More Carb Help Needed
Discussion in '1st & 2nd Generation 1983-1989' started by Calflash, Oct 10, 2009.
  1. Calflash
    Calflash New Member
    How do you get the "manifold" off the carbs on an '87 700. I want to sync the carbs and it looks like the adjusters are under the "manifold". Yes, I did remove the screws in the "manifold".
  2. Jons03
    Jons03 New Member
    Eureka, CA
    If its anything like an 86 then just keep tapping around the whole thing until it loosens up and lifts off.
  3. TOE CUTTER
  4. TOE CUTTER
    Pm
    PM me and I will give you my phone number if needed.:thumbsup:
  5. Jons03
    Jons03 New Member
    Eureka, CA
    Oh dang. Too late for me....uh oh
  6. squirrelman
    Like TOE said, you're in deep do-do if you remove airbox bottom from carbs! Don't attempt ANY operation unless you read and study the Honda service manual first.
    THE only way to properly synch carbs is with engine running and by accessing screws from bottom between the V
    "1963-1975 antiwar activist"
  7. Jons03
    Jons03 New Member
    Eureka, CA
    Is it not possible to install that cover again or what? Seems like the pins will just line up and pop right back on...with some massaging of course.
  8. Calflash
    Calflash New Member
    I will not for the love of god remove the manifold and wade in deep dodo. This is my first time working on a VFR, I have a lot to learn and this is the place to learn.
  9. squirrelman
    Once the airbox is removed from carbs they can wiggle around and loosen O-rings sealing fuel lines, and any of several springs could pop out.
  10. Jons03
    Jons03 New Member
    Eureka, CA
    Ahh, ok. So I might not be in it too bad if all I did is remove it and not touch anything else? I can just go put it back on and be OK...lol...hopefully
  11. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    You sych the carbs with everything in place - nothing at all should be disassembled. It requires a 90° screwdriver to adjust the sych screws. It's not the easiest thing to do, luckily it doesn't need done very often!
