Mission VF 750F 2012 Restore
Discussion in '1st & 2nd Generation 1983-1989' started by rainman6, Jan 14, 2012.
  1. rainman6
    rainman6 New Member
    NZ
    Progress
    got a bargin on trade Me (NZs Ebay). I box with VF750F written on it someone found cleaning out their shed. They couldnt tell me what was in it, I got it for $10. It was like a Christmas present when it arrived. New oil filter, cam cover gaskets, lots of different size jets and needles, and lots of other little bits and bobs.
    Painted the frame with many coats of Epoxy Enamal
    Painted the old red & primered front gaurd and under belly - Gloss white with Epoxy Enamel, they are only temporary until I find original white ones in good condition on my side of the world.
    Opened the sump up to clean the oil pump gauze filter, and just as well I did, it was soooo dirty, almost completely blocked with old residual silicon off somebody getting carried away with gasket sealer. I also found these two items in the sump. I think they must be off the Cam tensioners/guide. from what I can see they are all complete, any other suggestions of where they could be from would be appreciated!
    The manual says to check the pressure relief valve but doent say how to do this...so I diddnt. How likely is this to fail and if I really should be checking can someone please tell me how?
    Last but not least my new body parts are travelling to this side of the world - Thanks to Dutchwurx!!
  2. hopit88
    hopit88 New Member
    Now that's my kind of package. I'd be thrilled to open that and I don't even have a 750! Can't wait to see them on.
  3. invisible cities
    invisible cities New Member
    new york
    Well done!
  4. rainman6
    rainman6 New Member
    NZ
    Monthly update.
    So this month I got the frame / swingarm reassembled, swingarm bearings already had fresh grease and were very new looking so PO must have done this. (thats about all they did LOL)!
    Stripped, cleaned out grey sludge from forks. Painted the outsides and baked them in the BBQ - thins prevents 1. hot paint smell in house 2. Strange looks and noise from her indoors!!
    Replaced seals and reassembled filled with new 10wt fluid....found left over seal support washer - Damn I knew I rushed it. Following night drained and re-stripped fork....the wrong one. AAAAARRRHHH. Never mind they are all done now and back on bike.
    Got the new 4-1 fitted and centre stand still works fine so that's a bonus!
    New / second hand Remus carbon fiber muffler is looking like its gonna work out. Will joining to the 4-1 system with a V clamp system.
    Received my James Daugherty modified CBR shock this week and got it bolted in. (Thanks JD it is a nice bit of kit - glad I didn't fab one up my self, I can see a bit of homework had gone into your design.)
    Have to suss out where to bolt the Pressure canister.
    Now I'm onto re-kitting master brake cylinders and maybe canisters, re-kitting carbs and finding replacements for all the perished rubber mounting bits. Also Iv'e gotta realign the front fairing frame. Diddnt notice how badly bent it was until Iv'e gone to strip and paint it.
  5. Pops
    Pops New Member
    Stephenson, VA
    That's beginning to look more like a proper motorcycle now, Rainman! I guess I'd better get my butt in gear to get caught up to where you are in your "reanimation." I especially like your exhaust - really unique for a gen 1 bike! Lookin' good...keep the updates coming!
  6. rainman6
    rainman6 New Member
    NZ
    Thanks Pops, I'm undecided if the exhaust is a good thing or not. Diddnt have much choice as I didn't want to ship a collector and mufflers from the States due to cost. Glad you like it that's a good sign. I'm gonna wait until the body work is on before I finalise how long to have it and at what angle.
    Good luck with your Gen 1, my progress will probably slow down now so don't panic!!
  7. rainman6
    rainman6 New Member
    NZ
    Some Photos
    Heres some progress photos.
  8. Apittslife
    Apittslife New Member
    Clarksville, Indiana
    Lookin Good! :thumbsup:
    From the Pics, Just a couple O-Bits & Pieces, & you can be riding.
  9. hopit88
    hopit88 New Member
    Love it. Looks good and should sound even better!
  10. rainman6
    rainman6 New Member
    NZ
    Cam Chain Slipping!!!!!
    :eek: Bike was running well, then next time I ran it was back firing badly and I thought the carbs were probably fouling up after relining the tank etc. But no.... I stalled the bike and then it wouldnt turn over. It turns out the cam chains are so stretched that jumps teeth. Not good. To add salt to the wound it appears the oil mod I made was too restrictive and the cams have had a melt down. I wish I had left the motor as is and just kept an eye on it for wear and tear. Now I need a good new motor which are not easily found over here and sumer has arrived. :Cry:
  11. jeremyr62
    jeremyr62 New Member
    Ireland
    Limerick, Ireland
    Look on the bright side. You have a perfectly good bike apart from toasted top ends. There still seems to be plenty of VF750's floating around. It isn't that rare a bike after all. You'll find an engine I'm sure.
  12. hopit88
    hopit88 New Member
    That totally blows. Sorry to hear that.
  13. Apittslife
    Damb, That blows! :hurt:
    Hopefully someone in the community will have an extra motor or upper end laying around, that they need to get out of their way.
  14. reg71
    Sikeston, MO
    Ouch, after all that work. That blows. Good luck...
  15. rainman6
    rainman6 New Member
    NZ
    Thanks for all the sympathy guys:smile: In the last 12 months while doing up this bike I have only seen a couple of VFs for sale and only one that is being parted. I will put her aside and bid my time until I find enthusiasm and a motor with a good top end. I may have to go out and buy a newer vfr to get riding over the summer!
  16. Apittslife
    Actually I think rainman has made his ole-Girl so damb Pretty, he's afraid to ride her, So he has come up with an excuse so as to buy a newer bike to beat on! :tongue:
  17. rainman6
    rainman6 New Member
    NZ
    Damn it Apittslife your cutting comment was too close to the bone...but it worked I got motivated and gotta motor with shiny cams. I fitted it this week and went for a proper test ride today!!
    CHECK IT OUT!!
    :chaingun: photo (3).jpg
    I am so relieved to have the old girl mobile. Got a few tidy up jobs left but the main job is to get her relicenced for the road! Have ordered a filter type top end oiling kit this time and will fit that at a later date if I see any signs of wear.
    Thanks for the encouraging comments guys it all helps!
    :chaingun: Ye Ha!!!!!!
  18. hopit88
    hopit88 New Member
    :thumb::thumb::thumb::thumb::thumb:
  19. Salvo
    Salvo New Member
    Mesa,Az
    Just read this thread for the first time... Very nice project and very nice work! Glad to see it all worked out in the end! Gotta keep 'em on the road! :)
