melted stator wires
Discussion in 'Mechanics Garage' started by mdange2011, Feb 23, 2012.
  1. Allyance
    Allyance Insider
    East Bay, California
    I went with the SH775 because I am running LED headlights and tail lights. Just got back from dinner, unit is cool.
    #81
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    The problem with that idea is there would be so much extra current coming out of the Vfr stator that the sh775 probably wouldn't be able to keep up at high revs and either go open circuit or burn up. That's the problem I had with my last series rr, the compufire rr, would let go at 10,000 RPMs and the voltage would spike to 17 volts.
    #82
  3. Allyance
    Allyance Insider
    The amount of current the stator puts out is determined by the load (resistance) of the bikes entire system. The lower the load, the less current. The stator generates voltage (potential), the higher the RPM, the more voltage is generated. The R/R job is to regulate the voltage and produce DC as required by the load. The series R/R only pass the current required, whereas the OEM R/R's shunt the current to ground, as the RPM and voltage increases, so does the amount of current. E=IR. the bikes load remains constant, therefore, as 'E' (voltage) increases, so does 'I' (current). This is why the stator wires and connectors get so hot. Don't know why your series unit failed, maybe load was to great for the unit. I went with the series to reduce the amount of current being shunted due to decreased load from the stock design as recommended by Jack @ roadstercycle. He is totally aware of the situation when racers disconnect all their lights and unbalance the system.
    #83
  4. H3nry
    H3nry New Member
    Pflugerville, TX
    Rather than current, there is another limit, how quickly the FET or SCR or whatever the switching device is can be turned off. It has to respond in a fraction of a revolution of the engine. The Compufire is designed for a Harley with a redline of under 6,000 RPM and has some margin extra, but not enough margin for 10,000 RPM. Above the maximum switching speed, the regulator can't turn off fast enough to keep the voltage down. Shindengen builds for all the Japanese bikes and presumably designs for faster spinning engines. I hope the SH775 is the first of a series of series R/Rs, and there will be a heavier duty one soon. There is no reason a series regulator is more complex or expensive than a shunt regulator.
    #84
  5. Allyance
    Allyance Insider
    Both are the same price on roadstercycle.com
    #85
  6. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    Whelp we spun the zx6r ninja up past 12,000 a few times and the voltage never spiked, but I just didn't like all the heat.
    #86
  7. H3nry
    H3nry New Member
    Pflugerville, TX
    OK, today I installed the MOSFET R/R. It is not a Shindengen part. Mfr unknown, but "Made in China". That's why it's under $30. It's claimed to be an improved circuit which turns off when too hot and restarts after cooling down. Claims to handle 30 amps continuous, 50 amp surges. I copied CandyRed's mounting on the passenger peg bracket. Tres cool.
    http://www.ebay.com/itm/Mosfet-Volt...Parts_Accessories&vxp=mtr&hash=item4d206f52cc
    It works. It runs much cooler than the Honda OEM part, and it holds a stable 13.9 V at 2,000 to 12,000 RPM. About 12.4 V at idle. Considering that it's 100 F ambient today, and the battery is close to 200 F when riding, 14 V (2.33 V per cell) is about as high as you can charge a battery without boiling the acid.
    http://batteryuniversity.com/learn/article/charging_the_lead_acid_battery
    I installed it with new gold plated crimped and soldered connectors so it can be replaced with the original part in case of trouble. The regulator runs warm to touch, but not scorching hot like the OEM part. The yellow wires are warm, but no warmer than they were before. The connectors are no warmer than the wires attached to them. So everything looks OK - the remaining question is reliability / longevity. I am pretty sure this is a shunt type rather than series. I'll keep an eye on it and report how it goes.
    #87
  8. carlgustav
    carlgustav New Member
    Heart of Dixie
    So I'm looking at doing this R/R upgrade before I loose my stock unit (~26K miles on bike). I'd really like to get an FH019 instead of the FH020 ... 50A max vs 35A and same size, but can't find a supplier that provides 1 unit vs 10 ... anyone know of a source?
    ACE
    #88
  9. fcc
    fcc New Member
    if the wires are the problem of being too thin, maybe cutting the wiring from the r/r and stator would be a good idea and replace them with a thicker wire?
    #89
  10. skimad4x4
    France
    French Alps & London
    Hmm indeed that was essentially what the original VFRNess loom was designed to do BUT sadly it did not really deal with the problem - just moved it elsewhere. In reality the loom is adequate for normal current flows - the problem arises when components (mostly the RR) fail resulting in abnormal current flows, melted wires and connectors.
    Inherently all 4 elements of the charging system (RR, Stator, battery and loom) need to be in good order and a fault in one can damage some or all of the others. Sadly the electrics are pretty much the only significant part of your motorbike not made by Honda - they are bought in from an outside supplier and I suspect that for a while Mr H was not really unhappy to see the endless charging system issues which affected so many makes and models of motorbikes of similar vintage.
    Think of it this way. If the system fails within warranty their dealers will happily repair/replace stuff and behind the scenes the costs will be claimed back from the original supplier. If it fails after the manufacturers warranty is expired the bill falls to the owner, meanwhile the dealership will enjoy a continuing demand for replacement charging system parts and repairs. After endless complaints Honda finally realised this was actually damaging their reputation and loosing them sales, so they upped the budget to secure better quality bought in charging system components and importantly installed more reliable Shindengen RRs on 7th and 8th Gen models, which thus far seem to have largely avoided the gremlins affecting earlier models.
    Indeed a while back, there were a few posts on here reporting that an 8th Gen RR had been successfully retrofitted into an earlier VFRs so that would be where I would be spending my money. The OEM stator is reasonably resilient provided it is not being fried alive by a faulty RR.
    More often than not damage to the stator, battery and loom are simply collateral damage caused by a failing RR, however they may not be spotted at the same time.
    Sadly people tend to stop looking once they identify a faulty charging system component not realising that depending on which diodes fail within an RR, it could short out the stator, or could feed 60+ volts into a system designed to handle a nominal 12 volts blowing bulbs etc, or worse still fry critical electrics if the rectifier fails and starts to feed AC into the bike main loom. All these are bad things.
    That is why it is so important to do the charging system checks(the drill) twice once with the bike cold and once with it hot - because a stator may test out fine whilst cold, but the very fine insulation on the windings can degrade with heat and potentially fail over time especially when hot and allow winding phases to short out and instead of charging the battery that can quickly kill your battery.
    These problems are not unique to Honda, I had very similar issues on my Triumph Street Triple (also built using bought in components) but after they replaced the RR under warranty, I had the good sense to immediately run the drill tests which tested fine while the bike was cold, but when hot revealed that the RR failure had also damaged the stator, so I took it straight back to the dealer to replace that under warranty too.
    Hmm - that is way too long a post so I think The Macallans is calling - I am not sure that helps.
    SkiMad
    #90
    squirrelman and Thumbs like this.
  11. skimad4x4
    France
    So what's going on Reggie - I am now in Italy ??? I am in Aylesbury UK - an hour north of London.
    SkiMad
    #91
  12. Grum
    Grum New Member
    Hi SkiMad. Is there any chance you could provide a link to this. I've never heard of fitting an 8gen R/R to any earlier VFR. That would be quite a tricky modification.
    #92
  13. Thumbs
    Thumbs Member
    Bath(ish)
    My exact thoughts on the 8th, but the 7th is a 50amp 5pin, so I bought one to try it on my 2nd, looks like a straight swap with allowance for extra space
    #93
  14. kennybobby
    kennybobby New Member
    A sliding electrical contact will eventually fail and should be avoided if possible.
    The stator produces a 3-phase alternating voltage and current that travels to the rectifier in the 3 yellow wires. If one of the legs of the 3-phase AC circuit is opened up for some reason, the current will arc thru whatever path it can create to find a return path back to the stator. The crimp terminals are tin-coated copper which lose their spring temper when heated. The loss of spring tension allows the contact sliding surface to progressively open due to vibration and arc-erosion. Once the arcing starts then it feeds on itself--heats up and loosens the contact, which creates more arcing, more heating, higher resistance in the contact, etc.
    here's one that i caught and if you zoom in on the contacts you can see the erosion traces in the blade due to the arcing at the terminal. The heat damage is greatest at the terminals and progresses up the wiring harness. If the heat gets high enough it will melt the yellow wires and the green wire that is bundled with it in the harness. The loss of the green wire opens up the ground side of the main 12 volt battery bus, and there is no telling where the arcing will occur as the bus currents are trying to find a path to ground.
    And that rectumfier was still good and working properly--the sliding contacts were the root cause and culprit.
    #94
    Thumbs and squirrelman like this.
  15. Hingley
    Hingley New Member
    I have been reading this thread with great interest as I am very week when it comes to electrical and I know the VFR's
    charging system is it's Achilles heel.
    A couple of weeks ago before I put the girls to bed in the winter play house I warmed up the new 1999 for a winter oil change and was surprised to find the stator wires at the connector were getting really warm ( if not hot ) . I did not expect this as I checked the charging voltage at the battery earlier and it was above 13.5v.
    I pulled the connectors apart and this is what the pins looked like, if I was to guess I would say the pins are discolored due to heat
    Would I be correct in thinking this?
    Can the connectors can cleaned up and useable or is it time to consider a regulator/stator wire upgrade?
    #95
  16. Thumbs
    Thumbs Member
    Bath(ish)
    Those connectors look like they’d clean up no problem and then see if they get hot
    #96
  17. Hingley
    Hingley New Member
    Well it is a hell of a cold day here so instead of freezing outside I checked out the stator and regulator on the 99VFR800.
    Looks like they both check out and all I have to do for now is clean up the connector plug pins and see if the wires still feel warm/hot to the touch when running.
    While I was at it I checked my spares for a Shindengen Mosfet FH020AA
    I thought sure I had bought one years ago out of a salvage yard, but to my surprise the one I have is marked as a FH020BA
    Are they the same unit or have different specs?
    They match exactly the same otherwise, same Shindengen brand marking on end, same casting ribs and tabs, same number of fins , same SS backing plate etc
    What do you guys think?
    #97
  18. raYzerman
    raYzerman Member
    Millgrove, ON
    IMHO the stator wires will always be warm and the regulator is there to shunt the excess to ground.... so always under load so to speak.......
    The previous model to the FH020 was the FH012.... I'd use the BA, no issue there. Vast improvement over the OEM.
    #98
  19. proper
    proper New Member
    Tucson, AZ
    WireMyBike, Joshua, “I am sorry but due to a fire in my shop I am no longer producing the VFRness at this time. I don't know for sure if/when I will resume production as most of my tools and supplies were lost in the fire.
    The biggest issue the VFR has is piss poor grounding. If you add additional ground wires from the R/R to the frame it should help.
    Most of the wiring, if damaged, can be replaced with off the shelf products, including the Main Fuse B holder.”
    #99
