motor oil
Discussion in 'Mechanics Garage' started by machinist 65, Jan 17, 2020.
  1. machinist 65
    machinist 65 New Member
    can I go to the auto parts store and get any 10w 40 oil or does it have to be motorcycle oil is there any diffrence
  2. bk94si
    bk94si Insider
    Don't use car oil. Bad for the clutch but you can use Rotella T6 or something like it for diesel engines if you want to save a little money.
  3. machinist 65
    ok thanks just wanted to know if there was any difference between oil
  4. bk94si
    bk94si Insider
    Yes. Car oil has friction inhibiters that will eventually make your clutch slip. So yes, there is a difference and why I said not to use it.
  5. James Bond
    James Bond Member
    Dixie
    I absolutely love oil threads. Never heard of a VFR engine worn out due to using the recommended oil, dino or synthetic changed as recommended. Ride the bike.
  6. GreginDenver
    GreginDenver New Member
    Denver, Colorado
    Truth.
    And within the VFR model lineup this is especially true of the VFR800 engine due to its cylinder sleeves (which are hot-worked, ultra-high-pressure extruded, Powder Metal Composite composed of a mixture of high-silicon Iron, Copper, Magnesium, Aluminum, and semicrystalline Carbon.)
