Need Help setting Float Level. 2nd Gen VFR750
Discussion in '1st & 2nd Generation 1983-1989' started by slowbird, Feb 20, 2011.
  1. invisible cities
    invisible cities New Member
    new york
    Setting up/fabricating a gravity fed system is very straightforward. For reference Motion Pro makes an auxiliary tank.
    Motion Pro - Auxiliary Fuel Tank
  2. slowbird
    slowbird Member
    Toronto, Ontario.
    Ok....so i went out and got some hoses and a bucket thingy with a drain on the bottom....i set it up above the carbs hanging from the ceiling and hooked up the line.
    After checking everything I added some fuel and watched in dismay as a thousand tiny holes in the bucket started to leak fuel. When the bucket started to fill up the leaks got crazy worse and fuel started to pool under the carbs. (i don't know if it was from the leaky bucket or from the carbs)
    So after cleaning up and opening the one window in the basement, I hooked up a 2 ft hose to a tiny spout and slowly poured fuel in until it came out of the spout....then I stuck the hose above the carbs. (see attached pic)
    I don't know if I need to have a large body of fuel above the fuel line in order for the test to be valid but this is the best i can do.
  3. squirrelman
    Stop fretting, Matt, and install the carbs already. Your testing method is only partially valid cuz carbs are under 3psi pressure from fuel pump during operation.
  4. slowbird
    slowbird Member
    Toronto, Ontario.
    but the carbs leaked when the bike was just sitting....just resting on the side stand not running
  5. invisible cities
    new york
    If they are not leaking after you have bench tested them you are good to install.
    On a slightly different subject you mentioned in an earlier post that the new float needle has a different code. SM mentioned that this is okay though I would think they should all have the same code. Not calling SM out to the town square here but I would appreciate a bit more info this.
  6. slowbird
    slowbird Member
    Toronto, Ontario.
    I really hope it's ok....I'd hate to have to dish out more cash to replace all float assys.
  7. invisible cities
    new york
    For ref, here is the original post:
    http://vfrworld.com/forums/1st-2nd-generation-1983-1989/31865-goodbye-1st-gen-hello-2nd-gen-6.html#post303325
    I'd be interested to read a more detailed description of how this affects the float level. I would think for clarity you would want to have the same float needle & float seat and subsequently the same float setting.
    It seems overly complicated to have different float settings in the same set of carburetors, IMO.
  8. slowbird
    slowbird Member
    Toronto, Ontario.
    I just got back from Honda...spoke to my buddy that works in parts.
    The old part number for the float assemblies has been superseded. So Honda only supplies the one that I installed with the .2mm larger number
  9. invisible cities
    new york
    Thanks for the post.
    I would think that all the float needles/seats should be the same spec if you are setting all the floats to the same height.
    I am curious to see how the carb pros weigh in on this.
  10. slowbird
    slowbird Member
    Toronto, Ontario.
    I'd think (and hope) that the only difference is the inlet size. (2.6 vs the older 2.4) So there is a 0.2mm difference. So the fuel will flow ever so slightly more....but only when the float is all the way down and pulling the valve completely open.
    I didn't notice any difference in the valve and I can't see why Honda would change the float valve size making the float height spec set in Honda service manuals obsolete.
    My friend at the Honda Dealership think it won't be an issue....and I hope him and SM are correct.
  11. tinkerinWstuff
    I wouldn't sweat it either. In a perfect world, I'd change them all to be the same. All things considered, I think you'll be just fine.
    The main point is that the float levels are all set consistent so the float level will remain the same on all four carbs. One will just fill a little quicker.
    Looks like a good job on the leak test. You simulate the 3PSI from fuel pump by having the funnel/bucket several feet above the carb assembly. Regardless, you've shown that the floats are shutting off the needle/seat, the fuel rail o-rings are sealing, and the float bowls are sealing. Coupled with the fact you said it was leaking before just sitting.
    did you figure out where your original leak was coming from?
  12. tinkerinWstuff
    where the carbs ever vacuum balanced when you had them on last? How about rough balanced on the bench?
    After the dyno runs, cam change, and rejetting I recently did on my 3rd gen, she ran so rough at 1100 RPM that there was literally a knock that could be heard. Sounded like a bad rod bearing. After vacuum balancing, she runs smooth as can be without any knocks. No adjustment screw was off by more than a half turn. Little things make a huge difference with carbs.
  13. squirrelman
    Clarification: Original (1986) size is 2.6 and REPLACEMENTS are 2.4
    Set all the floats the same, and ride the bike. If any running problems, then do some plug cuts and inspect colours for consistency.
  14. invisible cities
    new york
    Thanks for the clarification. I'll be curious to hear if this size difference will require a different float setting. On this note, perhaps their was an FSB regarding this change?
  15. squirrelman
    i don't believe the very slight difference in fuel inflow would require any change from stock float height setting; however, if the needle is even slightly longer or shorter ( i think it may be) then that would have an effect on proper float height becuz, with a setting by the book, the fuel would be stopped sooner or stopped later by a non-stock length needle.
  16. tinkerinWstuff
    No it wouldn't squirrel
    closed is closed and it wouldn't matter the length of the needle. You are bending the tab on the float to account for that. The float level would remain the same and you could have needles different length by .100 if you wanted to. By setting the float level using the book method and tool, it wouldn't make a difference.
  17. squirrelman
    Most respectfully, i disagree.
    With a very long needle, for example, you'd need to adjust the float tab to close inlet later at a given float height. Does this make any sense ?
    Or, at a standard float setting, a longer needle would be closing off the inlet earlier, resulting in a lower than standard fuel level.
  18. tinkerinWstuff
    do I need to draw you a picture? It doesn't matter. trust me.
  19. invisible cities
    new york
    Tink, if you have your pencil and sketch pad handy I would appreciate a section detailing your take on this.
  20. tinkerinWstuff
    I am loading up the dual sport for an overnight ride and alcoholics-proud-of-it meeting in the Pawnee grassland. No time for drawing, scanning, uploading, posting right now. Draw yourself a picture and I'm sure you'll see what I mean.
    The float will always have the same buoyancy and the point of setting the float level is to control the level of the fuel in bowl. You want the flow into the bowl to be off at a specified level. So the float "level" is a known point in your drawing. When setting the float, you tweak the tab on the float so that the needle is shut off when the float reaches the known point in your drawing. If the needle were a different length, you'd adjust the tab one direction or the other. Point is, the "off" point for fuel flow will always be at the specified level regardless of the length of the needle. The tab on the float is your adjuster just like a turnbuckle is on a chain or cable system.
