My 1986 VF500F revival
Discussion in '1st & 2nd Generation 1983-1989' started by jstehman, Feb 2, 2021.
  1. RogueRC24
    noice!!
    #81
  2. jstehman
    jstehman New Member
    I tried getting the 85 tank installed today, but I'm having an issue with the petcock.
    I don't have the Actual screen that goes up into the tank, I have a repro piece. And when I install the petcock with the screen attached, if you so much as look at it wrong, the screen comes off. And I'd rather not have it lost inside the tank so I'll just go without it for now
    So now I am going to try and find an oring that will fit the petcock oring indentation. The one I got from Honda is slightly smaller than the opening, but is perfect when it's on the screen, as it has something on the inside to keep it taut.
    Probably a 1.5x10.5 or something close. Got a hydraulic supply pretty close so hopefully I can find something that will work.
    Sent from my SM-N950U using Tapatalk
    #82
  3. jstehman
    jstehman New Member
    I also tried getting the carb heat shield installed but ran into an issue.
    Either the heat shield is bent, the frame tabs are bent, or I have the wrong shield. I believe it is the 84/85 shield and I'm running the 85 carbs, but with an 86 engine and frame.
    Currently, if installed the heat shield would rest on top of the fan motor. No bueno
    And the holes in the rubber are obviously for the throttle cables and the idle stop screw, but the angle is totally wrong.
    Do the frame tabs look correct or bent upwards?[​IMG]
    #83
  4. jstehman
    jstehman New Member
    Got the 85 tank installed and lines hooked up today.
    Also decided to try another clutch line to see if there was any change with the odd lever feel. No dice
    No matter how much I bleed the master, there are bubbles coming from the return port.
    I disassembled the master cylinder again to inspect the bore. Looks like shit with pitting in one area.
    Guessing the pitting is not making a good seal, making the lever bite point slightly random.
    Also found a pic of a naked frame on eBay and lo and behold, those tabs that hold the heat shield are supposed to be horizontal
    Guess whoever the moron that tried to seat the carbs before me used the prybar right there
    Oh well, easily fixed and the shield is installed.
    One step forward, two steps back [​IMG]
    #84
  5. jstehman
    jstehman New Member
    #85
  6. jstehman
    jstehman New Member
    No wonder the fairing and gauges were crooked to one side.
    And she runs gooooood sweet little engine
    Feels good to have all the plastics back on. They don't really match to the year, but they are there. Even the chin fairing [​IMG]
    Sent from my SM-S911U using Tapatalk
    #86
    Jim McCulloch and RogueRC24 like this.
  7. jstehman
    jstehman New Member
    Got her up on the triple stand today.
    Pin size is the same as the 6th Gen so
    Got the front wheel off to have new rubber mounted. Sweet baby Jaysus! A 2 piece front axle?!
    Noticed one of the caliper bolts is a custom with a few washers, will probably order one of those as well as rubber gaskets for the valve cover bolts, they are weeping a bit.
    I can't get the rear wheel off with the front.. not sure what's going on, the shock is blown? But the rear wheel hangs pretty low. Even on the center stand I have to put her on a plank so it's high enough to spin.
    So 2 trips for tire change.
    #87
  8. jstehman
    jstehman New Member
    Pervious owner had a 130/80 on the rear! I just noticed that when I was looking for the date code
    #88
  9. Totaled TL
    Totaled TL New Member
    Louisville, KY
    6 mo. + break?
    Triple stand?
    What is 'I can't get the rear wheel off with the front.'
    #89
  10. jstehman
    jstehman New Member
    Triple stand = head lift so I can remove the front wheel
    If I have the triple stand up, I can't take off the rear wheel because the angle pushes the rear wheel to the ground
    I took a break because my garage is unheated and the winters here get below freezing
    I'm not holding a metal ratchet on metal fasteners in freezing temps lol. Too old for that shit
    Plus I have a daily already this is just a side project
    #90
    Bazza and Jim McCulloch like this.
  11. bmart
    bmart Member
    Charlotte, NC
    I have to pull the rear first on a bunch of my bikes. Normal-ish.
    #91
    I know I'm spoiled with my setup, but every time I read a sentence like this my brain has a hard time processing it.
    #92
  13. Colddevil
    Colddevil Member
    Wisconsin
    The two piece front axle and the multi-piece axle clamps are my least favorite part of the whole bike.
    Regarding the rear wheel lift--my rear stand barely gets the wheel off the ground. Not quite an inch.
    #93
    jstehman likes this.
    You can always convert to your 86 VFR fork lowers. Both are 37mm.
    #94
  15. Colddevil
    Colddevil Member
    Wisconsin
    Hmm, certainly something to consider. I assume that would require swapping to the VFR front wheel as well? I think I'm content to stay with how I've got it currently after putting the time and money into getting the racetech emulators setup. It's just the alignment part that I find tricky compared to pushing through a solid axle, tighten axle nut, tighten pinch bolt, done.
    #95
  16. jstehman
    jstehman New Member
    I know I'm not in any real hurry to get her going. But now we have some warmer days and I can get things done without freezing fingers.
    The front wheel wasn't terribly difficult.. it was more just figuring it out.
    Second time will be much faster. The hardest bolt to undo was the horn bracket
    #96
    Bazza likes this.
  17. jstehman
    jstehman New Member
    Looking back, I suppose I could have removed the rear wheel first, then the front and shed be up on the triple stand and the center stand.. but I got a weird feeling about the center stand anyway. The bike teeters forward and back a little more than I'd like.
    #97
    Your Emulators stay exactly where they are now. You would have to change the bearings in the VF wheel to 20mm. Think you would need VFR brakes tho.
    I know I say this shit like, "why don't you just..", but I have so many parts kicking around here that I forget it's just not that easy.
    The next (last) VF500F I build is getting the VFR forks.
    #98
  19. RogueRC24
    "I took a break because my garage is unheated and the winters here get below freezing"
    I know how you feel jstehman, it was a brisk 71* in my open garage yesterday. Had to go for shorts and T-shirt. :Smow:
    #99
    Bazza likes this.
  20. jstehman
    jstehman New Member
    Got the new one piece clutch line installed.
    Looks good, feels good bleeding took all of 3 minutes
    Gotta go shopping for that YSS rear shock now.
    Sorry no pics. Tapatalk doesn't like phones apparently
    Captain 80s and Bazza like this.
