Looking for any cooling/electrical system upgrades
Discussion in '5th Generation 1998-2001' started by connah250r, Jul 31, 2023.
  1. connah250r
    connah250r New Member
    Plano, TX
    You're right, I didn't check, my fault. I dunno if I missed it in the service manual (I don't do terribly well with books, I'm autistic and a visual learner) or if it's just not there. Regardless, I just checked and sure enough there's a short to ground on the three phases.
  2. Grum
    Grum New Member
    Ok, at last you have confirmed the Stator is toast.
    Just be aware of the very stong magnetic force pulling the Stator towards the Rotor, it can make for difficult removal, and when installing can pull the Stator housing out of your hands, potentially damaging your new housing gasket.
    Good Luck Connah, all the Best with everything.
    connah250r likes this.
  3. connah250r
    Plano, TX
    My new stator just came in! I'm so excited to put it on tonight. One question though, the 3 phases are supposed to have continuity to each other (and no to ground)... right?
  4. Grum
    Grum New Member
    Yep this has already been mentioned a few times! Your phase to phase coil resistance will be very low, virtual continuity, BUT you want infinite resistance/no continuity from any phase wire to Ground, being the iron core of your new Stator, or frame/ground when installed in your bike.
    Good Luck.
  5. connah250r
    Plano, TX
    I'm so beyond angry right now. Not at any of you, nor the manufacturer, but myself. I was erroneously lead to believe the 6th gen and 5th gen stator were the same, apart from the connector, but that's wrong. I accidentally ordered a 6th gen stator and gasket, and I emailed them asking them to change to a 5th gen gasket (which they did), but did not opt to change the stator since I was told they're the same. My new stator won't fit, and now it's 1:11 in the morning after spending like 4 hours busting off this gasket, and I'm utterly beside myself. I'm gonna try and email the place I bought it from to see if there's anything they can do, but I really doubt they'll let me return, since I cut off the connector and put on my MOSFET connector.
    Welp, guess I'll be back two weeks after my next paycheck. I gotta find a new hobby...
  6. connah250r
    Plano, TX
    image.jpg New stator is in! I didn't have enough time (or endurance, it's 100°F today in NTX) to REALLY test it, but it didn't go below 13.5 on my 20 mile drive! Coolant is still running a bit hot, it was going anywhere from 220-239, but as long as it's not triggering the warning and my battery is staying charged, I'm fine! One problem... despite 4 meticulous hours of gasket scraping, either i missed a spot or didn't put gasket dressing on the bottom, cause its leaking oil! I just put a new gasket on and I'm sure if I try and take it apart after that high temp ride I'm gonna have to scrape it again... Any ideas for how to patch the leak without opening the cover or permanently welding it shut? :/
    By the way, here's my old stator :)
  7. mello dude
    Dude.... everybody here is a "do it right or dont do it" ...... pull it apart, scrap the gasket. An old credit card works fairly well. There are gasket disolvers if you need to go that far.
    Then head to the hardware store and grab some M6 x 40 bolts, cut the head off.
    Use these as guide pins so everything goes on straight.
    Then with the new gasket.. use a gasket sealant... I like Permatex High Tack gasket sealant. Dont use the brush that comes in the can, its goofy sticky shit. Cut the head off a Qtip and apply with the care of a surgeon...Use on both sides.. on the engine and on the stator cover.. (some guys will object to this..dont care)
    When that is done, and the pins are installed roughly evenly spaced, slowly guide the stator cover over the pins and on to the engine side. Add all your fasteners then..
    Engine cooling... check to see if its full.... Things I have seen in these forums...
    -Add a switch to get the fan going earlier that the thermal switch 217 degrees F.
    - Add another computer fan to the right radiator...
    - Replace radiators with 6th gen part, they have 13% more cooling capacity.
    - Some guys have gone to custom build radiators for also more cooling capacity.
    - Replace 2 row oil cooler with 6 gen 3 row or RC51 5 row cooler
    - On fans....
    ----- OEM is best if you are going in dead stop and go.
    ------ VTR is best if only typically you slow down to roughly 10 mph and move faster after that. - I'm running the VTR fan in my '98.
    Good luck..
    pi-on and Riding a 2000 like this.
  8. vfrgiving
    vfrgiving New Member
    Yup, big fan of high tack. I use that stuff on everything, including the stator cover gasket I did 3 weeks ago. I even put some around the rubber triangles that seal off the wire entry into the cover.
  9. Riding a 2000
    Riding a 2000 Insider
    Rochester Hills, Michigan
    Educational, reading this thread.
    No issues (yet, anyway) with charging on my '00
    Interesting to read about the temperatures... Has always made me nervous as hell to see water hit 215, and no fan action at all.
    Just did an oil change, and I meant to check the fan for function by giving it 12V directly, got in a hurry and forgot.
    Going to hunt in the forums for threads on operting temps and cooling upgrades. I have considered just installing a rider-operated switch.
    pi-on likes this.
  10. connah250r
    Plano, TX
    Here's The Update™
    New gasket was supposed to come in today, but while eBay says it's "posted", I don't have a tracking number, so we'll see.
    I do actually have another gasket around from my first install, but I don't think it's a good idea to use it, since it's all gritty from sawdust and covered in dried sealant. If there's a way to wash it off, that would be nice.
    I got a carbon gasket scraper and some Permatex foaming gasket remover, so I'm gonna use that to get this gasket off.
    Haven't heard of the High Tack, I'll go get some when I run to go get the M6 bolts. I used Permatex Gasket Dressing & Sealant, I used it on my clutch cover with no issue.
    I also see a spray-a-gasket high tack sealant. I assume the jar would be a better fit for what I'm doing, but I wonder if anyone has any thoughts on the spray-a-gasket. I see a tube of high-tack gasket sealant as well, I wonder if that would be better [to apply] than the jar.
    I wonder if anyone here is good at CAD, it would be so cool if someone could CAD up some gaskets. I have a laser cutter but suck at CAD, so it would be super nice to just cut my own gaskets instead of paying money every time it fails, then waiting for eBay shipping. Maybe I should use that spare stator gasket (and the clutch gasket I have that got folded in the mailbox, thanks USPS) and hone in my CAD skills.
    Other than that, the bike seems like it's running good. From what riding I have done, it's staying charged and I don't think I've seen it go below 13.5 even with the fans on. I'm trying to keep my riding to a minimum, since the oil from the stator cover ends up on the tire, which is a no-no in my book.
    The cooling seems a little better, which I chock up to two things
    - The extra voltage from a working stator is allowing the fan to spin faster
    - I refilled the overflow bottle with distilled water instead of antifreeze
    I'm still interested in mounting a fan to the right rad, just for extra cooling power on hot days. I have a whole tub of computer fans, but I wanna find something with super high CFM that'll fit in the (I believe) 20mm between the rad and the engine I've seen online. I also gotta figure out how to mount up a manual fan switch and how to actually mount the fan. I think I saw someone using zip ties, but I don't know how much to trust that.
    In the mean time, I've been working on my eBike. Helps with the VFR withdrawal, but it's just not the same.
  11. tsmitty
    tsmitty Member
    Sweden
    Ohio
    Genius!
    mello dude likes this.
  12. mello dude
    - Dude......please don't use a spray on gasket sealant........the reason for a can is that you can carefully apply it where it's supposed to go.....and nowhere else.
    - There a lots of different sealants on the market, I can't say if the tube you have is a good choice. I'm a creature of habit, if something works for me, I stick to it.
    - Don't ride the bike if it's leaking oil and getting on the rear tire....
    - If you have a more mechanically inclined friend, plz give him a shout, get help.
    Good luck
    pi-on likes this.
  13. connah250r
    Plano, TX
    Just to clarify--
    The plan was to get the tube, it appears to be the same material as the can. Was just curious about the usage and application of the spray.
    I think the high tack should work better than what I've got though, as it'll be much tackier. The stuff I got was a little goopy. Either WILL seal, but the high tack is most likely EASIER to seal.
    As said, I took a test ride, got the info I needed (IE- it's still leaking oil) and my bike is currently collecting dust until the gasket in. All my oil is on my chicken strip portion, and I'm going to look into how to get the oil off without (or rather, minimally) damaging the tire, I'm guessing degreaser and a rag.
    I haven't measured the standard bolts that are on the stator cover, but I'm guessing 40mm is longer than the standards? Is the correct procedure
    - goop up the engine side
    -insert M6 bolts and dowels
    - goop up gasket
    (and/or?) - probably gonna go with both just to be safe
    - goop up stator cover
    - slide cover onto M6
    - remove M6 bolt with pliers, replace with cover bolt, repeat for each bolt
    Apologies if I come off as mechanically incompetent. While I've been disassembling and reassembling things all my life (i get it from my engineer dad), I've only been working on things with engines for 3 years. I was considering taking mechanics as a field of study, but I decided to stick with tech. My brain is wired to work best from hands-on learning, so my mechanics knowledge is all self taught and experienced-based. I come here to make sure I have the right info from people who know this bike better than me. I have a lot to learn, and I'm not good at putting my thoughts into words, so forgive me if I misunderstand or ask too many questions. I tend to have my dad help me out when I'm out in the garage.
    bmart likes this.
  14. mello dude
    I get not being much of a wordsmith to describe what you want to do.....
    Soooooo....
    Before you start, both the engine side and stator cover need to be.....eat off it spotlessly clean! Screw this up and you will only have to do it again.
    But again frickn very surgically carefully with a cut down Qtip....
    1. Apply the High Tack (HT) on the engine side of the case. Patience plz.
    2. Install 5 or 6 ...40mm guide pins around the perimeter of the case....
    3. Apply HT on the stator cover. More patience...
    4. Set gasket on stator cover....no HT on the gasket, you are making a sandwich ....cover, HT, gasket, HT, engine case.
    ---- Optional to set gasket on engine side, slide it over the guide pins
    5. Slide stator cover frickn carefully over guide pins and mate it to engine case.
    6. Leaving the pins in place, loosely install the OEM 6mm socket bolts where possible at this point. Right bolts in the right spots....?
    7. Next, one by one, remove each pin and again loosely replace with OEM 6mm bolt. I think there is a couple different lengths, so you need to have the correct ones in the correct location.
    8. Once all pins are out and socket bolts loosely installed, now go back and torque the to the proper spec, per factory manual.
    9. Let sit overnight to allow the HT to cure.
    10. Don't forget to check the oil when you are done.
    Ok, now.......got it?
  15. connah250r
    Plano, TX
    Just to clarify... I cut the cotton part off a q-tip and use the stick, or am I misunderstanding?
  16. mello dude
    I like to cut it down to about a third, just so there is a little cotton on the tip....chances are you will go through 4 or 5 of them ..suggest trying it out on something for practice before you do it for real. That HT is a bit challenging to work with....
    You don't have to use a Qtip, if you like something better, go for it. Wood match stick? Small artist brush? Practice....
  17. connah250r
    Plano, TX
    Gasket came in! GF expressed interest in helping me work on it again, so I'll come back with the results later tonight.
    Would a wooden wide popsicle stick be adequate? I've got a whole drawer full of those. Will practice with some Q-tips just to be safe.
  18. mello dude
    Wide popsicle stick is probably too big, maybe cut one down....the idea is you control where the stuff goes. Should be a thin even coat on the parts and nothing to the inside.....It can get outta hand fast.
  19. connah250r
    Plano, TX
    It's in!
    From all the time it's been put back together, and also the 2 minutes I ran the engine (didn't wanna get it hot just yet, just wanted to get some oil flowing), it hasn't leaked any oil. Tire degreased, chain lubed, I'm letting it rest for a few hours (3, as recommend on the high tack), then I'm going for a ride. Wish me luck!
  20. connah250r
    Plano, TX
    Welp.
    It is leaking oil still, but not as much.
    I'm genuinely at a loss, I don't know what I did wrong. I scraped all of the old gasket off and used some fine sandpaper to make sure the mating surfaces were clean, put in 5 M6 screws, covered engine and stator mating surfaces in HT, no metal showing, torqued in a star shaped pattern, I thought I did everything correct.
    What I DID notice is
    - The gasket split after installation, but the split was outside of the mating surfaces. No more Caltric gaskets, I have had no luck with them at all. I'll save up and splurge on a Honda next time. Still, I'm not sure if that would make it leak, since the split is outside the mating area.
    - There did look like some abnormal, possibly gouged areas on the block.
    Am I shit out of luck? Is it time for me to get a new bike? I am getting quite sick of this, I've had this bike for over a year, and while it's a blast to ride, there's always something broken on it. When I fix something, something else breaks. I love the VFR, but I don't know if I love MY VFR...
    I'm utterly heartbroken. Is there any possible ways of fixing a potentially gouged block? I feel so stupid right now.
