Latest acquisition....original owner 1983 VF750F - Euro version
Discussion in '1st & 2nd Generation 1983-1989' started by Bazza, Nov 23, 2023.
  1. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Funny when I searched for turn signal relay - there's one from Great Britain on eBay that looks like mine (round) but all the others from the US are square.
    Guess there are some differences between the two models I should be aware of other than the speedometer in KM's and the gold wheels......
  2. Bazza
    Bazza Member
    No - does not run without the engine running. Doesn't run with key on....engine has to be running.....
    Yeah. The fact that this was raced may be a clue.
    Drain one of the carbs and see if the pump wants to re-fill by just turning on the key, not starting.
  4. jstehman
    jstehman New Member
    Normally the relay gets a signal from the spark unit if I remember.
    Sent from my SM-S911U using Tapatalk
    Weird. Is it possible the winker relay is plugged in the wrong location?
    I'm grasping, I know.
    tsmitty likes this.
    Yep. That's how it's only energized by cranking or running.
  7. Bazza
    Bazza Member
    Looks correct according to Partszilla.
  8. jstehman
    jstehman New Member
    I think on the early models the winker is 3 in a row.. that's how my Magna was. And the fuel cut relay was 3 pins but 2 on top and one below.
    Interceptor is probably different though
    Go to CMSNL and find the correct Model / Market and do some looking on that parts diagram.
    Interceptor is 3 in a row, flat connector, for fuel cut and winker.
    Do the turn signals work too?
    jstehman likes this.
    When I get fully dressed, I'll go out to the other garage and look at an 83.
    Bazza likes this.
  13. Bazza
    Bazza Member
    Just did and looks like I have the right Blinker relay and the fuel pump cut off relay matches up with that empty connector I have so I just need to get that FP cutoff relay and should be set....
  14. Bazza
    Bazza Member
    No but that's a whole 'nother discussion....lol......and right now they are low man on the totem pole......lol.....
  15. Bazza
    Bazza Member
    I'm not seeing a lot of butchered stuff on the bike. It's all pretty much unmolested. Except the turn signals
  16. Bazza
    Bazza Member
    Update............just went out and checked and looks like I had the fuel pump cut connector plugged into the blinker relay. I swapped with the loose one in the photo and now my blinkers are working but the engine does not start/run.
    When I say the blinkers work......they light up but do not blink on and off. So another mystery to solve.
    In theory I can jump the fuel pump cut connector then to be able to run the engine? It has a black, white, and blue wire. Which ones do I jump?
    I have a new relay coming but won't be here until Tuesday.....
    Black and blue... I think on that one.
    With the key on you'll know. You can't fuck anything up by having it wrong.
    Mental note... Turn signal relay might be a quick, temp fuel cut relay jump.
  19. Bazza
    Bazza Member
    OK thanks.
    Blinkers are now working, except missing the right rear one. I'll be changing out to the factory versions anyway but at least we know they are working as they should be.
    Jumped the FP connector and engine didn't start.
    Reconnected gravity fuel bottle and engine started and ran.
    Problem now isolated (I'm hoping) to fuel pump and/or cut relay.
    I took the fuel filter out and blew through it - fine there.
    I think my fuel pump is non-functional now. I will investigate further.
    It was working when I installed it because I tested it then. I will do that one more time.
    I do have a used Mitsu FP coming in the mail but won't get here for a few days.....
  20. squirrelman
    if you have a toggle switch or pushbutton to power the pump, there is NO NEED for a relay.
