My RC24 resurrection
Discussion in '1st & 2nd Generation 1983-1989' started by Wheezy, Sep 24, 2021.
    It doesn't have to be 2 left or 2 right carbs. You can also accomplish this by removing the furthest out L & R carbs without having to remove the linkage arm from the 2 remaining center carbs.
    Sometimes it's nice not to mess with the tiny circlips or cotter pins.
    #61
    Wheezy likes this.
  2. RogueRC24
    ^^ +1
    Not sure if I missed it, insulator boots..Change em. :)
    #62
    Wheezy likes this.
  3. Wheezy
    Wheezy New Member
    A pretty rubbish day a work, so a bit of therapy by starting the process of cleaning up the outside of the carb bodies. Quite a nice way to switch off and to start getting my head around all the components. Still a long way to go.
    #63
    Thumbs and Captain 80s like this.
  4. RogueRC24
    so much better! Nice!
    #64
    Wheezy likes this.
  5. straycat
    smart move to get the outside as clean as possible before you crack them open
    #65
    Wheezy likes this.
  6. Wheezy
    Wheezy New Member
    That was @RogueRC24 top tip. Thanks for all your help everyone. Feeling a bit more confident about it.
    #66
    RogueRC24 likes this.
  7. Wheezy
    Wheezy New Member
    While I’m waiting for the parts to arrive from Joe at V4 dreams, I’m going to spend today trying to clean the chassis, sub-frames and components from the built up muck, that has accumulated over the years. I’m also going to start tackling the tank. I need to drain it today and I’m going to start trying to clear out the rust from inside. Depending on how bad it seems will determine whether I leave it at that, or send it off to be coated by a company.
    The tank has a ding in the top where it looks like something heavy has fallen on it. It doesn’t look big enough to have it pressed out from the inside. Would you guys recommend filling it and sanding smooth? It’s about 1.5” across. [​IMG]
    #67
  8. Thumbs
    Thumbs Member
    Bath(ish)
    The ding lost above the waist line of the tank so filling it should be OK
    Reverse electrolysis is the way to clean the inside
    #68
    Wheezy likes this.
  9. Wheezy
    Wheezy New Member
    Another two steps forward, one step back, kind of day.
    Started off by spending an hour or so wiping down the engine block, wiring looms and some of the easy to get components to wipe off some of the accumulated crud.
    I know it doesn’t look much, but it’s quite a bit cleaner around there.
    Drained the fuel tank. It still have 2 litres of fuel in there. Put in 6 litres of cola to start getting rid of some of the crud inside. I think I’m going to farm this out and get it done properly. I’d also like the ding removed from the tank. It’s not big, but it’s there.
    #69
  10. Wheezy
    Wheezy New Member
    Then went to an autofactors shop to buy some fuel hose. Of course I’ve bought the wrong diameter. Lesson learnt, so I’ve bought the right stuff from wemoto. Should be here in a couple of days.
    I’ve taken the fuel pump off ready to install new lines and a fuel filter. Hopefully will get that done next week.
    #70
  11. Thumbs
    Thumbs Member
    Bath(ish)
    While you have the carbs off it’s worth replacing the O rings on the cooling cross pipe and the 2 under the caps
    #71
    Wheezy likes this.
    100%. Another one of those "while you're there" things that you will never have to worry about again.
    #72
    Wheezy likes this.
  13. Wheezy
    Wheezy New Member
    I’ve had a quick look in the service manual and can’t see a reference to the o rings in there. Is there anywhere that has how to do this written down?
    #73
    #74
    Wheezy likes this.
  15. Wheezy
    Wheezy New Member
    Thank you!
    #75
  16. Wheezy
    Wheezy New Member
    So I can see you’re talking about part 15 for the cross tube O rings. The 2 under the caps, do you mean part 18 in the diagram?
    #76
  17. Wheezy
    Wheezy New Member
    Ok, think I have worked it out.
    So I’ve ordered 2 seals for the cross pipe and also ordered seals numbered 17 and 18. I take it that I have to remove the two caps so I have also ordered 2 replacement gaskets for them?
    That’s a brilliant website to have all the part numbers listed. Thanks for the heads up!
    #77
  18. Thumbs
    Thumbs Member
    Bath(ish)
    You need 2 x 16, 2 x 15, 1 x 17, 1 x 18, 1 x 19, 1 x 20
    You can purchase them individually now you know the sizes, except #15 ….Viton seals are pretty easy to get
    #78
    Wheezy likes this.
  19. Thumbs
    Thumbs Member
    Bath(ish)
    #79
    Wheezy likes this.
  20. Wheezy
    Wheezy New Member
    I’ve got to the point in this project where I seem to be spending a lot of cash, yet I haven’t actually fixed anything on the bike! Hopefully that will change over the next couple of weeks. Firstly, that pesky clutch slave piston and housing. A chap on FB has sold me an entire clutch lever, hose and cylinder for £35. Bargain. So I’ll take the working slave off and install with my already refurbed lever. The piston and seals on this unit look in great condition so I don’t need to overhaul it. That will be my main job, this weekend.
    I’ve just taken delivery of my carb refurb kit from V4dreams.
    If I’m not too tied up at work, I’ll make a start on that this week, with a view to completing next weekend. I’ve bought myself a set of JIS screwdrivers, in the hope it’ll make it a bit easier.
    Re. The petrol tank, I’m going to have a go at the electrolysis method of cleaning out the rust. I’ve bought some sodium carbonate crystals; just need to get my hands on a battery charger and I’ll set that up.
    I’ve got a new set of boots on order, and I should also receive the seals for the cooling system, so I can be doing that, while the carbs are being cleaned up.
    I’ve given myself the deadline to get the bike fired up at the end of my half term holiday, so June 5th. Fingers crossed.
    #80
