KN-204 oil filter broke
Discussion in 'Mechanics Garage' started by Big_Panda, Jul 27, 2016.
  1. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Never mind it was done with a torque wrench to spec.
    Think before you type something silly like that SOW.
    Sent from my A0001 using Tapatalk
    #41
  2. Big_Panda
    Big_Panda New Member
    Simi Valley
    With a tire that coated in oil how in the world did you manage to keep the rubber side down? Seriously.
    #42
  3. Badbilly
    SOW has been smoking cat food again.
    #43
  4. duccmann
    Think, come on Jeff really?
    #44
  5. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    You're right ... what was *I* thinking ... SOW doesn't think. Lollzzz
    #45
  6. sunofwolf
    sunofwolf New Member
    Ya, I know what happened, that china torque wrench was off by 50 foot pounds
    #46
  7. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    I think it was your brain was off by about 50 IQ to the negative ...
    #47
  8. OOTV
    OOTV Member
    Don't feed the troll...that is all
    #48
  9. Terry Smith
    I took a look at my VTR1000F which has been sitting quietly in the garage (other chores and other toys demand more time). What did I see? A freakin' K&N oil filter!
    Note to self: CHANGE OIL AND FILTER!
    #49
  10. A.M
    A.M Moderator Staff Member
    NOOOOO, Cadbury...no Making Adventures Challening Since 1906 for you!!
    #50
  11. 34468 Randy
    Or you could wait for the filter to blow out the oil and all you would need to do is add new filter and oil. Spent oil not an issue. Its all over the road.
    #51
  12. Terry Smith
    Awesome. Thank you so much for that labour-saving tip Randy.
    #52
  13. Terry Smith
    No I will leave that to you, Wonder Woman!
    #53
  14. sunofwolf
    P1010087.jpg P1010088.jpg P1010193.jpg P1010194.jpg P1010195.jpg P1010196.jpg Nothing wrong with K+N filter-just the installer using the Nut too much, if it was hand tightened-never would have happened. Like it should have been in the first place. I don't use one however and never will-the nut should only be used to take it off-dummy's. Ask Randy How to install a filter without stripping the drain plug. too! How a simple can install goes so wrong. Perhaps -just go to the dealer for oil changes. I going to change the oil soon-I show you how to do that- take off that carbon canister too and fit a over sized napa platinum-there you go just use my old pics-done perfect. use a strong wood boom handle-I broke a metal one.
    #54
  15. OOTV
    OOTV Member
    You apparently read as well as you write and spell. Although it might have been different in AM's case, if you would have read Big_Panda's post you would have saw and read this statement. Regardless of the installation method used, these K&N filters have a problem.
    "When I first bought the bike I thought the previous owner had used the bolt to tighten the filter and cracked it because it was doing the exact same thing, leaking oil from the bolt. After replacing, it was fine for several thousand miles when I replaced the oil filter again. This time I did the oil change and made sure not to tighten using the bolt on the end of the filter knowing it causes problems, however it STILL ended up leaking."
    Damn, I ignored my own suggestion...I fed the troll!
    #55
  16. sunofwolf
    Yes you Knowing put a defective filter back on-now who fault is that? LOL!
    #56
  17. Gator
    Gator Member
    K&N failures are on many different forums. After my CBR's slick looked like AM's tire coated in oil that was it for me. I was lucky to keep the rear spinning and was able to save it in a fairly fast 2nd gear turn. I got off the track asap.
    #57
  18. OOTV
    OOTV Member
    Wow! I really think the school system failed here...
    #58
  19. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    He's not worth it bud ...
    #59
  20. OOTV
    OOTV Member
    Just trying to up my post count! Plus I'm bored...
    #60
