reformed for more Pinch, and Soldered.
    Assembled and Tested OK.
    No connector or Wire should get Hot or even Warm.
    I was looking at the Throttle Switch Asm, as the Throttle Twist was a little sluggish.
    Woulda taken that all apart, cleaned, lubed, assembled, tested,,..
    But we were Outa Time, were up late, and up early, and gone.
    Dems new-fangled bikes got a CPU that runs the bike, and if it ain't happy,,..
    This may not be worth much, but it seems to act up only when its Warm/Hot?
    Photos coming,,.. still processing,,..
  13. A.M
    Alright, I've been in pickles all day. Had to roll backward down a hill...it started at 20kph. That was effing scary. Next stop, border patrol. He made me turn off bike. It started up again fine. Next stop on an incline. I had to leave it in gear and shut it off. Didn't start back up. Luckily I was in a mountain and this time rolled it downhill with my hazards on...it finally started up at 30mph. Got gas 40 minutes later...it to started just fine.
    I can take it apart and clean it....with gasoline?
    What else can I do on the road?
    Thanks for input.
  14. Gator
    Gator Member
    AM have you checked the side stand sensor and wiring there? I have seen all sorts of weird problems with them. Often after a fall or tip over.
  15. RVFR
    No gas.....! If the time and location works, next time it does this, then take it apart and look, again if nothing pops up, re install and see what happens unfortunately this one sounds like some tinkering is going to be involved. and know where you has me SMH.. Damn..
  16. Glenngt750
    Glenngt750 New Member
    Edmonton, Alberta, Canada
    Make sure if you are roll starting it, it is in a high gear. At least 4th. Might be time to stop and visit a Motorcycle Mechanic. Very hard to try and figure out over the Forum. Either that or no turning bike off, maybe for lunch and fuel, as necessary and ride straight home. I'd maybe even unhook your phone charger. Why would it get so hot, as to melt the end off of it? Could be an issue.
  17. Glenngt750
    Dam, I have removed those side stand interloks, for racing. If you put a piece of wire across the leads it'll trick it into thinking the stand is up. Don't know if you wanna try that A.m.? A paper clip would work, or a piece of insulated wire, about 1" long. Tape it in place. Agree with RVFR, take the kill switch cover off and see if there is an issue in there. Loose wires, poor soldering, allowing wire contact to move. If you can, while bike is running, have that cover off and wiggle it around. See if it is hot or anything arcs. Shouldn't take much if it is the problem area. Or visit your friendly Honda Dealer. Might be time!
  18. Glenngt750
    Wouldn't that "Bl" wire be just a low powered wire to operate the contact on a relay?
  19. Allyance
    Allyance Insider
    Brazil
    I think she has two separate problems, I cannot figure out how the starter switch assembly would have that effect on the Main Fuse B short harness.
    for the R/Y wire or the R/W wire to get so hot as to burn a finger, requires a direct short to ground somewhere local to fuse B. If the short occurred further away, then the entire length of the wire would have gotten hot.
    Has the wire gotten hot again after the new battery?
    Here starting problems have more to do with interlocking switches or the kill switch assembly.
    Just hope she can get somewhere to fix it.
  20. A.M
    Good thought. Side stand wiring looks fine. So did the inside of the ignition assembly.
    I'm beginning to feel like it's operator error, this is driving me crazy. I'll figure it out somehow. But rather upset to cut out the state of Idaho.
    Hard day.
