mechanic doubts...
Discussion in 'Mechanics Garage' started by silverbullet132, Nov 24, 2011.
  1. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    The battery will get very hot and the boiling electrolyte will provide a very strong smell. Trust me, you'll be able to tell if it is over charging. Just take it for a few short rides to try it out.
    The specs for the R/R are 13.5-16V @ 5000 RPM. Your 15V is going to be fine.
  2. silverbullet132
    silverbullet132 New Member
  3. tinkerinWstuff
    I thought it was a '98 but didn't pay that much attention. The 2000-01 has a different part number for the harness. Most likely due to O2 sensors and additional pinouts on the ECU for them IMO. It may work but I wasn't willing to take the chance or spend any more time in research myself so I bought a '98-'99 for the project I'm working on.
  4. silverbullet132
    Scored a harness with coils for $64.50 shipped, just have to ride down to Niagara,NY to pick it up as the seller refused to ship out of USA :)
  5. silverbullet132
    Temp hooking the monitor wire straight to the battery fixed it, would it be a bad idea to use this as a permanent fix?
  6. silverbullet132
    Stator turned out to be bad...27v on one, 45v on another, and about 80v on the last one. Could this be what is causing the problems?
    Ordering a Rick's stator Monday :) unless RM stator is better?
  7. silverbullet132
    Stator replaced but he now discovered the cover had been well messed up by the last owner. Found weld fixup spots, and I think caulking too. Told me when he replaced the stator it was hitting off of the flywheel rotor? Ordering a new OEM cover/gasket tonight/tomorrow.
  8. slowbird
    slowbird Member
    Toronto, Ontario.
    I hope this is the lastfix for the bike SB
  9. silverbullet132
    Me too. My wallet is starting to get pretty dry :frown:
  10. mello dude
    Iran, Islamic Republic of
  11. silverbullet132
  12. mello dude
  13. ridervfr
    I like that one/gona mis-apropriate it to mine...dont wana hi-jack the thread...
  14. silverbullet132
  15. mello dude
