Leak......I hate Leak :mad:
Discussion in 'Mechanics Garage' started by Scubalong, Nov 24, 2013.
  1. Scubalong
    This is what I found today when I go over the bike for visual inspection and get her ready for work on Monday......:rolleyes:
    Look like I will be visiting Ootv's garage after Thanksgiving :mad:
    The leak seem to be from the T the little block above the caliper
    I wipe clean and test the pressure the break holding up but I can see the wet spot on the front fairing behind the block
  2. Outboard John
    Outboard John New Member
    Escondido, Ca.
    Bummer my friend, maybe she thinks she's a Harley, you know, marking her spot:witless:
    John
  3. Scubalong
    John
    I am not complaining .....She have been a Gooooood girl. This is a small fix :livid:
  4. Badbilly
    A quick fix might be some Teflon tape on the fitting. If you have to wait for a teardown, wrap the leaker with something absorbent. Brake fluid will damage your paint and plastics..
  5. Scubalong
    I toy with it and come to conclusion that my front suspension is shot :sad:
    With all the leak my fluid should be low but it is full so I went and test the front shock and found to be wet. Wipe off and try again ......sure enough it is wet again. Look like the shock need to be off to JD.
  6. OOTV
    OOTV Member
    Just have Jamie send you the components and we can do the install, otherwise you have to take the forks off and have your bike on a stand for a week or two. I was able to do my '09 forks that way. If you just want to change out the seals, we can do that too, easy breezy! Before you buy them, let me check I think I have a set laying around. They're yours for a 6 pack of IPA!
    Another option is to buy a set of forks off eBay and send those to Jamie and wait for them to come back, once they come in, put yours up for sale! That's the way I went with the '01 forks. I went that route because Jamie was going to do the CBR internals with the rebound adjusters and figured it would be better for him to handle that. Plus leaves me more weekend time to ride!
  7. Badbilly
    Not to worry aboot the forking oil harming your paint.
    Oil spots on concrete are potentially dangerous. Oil can also transfer to your bike tires and ya end up with a slick place. Best stuff I have found is from Walmart.. "Purple Power" follow the directions...
  8. mofo
    mofo New Member
    Orange County Ca.
    I use cat litter over a piece of plastic to keep oil off my garage floor.
  9. Outboard John
    Escondido, Ca.
    My previous bike, the Yamaha TDM had a weapy fork seal and it ran down the fork leg and ruined the brake pads. Mo money. I'd pony up the sizer of IPA to OOTV and just do the seals for now. Aren't you headed south for tacos and beer?
    John
  10. Scubalong
    Yes John I think I have to up grade to Twelve pack to make sure the bike is done for the trip.
    I am running out of time here :rolleyes:
  11. Badbilly
    If your floor is really oily, save a few pesos by using Attapulgite clay. Same thing as cat litter but different than Miss Kitty Litter, Seattle's most famous stripper.
  12. Outboard John
    Escondido, Ca.
    Oh, It's a twelve pack job eh? Your probably going to need a supervisor, I'll check my schedule:biggrin-new:
  13. ridervfr
    Yep, ^ what they said, DOT 4 brake fluid can screw up your paint! I have a spritz bottle of regular H2O handy as it nutralizes that stuff, if you got leaky fork seals, it can get on your rotors then your pads with be shot.
    I like straight lines and always get rid of those square unions, but think you may have linked brakes so that may not work for you, anyway, cheers...
  14. Scubalong
    I noticed the front brake is making awefull grinding noise too, I will have to take it off and give it a good clean.
    Damn I just install all new brake last month....:chaingun:
  15. Badbilly
    Never had this happen on a bike but on a little Honda SW I had, a rock got in between the rotor and the puck. Lots of noise.
  16. Scubalong
    BB I think it the fluid from the shock that cause the problem, I look and no FOD :wink:
  17. Knife
    Knife Member
    Downingtown, PA 19335
    Scube, when you get to be my age, being able to leak is a real plus.
  18. Scubalong
    :pound: hey Knife we still wait for you report......:rolleyes:
    Slacker :cheer2:
  19. Scubalong
    John come over and help Ootv drink the beer :eagerness:
  20. Scubalong
    Anyone have an ohlin suspension laying around :tongue:
    Speak up now :eyebrows:
