My RC24 resurrection
Discussion in '1st & 2nd Generation 1983-1989' started by Wheezy, Sep 24, 2021.
  1. Wheezy
    Wheezy New Member
    I’ve installed a new fuel pump and it keeps blowing the 10A ignition fuse. I’ve tried chafing the polarity on the wires on the pump and the same thing happens. Can’t figure out where I have a short. Any ideas and checks I could do? I assume it’s something to do with the fuel cut relay?
  2. Wheezy
    Wheezy New Member
    Have confirmed continuity between fuse and fuel cut relay / fuel cut relay and fuel pump / fuel pump and frame ground.
    Managed to blow another fuse with the fuel pump relay removed so assume it’s not that, but cannot see where else the problem will be.
  3. RogueRC24
    ehhh wiring, not my strong point. Maybe you have a cut in your wire loom that is grounding out between the fuel pump and fuse? Someone smarter help out Wheezy. :)
  4. Thumbs
    Thumbs Member
    Bath(ish)
    What do you get when you measure the voltage from the loom side of the fuse to earth with no fuse in?
    It should be zero
    Wheezy likes this.
  5. squirrelman
    chinese pump ? :eek: wouldn't be too unusual to find BFF (Bad From the Factory).
    measure resistance across pump wires and report. also, unplug pump to see i f fuse blows with no pump in circuit.
    Wheezy and Thumbs like this.
  6. Wheezy
    Wheezy New Member
    Right, a couple of weeks off on holiday in the north of England, so not much doing on the VFR. Back on it now.
    Firstly, the fuel pump. Yes, lesson learnt re. Buying cheap stuff from fleabay. The new pump was the cause of the 10A fuse blowing. I checked everything else. All continuity on all the connections was correct. Opened up the replacement pump and the points would not move and I just thought ‘what else is wrong, that I can’t see?’ So I’ve written that £35 off and I’ve emailed Quantum pumps to see what they think might be suitable.
    In the meantime, I’ve started work on the rear end and yesterday turned into a dismantling day. Firstly, the rear brake hydraulic assembly came out. Yes, the pistons are completely siezed and the hydraulic actuator looks knackered too. Then the rear wheel came off and I got the sprocket and disc rotor off. Lastly, the chain guard and brake support assembly came off. I’ll get the chain off later, and then start cleaning up, before getting a big order in for all the rubbers. I’ll take the wheel in to work, where I should be able to dismantle it further, ready to get it powder coated.
    More boxes of bits
  7. Wheezy
    Wheezy New Member
  8. RogueRC24
    I used my air compressor with a spray nozzle attached to remove stuck pistons. I place a towel at the "exit" end of the caliper to catch the piston from shooting across the room. I leave in the bleed nipple and make sure the nozzle has a somewhat soft point on it so as not to damage the threads for the brake line bolt. Works really well. My compressor is set at 125 but I bet 50 might make it go.
    If you don't have a compressor try the local tyre shop. It takes all of 2 mins.
    Wheezy likes this.
  9. Terry Smith
    I think it is better to use the brake hydraulics to shift the pistons nearly all the way out first, and then finish off with air if you need to.
  10. RogueRC24
    ^^I thought his master was seized, but I would agree with your process.
    Wheezy likes this.
  11. Wheezy
    Wheezy New Member
    The pistons are siezed in the calliper and the master cylinder also seems siezed.
  12. squirrelman
    breaker's yard for replacements ?
    Wheezy likes this.
  13. RogueRC24
    ^^^Stop teasing us with 40yr old photos of awesomeness SM!!
    If you cannot get your rear caliper to work, I might have a spare that I can sell you for cheap. Let me know if I need to look for that stuff. :)
    Wheezy likes this.
  14. Colddevil
    Colddevil Member
    Wisconsin
    I'm not proud of this... but I have used a grease gun to push out seized pistons successfully before. It makes quite a bit of a mess to clean up. But it worked.
    If you've got a clean and operational front master mounted somewhere, you may also be able to attach the banjo to the rear temporarily to unstuck them.
    RogueRC24 likes this.
  15. sixdog
    Dude I use that method all the time …. It’s the best way I think
    Colddevil likes this.
  16. Colddevil
    Colddevil Member
    Wisconsin
    Alright, well then, let me revise my statement... I am proud to say that I've successfully used a grease gun to push out stuck pistons before! Got the picture hanging next to my diploma on the refrigerator.
    ... but, I'd still try to use a working master from another set of brakes first if it's available just to avoid the grease cleanup.
  17. sixdog
    At least you have a picture… what’s a diploma ?
  18. Colddevil
    Colddevil Member
    Wisconsin
    An expensive, ego-inflating piece of paper that's ultimately worth very little.
  19. sixdog
    Ha ha ha
    Sent from my iPad using Tapatalk
  20. Wheezy
    Wheezy New Member
    That would be awesome! I’m going to try to tackle my caliper over the next couple of days, but I’ll let you know if I give up!
