Mystery box
Discussion in '6th Generation 2002-2013' started by whiteknuckles, Apr 1, 2017.
  1. whiteknuckles
    whiteknuckles New Member
    Beaverton, OR
    Anyone know what this black box is? I'm in the process of cleaning up the various wires that are attached to add on electronics. The box is in the compartment on the other side of the battery. It attaches to the same part of the harness that the kickstand safety switch attaches to. I've looked through the shop manual and can't find this in the wiring schematic or in the electrical connects chapter.
  2. Lint
    Lint Member
    Simi Valley, Ca.
    Alarm or GPS?
  3. Allyance
    Allyance Insider
    East Bay, California
    That looks like a "handy" box you would find at an electronics store, not stock. PO must done some custom wiring.
  4. GatorGreg
    GatorGreg Honda Fanboy/LitiGator
    Orlando
  5. whiteknuckles
    Beaverton, OR
    :bravo:Ba da bump! :drum:
  6. whiteknuckles
    Beaverton, OR
    Nope. I guess the question is, since it IS connected to the harness, any idea what's connected at the other end?
  7. whiteknuckles
    Beaverton, OR
    The only add on the p.o. did was heated grips, and I followed the circuit from rheostat, to heat troller, to grips. The box itself only has an output, no input wiring. SIGH
  8. GatorGreg
    Orlando
    I found the answer to the other mystery box question :witless:
  9. Allyance
    Allyance Insider
    Four connections to that junction, 2 O2 sensors (replaced by resistors), side stand switch and vehicle speed sensor which has been replaced, modified or eliminated?
  10. Badbilly
    Are we seeing a form of veiled complaint here?
  11. fink
    fink Member
    What colour are the wires on both sides of the mystery connector.
  12. Arnzinator
    Arnzinator New Member
    Central Massachusetts
    Possibly a LO-JACK vehicle recovery system.
  13. Allyance
    Allyance Insider
    According to the schematic, there are three wires at that connector: Brown/Blue +12V, Green Ground & Purple. Purple goes to dash for speedometer and to the ECM. It's there in the schematic, down at the bottom in the center. Speedsensor is a circle with 4 tabs on it.
    For the speedometer to work and for the ECM to get proper data, there has to more wires/connections unless it is some custom wireless speed sensor. More than likely, an aftermarket speedometer correction unit like HealTech.
  14. whiteknuckles
    Beaverton, OR
    Well, I put the fairings back on, but if my memory serves me (which at 54, is getting shaky) they're violet, green, and black.
  15. whiteknuckles
    Beaverton, OR
    That makes sense based on the three colored wires I can see, black, green, violet (faded purple, pinkish?). Although The bike still has it's speed sensor in place and I don't see a splice connecting the two. But away ways, thanks for your help.
  16. fink
    fink Member
    I am thinking speedo healer.
