Loss of Throttle Responsiveness
Discussion in 'Mechanics Garage' started by afpierce489, May 1, 2010.
  1. afpierce489
    afpierce489 New Member
    Cape Cod, MA
    So, I had a few moments to do the quick check to see about the pipes and sure enough, #3 took a long time to heat up. It probably only heated up because of radiant heat from the other exhaust. My next plan is to check the plugs as dizzy suggested. I'll let you know how it goes. Thanks all.
    Adam
  2. tinkerinWstuff
    so what do I win?
  3. afpierce489
    Cape Cod, MA
    So today I was able to get out and check a few things. I pulled off the plugs on #1 and #3 to check them out (pic enclosed). #1 is on the left and #3 is on the right. This pic was before I cleaned them off and checked the gap. #3 gap was off for some reason. I was also able to pull the air filter off, start the bike and look at the carb slides. #3 was the only one that DID move when given throttle. All other didn't move at all. #3 was the only one that "wiggled" as I gave it throttle. Also, I checked the vent tube for the gas tank, and it is completely clear, no problems there.
    If there are any other suggestions, let me know.
  4. TOE CUTTER
    Inspect the slide diaphams for damage and that they are sealing. You should have similair resistance in all of the if you push them open rapidly with your finger.
  5. afpierce489
    Cape Cod, MA
    So I opened up the airbox and pushed rapidly on all of the slides. I haven't torn anything apart yet. I found #2 and #3 slide in and out with some resistance and ease their way back. While #1 and #4 move with little to no resistance and kinda slam back. So, my question is which is correct. I am assuming that #2 and #3 are correct because they have resistance and ease their way back signifying that they are sealing. Again, from my previous post, #3 was the only one that moved, rather wiggled, when I had the bike running with the airbox off and giving it throttle. All the others did not move at all.
  6. afpierce489
    Cape Cod, MA
    So I took #1 slide apart, put it back together, fired her up and now #1 and #3 move (wiggle) as you give it throttle. I haven't done anything with #2 or #4 yet, and they don't move. Looks like I'm removing the carbs, again, to get to those.
  7. tinkerinWstuff
    regardless of what the vacuum sliders were doing, you need to figure out the cause of the dead cylinder. The vacuum sliders open up the main jet but you still have a fuel or spark problem going on with that cold hole. Even with the vacuum slides all the way down and at idle, you should have a hot header pipe because fuel is being drawn thru the pilot or slow speed circuit of the carb. You have a compression, sparks, or another carb problem causing that cylinder to not fire at idle.
  8. afpierce489
    Cape Cod, MA
    Sorry, thought that I posted it before. I took out the spark plug on #3, kept it in the wire, grounded it, pushed the starter and checked for spark, nothing. I haven't had a chance to check #1 or even swap the two to see if the problem moves. I'll keep you posted.
  9. tinkerinWstuff
    not sure where you planned on going from here but I get the idea you are moving ahead with pulling the carbs. Personally, I'd deal with the sparks issue first. You don't want to keep starting that thing up testing for vacuum slide operation the whole while you have fuel going into the dead cylinder and washing all the lubrication off your rings. Make sure you have some viscosity left in your oil too.
  10. afpierce489
    Cape Cod, MA
    Got it. I bought a new set of plugs today and plan on installing them soon. I am currently using the OEM NGK's, but I bought the Iridium set for the replacements.
  11. scalleywag
    scalleywag New Member
    Surrey, BC
    Hey guys I'm having the exact same problem with my 84 VF1000F....my bike idles fine until I roll the throttle and it will either burp & die or just dies. I tried manipulating the choke but starting it isn't "my" problem. All week my gas tank was poppin pin holes in it. I pulled the tank, flushed & epoxied it, then changed the fuel filter which was totally clogged (I cut it open & it was like mud inside). Now with that changed, it still has the same problem. I think mine tho has the vent in the gas cap, which by the way is really tough to close / lock.
    I'm going to try the same thing. I know the pump is working fine + a new filter...so I have the tank off now, I'll pull the plugs check/gap and then check the sliders and check the tank vent.
    We all should be riding right now :(
  12. tinkerinWstuff
    In your case, you likely have filter screens in the carb that are clogged as well. To test, you would unscrew the float bowl drain on each carb and see if you can get several cups of fuel to freeflow. If the filter screens in the carbs are clogged as well, you'll get about a cup of fuel and then it'll start dribbling slow. A fuel filter won't catch everything when your tank is that rusted.
  13. crustyrider
    crustyrider New Member
    North Country, New York
    what tinker said... also if your tank is that rusted chances are your vent tube aint venting..... I would also check the wee little filter screens in the carbs....
  14. scalleywag
    Surrey, BC
    Ok, so I pulled the plugs cleaned(rustish red/brown hue) & re-gapped them. Pulled the carb set out, removed the seat & jet and there isn't any filters in there but they weren't dirty anyway. So, next I'm going to drain the tank & look at the vent tube like you suggest. Whatever is happening, it has to be something that would effect all four cylinders at the same time, to kill the motor at full throttle....in theory lol
  15. tinkerinWstuff
    Might be a good idea to start a new thread scalleywag. Things have a habit of getting confusing in the same thread when diagnosing 2 different bikes.
  16. afpierce489
    Cape Cod, MA
    So today I finally got off my ass and changed out the spark plugs. I put in the iridium plugs this time, heard good things. I put everything back together, started her up and noticed an immediate difference. I took her for a 30 mile or so spin to check things out and there was definitely a difference in that there was much more power. However, it still feels like it's lacking some. Before I put the air filter back on, I started her up and checked the slides again. #1 and #3 "wiggle" when given throttle, and #2 and #4 don't move at all. Correct me if I'm wrong, but they should all wiggle a little when I give her throttle, right? This may be where the slight lack of power is coming from. So, I've fixed the spark issue (thank you tinkerinWstuff for the suggestion), but this may have been a duel issue problem. I just may need to delve into the carbs again, only the upper half this time. Or, the other possibility is that maybe when I took apart #1 slide to get it to move, it messed up the sync. I didn't re-sync after that. Could that be a possibility? Let me know any suggestions, everyone has been a great help so far. Keep 'em coming.
    Adam
  17. afpierce489
    Cape Cod, MA
    Well, between yesterday and today, I took the carbs off, took off the slides for #2 and #4, inspected and put them back together. I made a tool out of the inside of a syringe and a pair of forceps so that way I could hold the slide open so that way they fit back in the groove easier (pic enclosed). It really helped out alot. After I put everything back together, I did a sync with my homemade tool. I got them within about 1" of each other (using 10W40 motor oil in the tubes). So I just took her for a little test run around the block and the power is definitely back. I'm going to take her on a little 30 mile run here today, got an errand to run, and I'll see how she performs. Thanks again to everyone for their help. All the suggestions made it easier for me to pinpoint what was wrong. Now maybe I can participate in that photo game that I keep seeing. Ride safe.
    Adam
  18. shabba
    shabba New Member
    So what's the update here? Is the bike doing better? My '86 500 is doing this and I just had the carbs cleaned. Wanted to see what you figured out.
  19. afpierce489
    Cape Cod, MA
    Bike is doing alot better. Figured out that my problem was 2 fold. First, I wasn't getting spark on #3 cylinder. So I replaced all the spark plugs. When I did the beginning of the season checks, I only checked the plugs and put them back in. So, now I've got 4 new ones. Second, after I rebuilt the carbs, all of the slides were not moving when I gave it throttle. Only #1 and #3 were moving. So I had to take the carbs back off and mess around with #2 and #4 slides to get them to work. Put everything back together, sync'd the carbs, and viola, better bike. I do seem to be running a little rich, so I may mess with the idle screws, maybe not, we'll see. But all in all, things are running alot smoother.
