My 1986 VF500F revival
Discussion in '1st & 2nd Generation 1983-1989' started by jstehman, Feb 2, 2021.
    Yes, the cables are still kinda a bitch. Maximizing the free play on the throttle cable helps a lot just getting the cables on. Then take out a bit for later if needed.
    You could certainly do it that way, but checking for action with the throttle is nice, with the ability to still make changes on the carb end.
    jstehman likes this.
  2. jstehman
    jstehman New Member
    Is it safe to use a coolant/radiator flush chemical before I change the orings?
    Sent from my SM-S911U using Tapatalk
    Was it particularly nasty? Anyway, should be ok if you want to.
    I tend to try and be the least aggressive I can. I will use a garden hose on one of the coolant hoses to push out and flush. Then fill the system with distilled water for the first run or two, perhaps draining and repeating. Then draining and filling with the proper coolant mix. Yes, there is still some water in the block, but it is now distilled and won't dilute your new coolant drastically. I have also wrapped the compressor nozzle with a rag and blown out remaining water too.
    RogueRC24 likes this.
  4. jstehman
    jstehman New Member
    Yeah the first drain and fill when I got the bike was pretty bad.
    This time, when I pulled the rad to get at the front plugs, I got a little more sediment. Not a Lot Lot, but some
    I've been on the fence about using the chemical.. leaning more toward doing like you say run the hose from top to bottom and refill with distilled/AF 50/50
    Captain 80s likes this.
  5. Totaled TL
    Totaled TL New Member
    Louisville, KY
    That is how I last did it. I think it's easier.
  6. RogueRC24
    My process
    I always do the radiator separate from the bike and sonic bath it as well. Sonic bath the water pump and cross over tube hardware. Replace all o-rings on reinstall.
    1 x garden hose - drain
    2 x distilled only - drain
    1 x Water Wetter/ distilled - keep
    3 x eval water content and level after test runs or rides. Flush again if necessary.
    Most of the time my Samco's have one leak on a random fitting. I have never had complete seal first time after rebuild with heat cycles. :(
    I put it down to most of the bikes have heavy corrosion on the hard parts where the old hoses connected.
    Just replaced cables on the NSR. F me that carb return spring is heavy duty.
    Hickory smoked chicken for street tacos this last weekend. mmmmmmmmm
  7. Totaled TL
    Louisville, KY
    Took mine to a rad. shop. $50 bucks; they said it was pretty funky. I think it was worth it in time alone.
    RogueRC24 and sixdog like this.
  8. jstehman
    jstehman New Member
    I had the rad at a shop because the original had a leak in the center.
    Found a decent used one but the upper inlet angle was different.. probably from a magna
    Anyway the shop guy swapped the inlets for me, cleaned the rad and even painted it.
    Whatever crap is in the system, was probably sitting at the bottom of the water pump waiting to be freed
    RogueRC24, Totaled TL and sixdog like this.
  9. sixdog
    sixdog Insider
    How’s the cap ?
  10. jstehman
    jstehman New Member
    Needs changed. Thank you for the reminder
  11. Totaled TL
    Louisville, KY
    They pressure checked it & painted mine also.
    RogueRC24 and jstehman like this.
  12. RogueRC24
  13. jstehman
    jstehman New Member
    Removed the bar today to drill the hole to accept the newer VFR start stop pod.
    Looks like it is supposed to be there
    Need to remove the carbs and do the orings on the coolant tubes still.
    Id like to change the terminals on the power wires at the key switch connector.. still getting warm..
    but since I have no idea what I am looking at I am guessing the locking tab kind in the 6.3 or 6.2mm flavor? Looking at cycle terminal.com.
    Bazza and Jim McCulloch like this.
  14. jstehman
    jstehman New Member
    Antifreeze drained.
    I started taking the hoses off of the thermostat housing and remembered that they didn't fit too well, like the hoses were way to big.
    Yeah they are the right size. I had another tstat house that had engine side nipples that were 4-5mm wider that fit the hoses properly.
    Anyway I cleaned out the housing tstat and hoses because there was still some brown gunk in there. Flushed some distilled water down the rad neck and out the water pump. Pretty nasty
    Filled up with antifreeze and ran a few cycles to burp the air
    Pull throttle cable is kinked and frayed
    New onw on the way probably get here next week then I can MAYBE get the fuel tank back on.
    Oh and I gotta grab some vent hose to go from the crank catch tank to the airbox because I've got the 85 carbs so the nipple is at the front on the lid instead of the back under in the plenum. Or just cap the lid and drill the plenum there is a boss there where the vent should attach but it's filled
    Bazza likes this.
  15. jstehman
    jstehman New Member
    Still here. Still working with the 500..
    I went on a ride today although it's getting super hot and muggy .
    Bike still handles well for being saggy assed with that blown shock. And still pretty sure one of the front forks is bent
    Also still need to install.those new clutch plates
    Runs amazing shifts amazing.. too bad I always feel like I'm riding a time bomb or I'd take this everywhere. Actually pretty comfortable being a "small" bike.
    Front brakes need attention. pads and new lines on my wish list
    Patiently awaiting an upgrade package from biketyrresuk...
    Colddevil and Bazza like this.
  16. Bazza
    Bazza Member
    New Smyrna Beach, Florida
    Good to hear the update, Jim. Hot and muggy here as well. I have a lot of things I want to do but it's slow going right now. Hopefully I will have a climate controlled service bay set up by next summer.
    These little 500's are a BLAST, for sure!
    I need to climb back onto mine this coming week.
    Good luck getting the parts you need, look forward to future updates - best wishes!
  17. jstehman
    jstehman New Member
    I'm already eyeballing a set of used forks on eBay.
    Or my work buddy suggested a hydraulic repair shop that could straighten the tube if it isn't bad
    Yeah I always telll myself in winter man I'm gonna get so much done once it gets a little warmer. Then riding season hits and I'm like well it's too damn hot to be wrenching now lol.
    Totaled TL and Bazza like this.
    If it's just slightly bent without a crease, it can be straightened.
    I've done it many times on my press with some wood V-blocks, checking straightness on my wheel balancer.
    Bazza, jstehman and Totaled TL like this.
  19. jstehman
    jstehman New Member
    Looks like the package was here for delivery..
    But I was out doing errands and it needed signature
    Tomorrow
  20. Bazza
    Bazza Member
    That signature stuff drives me crazy.....
    Luckily for USPS deliveries, my carrier will sign it for me. The last one he did for me was the fuel pumps I bought from a UK seller.
