lubing an o-ring chain.
Discussion in 'Mechanics Garage' started by TheUnnamed11, May 6, 2010.
  1. Triplepac
    Triplepac New Member
    Seattle
    Tried Chain Wax. The can ran out of propellent right away so I have a can full of stuff that I can't get out and it's been sitting there for a couple of years. :-(
    #41
  2. TheUnnamed11
    TheUnnamed11 Banned
    this is what was on the chain after 200 miles.
    the chain was very slick. what was on it was very slippery, like sute ( i tried googing and dictionary.com, i caint spell that word to save my life) and it wiped right off.
    I first wiped off the original lube with a rag, then applied the dupont stuff a couple times (only one i think was neccessary).
    after a few hundred miles i re applied, it was still very lubed, and nothign grimey or course was on the chain, but it cleaned it VERY WELL. after applying it looked brand new again. perfectly clean and very very lubed.
    i also sprayed some on my kick stand as it was getting hard to move. this stuff is pretty amazing, the stand kicks up just by touching it. i am very amazed at how welll it lubed it.
    if you use a good ammount id say you can get about 3 lubes/cleaning out of one can. 4 if you use it somewhat lightly.
    #42
  3. TheUnnamed11
    TheUnnamed11 Banned
    thanks for letting me know man, i am sold on this stuff. wont use anything else (well, ill get the one they made specificially for chains which has more moly and tephlon.)
    #43
  4. Triplepac
    Seattle
    Great stuff for everything. Thanks for the tip!
    #44
  5. crustyrider
    crustyrider New Member
    North Country, New York
    anyway to know if I have the original chain? I couldn't see any markings but I am pretty sure its the original one... replacing it soon... just wondering
    #45
  6. leftcoast
    leftcoast New Member
    somewhere near Seattle, but my heart is just north
    at the risk of turning this into an "oil Wars" thread.....does anybody just use WD40? or nothing, cause the chain is lubricated & sealed with the o-ring...or X ring?
    here goes.......
    #46
  7. TheUnnamed11
    TheUnnamed11 Banned
    i believe they are still ment to be lubed, as they coome with lube on them from the factory. wd40 would be a bad idea. it was originally designed as a water displacement (wd40 = watter displacement 40th attempt). it works well as a temporary lubericant, but it drys up very fast.
    the great thing about the tephalon (yes i spelled it wrong) wax lube is it cleans as well as lubes. just keeping the chain clean will make it last, and this stuff cleans GREAT.
    #47
  8. TheUnnamed11
    TheUnnamed11 Banned
    there may be a purpose of lubing an oring chain other than lubercating it, it may be for protecting the orings. so they can do their job in holding the lube in the link. others here can probably answer this one for me
    #48
  9. vfrcapn
    vfrcapn Insider
    Grass Valley, CA
    Yes, I generally use just WD40 and typically get around 15K from my chains.
    #49
  10. leftcoast
    so does my friend. about 17 or 18,000 & he just changed his chain 'cause he thought it had been a long time. it wasn't worn..... meh........
    it always looks really clean too cause the oil is so light, nothing ever builds up.
    dunno. I'm gonna try it.
    #50
  11. mhzpower
    mhzpower New Member
    Brunei Darussalam
    Vancouver, BC
    Old thread, but i have a question about damaged orings.
    I have a used chain that has a couple of orings piping out.
    How urgent is it to replace the chain? I use DuPont wax about every 500km.
    #51
  12. bk94si
    bk94si Member
    Not an emergency but it will wear faster as dirt and moisture get in there with nothing to stop them. Motorcycles long time ago didn't have o-rings.
    #52
    mhzpower likes this.
  13. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    Lube it with something oily rather than chain wax, IMO. I don't think the wax keeps the O-rings
    as supple as some type of oil based lube. JMO of course.
    I had a '73 Bonneville in 1975. It had about 40 hp and a #50 chain. If I got 10,000 miles out of
    that chain, it was amazing. And that's lubing it constantly. O-ring chains are wonderful things.
    #53
  14. mhzpower
    mhzpower New Member
    Brunei Darussalam
    Vancouver, BC
    Cool, thanks! It’s good to know that it still has a little life left.
    I have a new chain on the way anyways.
    My sprocket doesn’t look anything like the ones posted here.
    #54
  15. James Bond
    James Bond Member
    Dixie
    My experience with chain lube in dry riding is to use what Honda recommends OR Honda branded chain lube. Both are relatively thin viscosities and are easy and not messy to apply. I've found that waxy, thicker, stickier chain lubes attract road dirt and grit much quicker which eats the chain. The thinner the better AFAIC. The Honda recommended differential lube can be applied by putting some on a folded up paper towel then turning the chain over the semi- soaked paper towel.....done.
    I get close to 30K miles from a chain and don't have to clean it very often using these two lubes. You dudes in rainy areas know what works best for you. Chain lube is a racket with dozens of concoctions. They all work. Some attract more dirt than others.
    #55
  16. Vlad Impaler
    Vlad Impaler New Member
    Indianapolis, Indiana
    My '95 OEM chain lasted a looooooong time with good-ole 80-90 gear oil.
    I thinks it's less about a fancy product and more about keeping it regular. I was more meticulous about upkeep a decade to two ago.
    Only better thing I have had in the past was a cog aramid belt on a Kawasaki. I adjusted it once early in it's 16,000 mile life (before selling it, in perfectly good shape) and never had to do anything to it.
    #56
    James Bond likes this.
  17. bk94si
    bk94si Member
    Chain wax for me. I literally never have to clean the chain. It stays perfectly clean. I just reapply new wax right on top of the old wax.
    I've use a lot of products over the years - PJ1 chain lube, Amsoil metal protectant, gear oil.
    #57
