Let's make a list of AUS members here
Discussion in 'Australia & New Zealand' started by daffy67, Oct 15, 2006.
  1. Himble
    Himble New Member
    G'day, Andy from WA (Perth).
    Recently acquired a 2001 Gen5 with just over 13k on the clock.
    Since photo was taken, I have fitted a Hurricane handlebar conversion.
  2. Warren Welsh
    Warren Welsh New Member
    Sydney Southwest
    99 Model Rider , Camden NSW, All standard. Looking for a staintune or Yoshi. Hope to make some friends with the same passion for this model.
    Old Faithful likes this.
  3. Warren Welsh
    Sydney Southwest
    Hi Andy,Nice Bike mate. Can you send a pic of the Hurricane Kit fitted.? I am a standard purest ,but exploring other add ons . A mate in the UK said he fitted a Gas Rear shock and mirror extenders. I’m looking at Mirror extenders , as I’m not the skinniest. Haha I have my manual now and will give her its first service since buying . It has 35k on the clock and although there is nothing wrong,I just wish to do a proper service. Thinking about the screen they make in Germany for it also. I’m undecided on handlebars,hence I’m asking you about your kit. My last bike (2002) was a ST1100 , But I always wanted more of a sports bike. Anyway, catch up here soon.
    Warren
  4. Himble
    Himble New Member
    Gday Warren, welcome to the VFR fraternity!
    I also like to keep as close to standard as possible, but sometimes there's a requirement to make a bike a bit more comfortable on long rides. I'm 6'1" in the old language, and will be 71 in 2 weeks and the body ain't quite what it used ta was!!:(
    So....on the advice of a bike club colleague I purchased the Hurricane handlebar kit. I also bought a set of lowered pegs from the US which makes the whole experience more enjoyable!
    Anyway, here's a couple of pics of the handlebar kit.
    Cheers, Andy
    20201031_171241.jpg 20201031_171253.jpg 20201031_171241.jpg 20201031_171253.jpg 20201031_171307.jpg 20201031_171241.jpg 20201031_171253.jpg 20201031_171307.jpg
    LexDex and Old Faithful like this.
  5. PetePower
    PetePower New Member
    South Australia
    Hi Andy what lowering kit did you get?
  6. Himble
    Himble New Member
    Riding a 2000 and PetePower like this.
  7. PetePower
    South Australia
  8. LexDex
    LexDex New Member
    LexDex - 2011 VFR800 Qld, Goondiwindi.
    PetePower likes this.
  9. LexDex
    LexDex New Member
    FB_IMG_1605170667161.jpg First VFR - have had about 5 other Hondas though. Own a nice 82 Bol'dor as well
    RUMBUS and Riding a 2000 like this.
  10. Marksy
    Marksy New Member
    (Ric) Marksy Jnr. - 2007 Candy Red - Canberra ACT
    (Al) Marksy Snr. - 2010 Candy Red - Canberra ACT/Bathurst NSW
  11. dgp
    dgp New Member
    South West Victoria
    David 1995 Gen4 red. Warrnambool Victoria.
    Marksy likes this.
  12. vfrr32
    vfrr32 New Member
    Hervey Bay Queensland Australia
    Had my 1996 VFR750F for 15 years never broke down, recently started coughing and cutting out then stopped completely with no spark on one plug I've tried so far will check volts from ignition and coils soon. Has been super reliable so a bit surprising, any ideas??
  13. skimad4x4
    France
    French Alps & London
    Inevitably it is more questions than answers at this stage, so a few thoughts..
    I suspect you might get more response if this message was listed in the "Mechanics Garage.
    You mention that the bike "has never broken down" but it would help to know the context. Have you actually been using the bike daily over the last winter or has it just been pulled out of winter storage and is now playing up despite running perfectly when you parked it up? (I guess it is spring time down-under).
    If it was parked up over winter - what preparation was done?
    If you have been riding it regularly over the winter - has the bike had any work done on it recently which might have contributed to the problem?
    Carburettor bikes don't like old fuel, so any chance you filled up with a bad batch? Bad fuel might explain coughing and cutting out, but seems at odds with the comment that just "one of the plugs is not sparking" which points towards an electrical/ignition system problem.
    If it is electrical a quick thing to rule out is to cycle the kill switch a few times - after 20+ years corrosion can slowly build up. If it then runs OK give that switchgear a through clean.
    Doubtless you know VFRs have not been spared from the charging system gremlins which affected loads of Honda(and other makes of) motorbikes. So it is also worth getting out a volt meter and checking the battery volts. If that is drained below 12.5 volts then you probably need a replacement battery and then need to do "the drill" to check for any other charging system faults - as a faulty battery may simply be a side affect of a charging system fault elsewhere .
    If all fails perhaps it is time to put in a call to your racing contacts.
    Good luck - let us know how you get on.
    SkiMad
  14. Terry Smith
    I had an issue with the front left plug on my 86 and there was water getting into the plug boot that had corroded the resistor that lives in there. You can disassemble the plug cap by inserting a flat blade screwdriver and undoing the brass end that engages the spark plug. You should find a red resistor in there, if it is un-saveable then a new NGK plug cap will contain the same resistor that can be swapped in.
  15. vfrr32
    vfrr32 New Member
  16. vfrr32
    vfrr32 New Member
    I think it's fixed after I removed tailpiece and lower fairing, my aim was not to disturb many things at once and being systematic as I'm a Broadcast engineer and ex-racer. Next step was to check kill and ignition switch whilst measuring 12 volts to coils, bike was cranking well but dead so I sprayed no drowned kill switch with WD40 as getting to ignition is a nightmare OMG, and WTF it started firing/farting while I was modulating choke and voila so far so good. My assumption without dismantling switch etc is I had a regulator/rectifier burn up a connector years ago due to high resistance and current too, and given age I never hose my bike or ride in the rain any more, next rides will be nervous.
  17. vfrr32
    vfrr32 New Member
  18. vfrr32
    vfrr32 New Member
    I spoke too soon problem is back next day, I will now measure 12v around coils and ignition and could be CDI/ECU??
  19. Wokka Wokka
    Wokka Wokka New Member
    Melbourne
    Will - Wild west of Melbourne. '09 VFR800 white & black (as per profile pic)
    Yes, the tank cover needs a clean, so does the rest of the bike! (just acquired an OEM topbox (but red) to go with my OEM panniers (black), so painted the lot to match the rest of the bike)
  20. Meremortal
    Meremortal New Member
    Noob here, Brisbane South. Just bought a project bike ‘83 VF750. Was my first road bike in the 80’s.
    Riding a 2000 likes this.
