Neutral light not working when hot
Discussion in 'Mechanics Garage' started by BrysonBman, Apr 19, 2011.
  1. BrysonBman
    BrysonBman New Member
    when my 2001 vfr gets hot the neutral light flickers and i can hear what sounds like a relay going on/off quickly. does any one know what it is. please help.
  2. pap11y
    pap11y New Member
    Sydney
    +1 I have this exact same symptom on my Gen 5.
    Anyone had any experience with this symptom?
  3. pap11y
    pap11y New Member
    Sydney
    Ok. There are more symptoms..
    When I got home today I could not get the neutral light to come on.
    I could put the bike into neutral and move it but no light.
    During this time I could not start the bike. Not with clutch in, stand up anything... There was a ticking sound (like a relay) near the gear selector.
    When riding I notice the neutral starts to flicker before it fails completely.
    After 15-30 mins neutral is working perfectly...
    Any ideas..?
  4. pap11y
    pap11y New Member
    Sydney
    FYI - I spoke to Honda..
    they have suggested the neutral light has an earth wire and the wire used is very thin. It is prone to degradation and they believe this is the cause of my issues.
    I am having them fix this (as I want this sorted - I don't want to be stranded on a long trip)
    Hope this helps anyone else with these symptoms...
  5. duB
    duB New Member
    Montreal, Canada
    Was your problem fixed?
    I have the same symptom. 5th gen/90000 kms. When engine hot (104 C) it starts to flicker. When I bend the bike to the right while in neutral, off the neutral light. Flick to the right, back on the neutral light. Switch is in the transmission I guess, hot oil affect it?
  6. pap11y
    pap11y New Member
    Sydney
    Honda replaced the neutral switch. I can't remember the price was 1.5-2 hrs labour plus part..
    I hope this helps you out.
    Mine was fine then just started misbehaving. Would only fail when hot so it does seem like a similar fault.
    I don't have the knowledge to answer your other questions..
  7. duB
    duB New Member
    Montreal, Canada
    Thanks, I just concluded this is the part I have to change and you confirm it. It's just above the oil level so it's easy to replace.
  8. Durk
    Durk New Member
    Pittsburgh, PA
    Appreciate the info in this thread, I'm having the same problem.
    Part # is 35600-KE8-003
  9. pap11y
    pap11y New Member
    Sydney
    Glad to hear that it helped you :)
  10. taylor65
    taylor65 New Member
    florence, al.
    I have a 98 gen 5 and have never noticed anything. Any idea of the cause? I know you said thin wire but where is that thin wire exactly? Thanks. That's all I need is more electrica problems
  11. motonut9000
    motonut9000 New Member
    Can someone tell me where this switch is located? I can't seem to put an eye on it.
  12. ZEN biker
    ZEN biker New Member
    Assiniboia, SK
    The neutral safety circuit is a pull to ground requirement. So any of 3 switches can be the issue and including ground (frame) connections.
    Im not sure of failure rates but there is a simple easy way to test if a switch is the problem. Simply shorting a switch to ground will make it look closed to the ecu. You can also use an ohm meter to test continuity of a disconnected switch. Some do fail in the closed position.
  13. ninja5
    ninja5 New Member
    Bulgaria
    Hello,
    I had the same problem. the reason for this was very simple too thick cooper washer :) on the switch on the gear box. I did replace it with 0.5 mm less thicker and I am back in business
    P.S.
    I know the tread is very old, just my 50 cents
  14. jpacman
    jpacman New Member
    Vermont
    Just 'cause it's an old thread doesn't mean it isn't still relevant. Shit happens.
    I replaced the neutral switch on my '00 with an OEM unit and I still don't have a neutral light on the dash. The switch functions properly (continuity tested) so I'm going to trace out the wire next. When it isn't so cold that I risk damaging the plastics by taking them off...
  15. Terry Smith
    If the neutral light is not working then I would start by checking the bulb, and the diode needs to be functional as well.
