My danmoto jisu exhaust for my 98 VFR
Discussion in '5th Generation 1998-2001' started by RocketJohn, Aug 26, 2011.
  1. Floydy
    Floydy New Member
    Cambridgeshire
    ...Noise is quite loud
    Hi
    I recently fitted a Danmoto JISU to my 5th Gen FIX
    My observations:
    Strap / Hanger for the silencer is fiddly to fit and the rubber is quite thin in construction and looks as though it will burn up in a short period. I had trouble getting it to lay flat and stay put around the hanger
    The supplied link pipe diameter was too large at the junction of the exhaust collector. Fitting a new gasket for the standard exhaust goes a long way towards resolving this issue but the fit was not quite tight enough (there did not appear to be any leak though).
    The whole assembly was a bit too loose for liking and moved about easily. Probably can be resolved given enough time and patience.
    At Idle, the exhaust sound is very deep and compared to other exhausts I have used, it is immediately apparent that this exhaust is going to be loud. Once underway, my concern over the volume of the silencer was confirmed. Way louder than I expected even with the baffle or 3rd party DB killer fitted.
    You will definitely be noticed on the road with this slip on fitted
    For me it was too loud and I am accustomed to running a 'full-power' open pipe on my 5th Gen
    I switched back to a street legal Motad for sanity...
    Pros:
    • Looks great, like it was designed for the 5th Gen from the outset
    • NOT marked 'Off Road or Race Use only
    • Price
    Cons:
    • Potential fitting issues due to flimsy hanger and supplied link pipe / clamps being a touch too small
    • Very noisy. Barely quieter than when no silencer is fitted!!!
    • Optional Baffle does not make a great deal of difference
  2. Rainbow7
    Rainbow7 New Member
    Muslim-free Queensland
    So I'm the only one who thinks the DanMoto stuff looks cheap and nasty, and sounds like a fart in a mason jar?
  3. ridervfr
    Cool videos, what state do you live in NM?
    I dont think it sounds like a fart in a jelly jar either...
  4. Bowidog
    Bowidog New Member
    I want one!
