Lift, stand. or anything to lift one or both wheels????
Discussion in '8th Generation 2014-Present' started by Check6, Aug 30, 2016.
  1. Check6
    Check6 New Member
    Denver, CO
    Thanks for all the suggestions. I got on the Bluestreak web site and found the Abba stuff. I'll be ordering one soon.
  2. fink
    fink Member
    Good great bit of kit.
  3. Diving Pete
    I've had my abba superbike stand since 97 & its used weekly on 3 different bikes.
    It is a great bit of kit but I'm going to spec up to the Sky Lift as I want to work at my height & not 6 inches off the floor.
  4. ridervfr
    Once you get it you'll be mad at your self for not getting it sooner. I still work 6 inches off the ground, more due to laziness than anything. How else are you gona do steering hesd bearings securely?
  5. Gator
    Gator Member
    Where did you get it? That seems high according to their web site.
  6. Bubba Utah
    Bubba Utah Member
    Utah
    I did not have a center stand on my 2003 Suzuki Sv1000s. So I bought a lift like you are talking about. Universal really about $65-$110. All you have to do is look for the what I call "Stand hubs" I know I am wrong on the wording, but this bike has a single swing arm. Just google it and see what comes up. Honestly, I remember that for the set of the racing stand and hubs I paid what I did to get the OEM center stand and have it installed on the VFR. I found that the aftermarket stand was a pain in the ass and gave me some scary moments getting the bike up on it and it only weighed 417lbs not 500 +! Downside for all of us is that a center stand adds extra weight, and I did have a center stand come up on me on my old 95 Kawasaki GPz 1100 in a tight corner with a change in elevation that was a safety issue for me! And scared the shit out of the other two riders behind me witnessing it riding tight at 70+. I guess that incident will have me checking the spring tension on the center stand more often on the new VFR for sure. If you change your mind about getting the OEM center stand do not buy it from Honda. I have seen OEM stands on sale online from other sites including EBAY around $80 and like I bought and paid the Dealer $90 to install. Good luck!
  7. Allyance
    Allyance Insider
    Germany
    East Bay, California
    Are we talking about the same model? Don't be fooled by Ducati, only difference are the pins that go into pivot bolts.
    This the one I bought, note the price!
  8. Check6
    Check6 New Member
    Denver, CO
    Yep, that's the one I'm ordering.
  9. Allyance
    Allyance Insider
    Germany
    Watch their video on how it goes together, make sure you put the kickstand up before final lift. I can't imagine some $65-$100 lift doing what this lift does safely. With nearly 600 pounds up in the air, stabilty is paramount.
  10. fatshoutybloke
    fatshoutybloke New Member
    Essex, UK
    Excellent piece of kit, I bought mine several years ago for working on my Ducati which only has a sidestand, but I later bought a set of VFR pins for my 6th gen and they fit the 8th also, and I've now added the front lift arm as well. I wouldn't be without it. Mine came direct from Abba because they're less than 20 miles from where I live!
  11. fatshoutybloke
    Essex, UK
    And they're now crossing the pond - http://abbastandsusa.com/
    I have no connection to the company, by the way, other than owning some of their excellent kit.
  12. James Bond
    James Bond Member
    Dixie
    I recently obtained front and rear Pit Bull stands. The front I use goes into the triple tree holes, or it can be converted to go under the forks. I got them mainly to hold the bike properly and SAFELY to get the front wheel off. In your case, it would help you with the rear wheel not having a center stand.
    Pit Bull stands are a must have IMO. I wish I would have had them years ago. They're solid, hold the bike totally solid, and are quality built with zinc plating. No paint to end up looking like shit later on. They're easy to sell. Great design better than the rest. Their welds are amazingly high quality. FWIW.
  13. Gator
    Gator Member
    Been using Pit Bull stands for more than a decade and still using the same set.
  14. James Bond
    James Bond Member
    Dixie
    Used them yesterday for an oil change. Gets the bike up higher making it easier to get to things. How did I do without them?......worse.
  15. John O
    John O New Member
    Whidbey Island, WA
    I love my Pit Bulls. Makes me feel good every time I use 'em.
  16. Diving Pete
    Well I got the Skylift...
    & it lasted 1 week before I started to modify it - lol
    Basically I hot glued some rare earth magnets to certain areas of the stand.. I would have used epoxy if I didn't have the glue gun.
  17. Diving Pete
    The magnet on the Jack Arm is for holding the Jack handle out of the way - I dont have the foot kit.
    Magnets on the 2 arms are for holding the 'specific bike bits' to the arms so I dont have to worry about a dropped bit.
    The magnet at the top of the main post is for the allen key & Jack Lock Off Pin.
  18. chuckywucky
    chuckywucky New Member
    SF Bay Area, Ca
  19. Diving Pete
    Yes that's the lift I have - although the cbr400 is using it at the moment.
    It works perfectly.
  20. chuckywucky
    SF Bay Area, Ca
    Thanks! I'm really thinking about ordering it, but according to their site it won't lift a Kawasaki Concours -- my other bike. I'll shoot them an email to confirm
