KN-204 oil filter broke
Discussion in 'Mechanics Garage' started by Big_Panda, Jul 27, 2016.
  1. Gator
    Gator Member
    Billy maybe you can answer a couple of questions about Scotts and these type of filters. I read some time back that the stainless reusable systems did not filter down to the same level as traditional disposable, BUT recently I read about the way that they test is different. The Scotts and Flo Oil for instance filter to 30 and 35 microns while a majority of the paper ones are 20 microns. The difference is that paper comes up with their number from a 3 pass test and the stainless is a 1 pass test. The stainless supposedly flows a lot faster too. Found this on a quick search.
    "The FLO Oil Filters are rated on an absolute (1 pass) system. Because of the inconsistencies of paper, they are rated on a multi pass system that allows particles 3 times the rated size (i.e. 60 microns) to pass once. What that means is a 35 micron stainless filter usually filters better than a 20 micron paper filter."
    http://www.webbikeworld.com/t2/flo-oil-filter/
    #81
  2. FightingChance
    FightingChance New Member
    Marina del Rey, CA
    That's how I understood it as well, when I started using PurONE filters on my bikes. I think the bypass PSI differs because of the difference in strength of the oil pump; as I am on top of my oil changes and live in a warm clime, I've accepted the risk of the bypass PSI being too high.
    Also it's kind of cool that I can use the same oil filter on my two Honda bikes and Honda Fit.
    #82
  3. NormK
    NormK New Member
    Does anybody know how long this problem with the K&N been going on, anybody had a reply from K&N regarding it, surely they must know about it.
    #83
  4. sunofwolf
    sunofwolf New Member
    Seems to me I am using excellent stuff, the Napa Platinum $9 when on sale,is designed for syn oil, I use the biggest one that fits-took the carbon canister off makes the changing of filter much easy. As soon as you throw a socket on the K+N -it will dig into the metal. No reason to use this K+N filter on anything. Also make note some filters have a steel shell too thin and can fail. the Walmart ST is too thin shell metal. No reason to have all these problems. I do question the use of purculator pure 1 may actually filter too well-might not be best for a high RPM bike-may slow up the oil flow too much
    #84
  5. Badbilly
    #85
  6. thx1138
    thx1138 New Member
    Perth
    One micron is 2.54 gnats arses.
    Always use this as the conversion number.
    #86
  7. NormK
    NormK New Member
    Not according to Google
    #87
  8. duccmann
    You go D... Dumb ass is he
    #88
  9. sunofwolf
    #89
  10. Badbilly
    The solution to the conversion may be that OZ gnats are metric.
    #90
  11. Badbilly
    #91
  12. NormK
    NormK New Member
    Billy, I dropped a micron on the carpet once and I never found it again
    #92
  13. Badbilly
    They are slithery little buggers and they hide on purpose. ;)
    #93
  14. Gator
    Gator Member
    I think my first failure was near 3 years ago. Wrote them and eventually got a response. They wanted to see the filter. Sent it to them, no reply. Wrote again and they sent me a new 204. The next time I got no reply to my email. They know and don't seem to care.
    #94
  15. Badbilly
    What a great spot for Knight as chief engineer and SOW as head of QC.
    #95
  16. Badbilly
    This is not a plug for K&N oil filters.
    #96
  17. sunofwolf
    the plug needed is for trolls
    #97
  18. OOTV
    OOTV Member
    Now isn't that the pot calling the kettle black!
    #98
  19. sunofwolf
    what did you do to that cat's tail.
    #99
  20. Badbilly
    SOW likes butt plugs just second to his shemales attentions. I claim first dibs on being numero uno. I hope Donald Trump doesn't fire me.
    This is not a plug for Donald Trump. Then again, he may have tastes we don't know aboot.
