My bike creeps when im not moving in first HELP!!
Discussion in 'Mechanics Garage' started by vf750fer, Jun 13, 2012.
  1. orion3814
    orion3814 New Member
    fayetteville, ar
    Are ya sure its not reading mph Lololol. Jkjk hahaha
    I would check the other things first b4 carbs cleaner could b plugs. Could be Tue lid on the airbox loose or air filter plugged if you lift the tank the air box is under if you can start it with the carbs exposed and full throttle it a few times and see if the slides all lift if they do chances are they are ok. Also if I remember right there may be velocity stacks on the carbs its been a few years since I have cleaned my airfilter on mine so I can't quiet remember. Some one will correct me if I'm wrong. But yeah ii would check all the easy things first then dump some carb cleaner in the tank and see if that helps
  2. vf750fer
    vf750fer New Member
    Haha no it would be off more then 10...
  3. squirrelman
    On an old bike with running problems, always drain the fuel tank completely and inspect the interior for rust or debris, cuz cleaning carbs won't help if rust gets back in from the tank. There are several commercial sealants for fixing rusty fuel tanks.
  4. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Its a little know rule here on VFR World that you need to have at least 15 posts before you talk about any venereal diseases or related that you may have contracted. This way we know you're serious and not just some cheap whore looking for attention.
  5. orion3814
    fayetteville, ar
    Lol. Now that's funny
