Milky looking stuff in the sight glass
Discussion in 'Mechanics Garage' started by FalseFiction1, Mar 5, 2010.
  1. steven113
    steven113 New Member
    Pensacola FL
    Change the oil and filter and run it up to temp again without load. Inspect oil condition( If clear you are most likely fine) If cloudy reapeat one more time and hope for the best.
  2. donald branscom
    donald branscom New Member
    Guerneville CA
    Very common.
    Milky white or coffee color is from condensation.
    Certain times of the year when you have warm days and cold nights.
    You see it more in desert areas especially.
  3. FalseFiction1
    FalseFiction1 New Member
    Goode, VA
    Problem solved. Changed the oil and filter with some cheaper stuff, ran it for a bit, everything looked good, changed the oil with the good stuff.
    Thanks everybody for your help
  4. betarace
    betarace New Member
    Middleburg, VA
    so it was Bubba Zanetti's semen then, I knew it. same thing happened to my bike after he "rode" it
  5. Badbilly
    I sure hope nobody starts asking for free samples.
  6. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    I've only had sex with betaraces bike. I wanted a hot Italian babe; so the 999 fit the bill.
    OP's bike has not been sexually assaulted by me.
    BZ
  7. betarace
    betarace New Member
    Middleburg, VA
    next time wear a condom - or at least use the tail pipe. Now I have a garage full of 1/2 italian 1/2 man things
  8. Bubba Zanetti
    Delaware
    Good! You need 1/2 man things around you beta ;-)
  9. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    You guys are sick and twisted. It almost makes me feel normal. I think.
  10. donald branscom
    Guerneville CA
    Normal. ....Normal is when you have just enough going on that you are not bored and depressed, and not so much going on that you have anxiety.
    Twisted ....Twisted is ok. BENT is another thing!!! Hahhahhahaha
  11. kingsley
    kingsley New Member
    Osoyoos, B.C. Canada
    I saw some worrying looking swirls in my sight glass early this year. Fresh oil run only a little to circulate at the end of last season. Took it for a good ride and everthing looks fine. With your mileage, I doubt it's a head gasket.
