LSL Bar Conversion Vs Helibars
Discussion in '5th Generation 1998-2001' started by FrankieKingpin, Oct 7, 2019.
Tags:
  1. FrankieKingpin
    FrankieKingpin New Member
    Hey guys, anyone have any thoughts about the LSL bar conversion versus the helibars? I had a 6gen with Helibars, but still felt a bit stretched over, so im a bit gunshy to get them for my new 5th gen. I had never heard of the LSL conversion before last week, and kind of like the idea. Do any of you have either for the 5th gen? for reference im 5'6, 230lbs, and 28" inseam.
  2. DaHose
    DaHose New Member
    Napa, CA.
    Hey Frankie
    My 5th gen. came with the little underbar riser type of spacers, but they weren't enough. I wasn't sure I'd like the LSL setup either, and it has a hefty price tag. I decided to test with a "homegrown" version using a spare top triple, bolt on bar clamps, low-rise superbar, and ST1000 throttle cables. I absolutely love the configuration. My setup actually feels so good that when I started looking for an LSL supplier, I still couldn't bring myself to pull the trigger because of the price tag. I don't mind that mine looks a bit "industrial".
    You do want longer clutch, and brake lines to do the job "right". I converted to braided SS in front only and it really helped brake feel. I HIGHLY recommend that front brake line upgrade.
    Jose
  3. FrankieKingpin
    Thanks for the reply. Do you have pics of your set up?
  4. DaHose
    DaHose New Member
    Napa, CA.
  5. jfrahm
    jfrahm New Member
    Here's mine, before I got the bar ends on and sorted out some cable routing.
    Also running ST1100 throttle cables.
  6. DaHose
    DaHose New Member
    Napa, CA.
    I didn't want to drill my original triple, so I did the double up thing. That's clean looking jfram. The silver risers look almost factory.
    Jose
  7. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
  8. DaHose
    DaHose New Member
    Napa, CA.
    Is that the complete kit, including the fork tube clamps? Or is it just the bar, and the riser blocks?
    Jose
  9. VFRIRL
    VFRIRL New Member
    Ireland
    Ireland
    I'd imagine it's a complete kit, bar ends not included but you can order whatever colour bar ends you want on the site.
