My two VFR750's
Discussion in '3rd & 4th Generation 1990-1997' started by john750, Jan 17, 2015.
  1. warewolf
    warewolf New Member
    New Zealand
    Nelson, New Zealand
    Mixture adjustment affects the revs for a given throttle opening. Changing one carb independently can affect the whole engine: indeed that's how you set the mixtures. Once the mixtures are correct, the carbs need to be balanced, which makes them all deliver the same charge at the same time. That means each cylinder is doing the same amount of work for a given throttle opening, which is most efficient, most responsive, and smoothest.
  2. ridervfr
    All the fuel mixture screws are set the same. Bottom out geny and count your turns, the manual states how many turns depending on year, state, country. CA bikes are different than Canada bikes. That wont affect you though.
  3. ridervfr
    Carburetor synchronization makes cunt hair throttle smoother, taking off from a start/idling at a light, carb sync makes these more pleasant. Once your past that small amount of throttle it doesnt matter as much. Fuel mixture screws involve mileage and how much gas the motor is getting. I could be wrong though ; )
  4. warewolf
    warewolf New Member
    New Zealand
    Nelson, New Zealand
    That's only the rough guide to get the bike to run when the carbs are assembled. From there it needs to be fine tuned. The service manual details the process.
  5. ridervfr
    Manaul is key to good relationship with your bike. Mine run so good you could rest a pint on the petrol tank and do the ton without spilling a drop! :loco: cheers
  6. john750
    john750 New Member
    I've updated the pics there, added clear indicators, Delkevic end can, shorty levers and some PR4's :D
  7. ridervfr
    Your the "Interceptor" king of the UK! :thumbsup:
  8. john750
    john750 New Member
    Why thankyou
    And today a double bubble screen along with changing the red seat cowl hump for a black one I have (with a bit of white piping that goes with the wheels!)
  9. john750
    john750 New Member
    Next up, going to carbon wrap the little air vent things in the side fairings and put a different mud guard/fender on (looking at options) Something like this
    Just need to do some measuring and get a bracket made up
  10. Iowa VFR
    Iowa VFR New Member
    Great work! I am enjoying this thread as I re do my 87
  11. john750
    john750 New Member
    I also may well get the bike fully resprayed with something special. Keep an eye out for that, won't be until April time though due to it being bloody expensive!
  12. john750
    john750 New Member
    Ok so this is how my red one is currently looking... Notice any difference!?
  13. john750
    john750 New Member
    Top one is with alternative mirrors
  14. ridervfr
    I got a skidmax on the white one and an mre on the black one, thanks for sharing, love my two too!!
  15. john750
    john750 New Member
    And after some serious polishing of all the nuts and bolts, I also added a tank pad and my Maxton reworked forks. I did a carb balance today as well, first time - only fiddly bit was getting the bloody brass adapters into place, but they're on permanently now so should be easier to balance them in future!
  16. ridervfr
    Looks Great!!! On my 93 I used the brass tubes like you described and cut some rubber hose equal lengths and screwed 4 bolts into the ends. This way, when you do the synchronizing drill, you simply get out your long needle noses and pull of the hoses and you got the brass spigots ready to accept your hoses for your carburetor balancer. My other bike, the 91 I have two brass spigots and two screws with washers sealing up the plenum. Actually, I don't really remember now, anyway...:loco: :hippie:
    I polished up my d-zus fasteners too, sad that the new bikes don't have as nice fastening systems or hardware of yester-year. Cheers, and happy/safe riding...
  17. ridervfr
    Oh, on my 93 I have those funky honda aqua-trax allen head bolts, they used to use them on the Dos-XX bikes, but these are stainless steal.
  18. V4 Matt
    V4 Matt New Member
    Huntington Beach, CA.
    How difficult was it to get the wrap on it?
  19. john750
    john750 New Member
    The wrap is always fiddly, the tank needs doing in two parts. The bike above is a spray job though!
  20. john750
    john750 New Member
    So...
    So, I bought the Sebring from Dutchy on VFRD and have had it fitted (I didn't want to do it myself, cost a bloody fortune but seems worth it). *I also got a Dynojet kit fitted, it's making 93bhp at the rear wheel now, which is enough for me and my riding style.
    I've GOT to buy a baffle for it, loud is an understatement - it's basically obscenely loud.
    I won't be doing anything else to the bike for a good while now, I've sank a pretty stupid amount into it over the past 6 months haha, the Mrs isn't going to be happy with me if I continue. *Next up will be a Hyperpro rear shock but may just save up slowly until Christmas and buy it as a pressie to myself then, the suspension as it stands is pretty decent with the Maxton front end.
    Here's some pics...
    And a video of the exhaust
    https://www.youtube.com/watch?v=4VPVJgQImKQ
    VERY loud
