LED headlight lamps
Discussion in '5th Generation 1998-2001' started by Cherryriver, Oct 4, 2021.
  1. Cherryriver
    Cherryriver New Member
    SW Chicagoland
    I searched back a few years but no hits.
    I've tried changing the H4s to LED units but the focus is all wrong. I even rotated the lamps 180 degrees for little improvement.
    I used an Amazon pickoff called "Sealight" that has worked well on other bikes without funny focus issues.
    Has someone found the proper solution?
  2. 34468 Randy
    zoom-zoom put together a very good thread on changing from incandescent to LED on his 5th gen (I think...maybe 4th gen). If you search the members tab for him and then search threads started by him, you should find the thread and maybe an answer.
  3. Cherryriver
    SW Chicagoland
    Randy, after a bit of digging I did find the thread, but the info on the parts to use is out of date after some seven years or so.
    34468 Randy likes this.
  4. skimad4x4
    France
    French Alps & London
    Before you waste money on H4 LED bulbs please see this video - yes it is long and well worth watching it all - but the key is revealed rougly 2:40.
    There are a few LED bulbs which work OK in H7 designed headlight housings but sadly none for H4.
    If you need better lighting there are uprated convenional H4 bulbs from the likes of Phillips, which will provide better light, will last reasonably long, and won't blind oncoming traffic. If money is no object HID is the answer with amazing precisely focused beam, but HID is still a single filament design - so cannot do dipped and main beam options.
    PS I do not have shares in Headlight Revolution - but as you will see they really know their stuff and issue updated videos reviewing the latest bulbs.
  5. Cherryriver
    SW Chicagoland
    My experience with H4 LEDs is different. I've installed different ones in my FJR1300, ZRX1100, and my wife's SV650S, among others, all with excellent results. The FJR in particular benefitted greatly.
    DOT approved lamps have proven better for me.
    Other bikes didn't do so well with conversions, including both Interceptors, VF500 and VFR800, so there are problems with certain headlights.
    Possibly the VFR is simply not a candidate.
  6. crewwolfy
    crewwolfy New Member
    Chicago, IL
    I installed LED headlights a little while back, but haven't taken a night ride outside of the city since. I'm second guessing it a bit, as the viffer is for long distance, and I'm not sure how different states will react to LEDs..
    Right now the bulbs filaments are facing left/right, but I believe they should face up/down to make use of the reflector bowl properly. I bought a ring at the base to install H4 bulbs properly. I know I researched all this when I installed, but I clearly haven't retained some important bits.. I need to do some disassembly this winter, I'll check and adjust the headlights and report back..
