new engine wont start
Discussion in 'Mechanics Garage' started by secretsix, Jan 15, 2010.
  1. squirrelman
    SORRY, who died ??
  2. secretsix
    secretsix New Member
    north wales
    i only changed the engine everything else is from the original bike apart from the crankshaft pickup camshaft pickup neutrall switch an the water temp montitor
  3. secretsix
    north wales
    i've managed to get a complete wiring loom and ecm for a good price an have decided to change the lot they all came off a working bike so in theory should work
    my brother an electrian an is going to test all the sensors on the engine before i fit it
  4. marks152
    marks152 New Member
    thats all good and well but unless you have the ignition barrel to match the ECM then it still wont spark, assuming your bike being a 2000 model it should have HISS on the ignition system, can you confirm this, if it has HISS it will say so on the ignition were you put the key in around the barrel, if its a pre-HISS model then that will be fine, just plug and play, hope its the later for your sake or you just wasted your money
  5. secretsix
    north wales
    no mines a 98 bike the engine is a 2000 the loom is off a 98 as is the ecm
  6. steven113
    steven113 New Member
    Pensacola FL
    What makes you think there is a problem with the harness that you curently have on the bike? Are you not getting power to the fuel pump at its connecter now?
  7. secretsix
    north wales
    not now also the sparks gone from plugs as well somethings not right so im thinking if i change the loom as well as the ecm it might sort it out
  8. TOE CUTTER
    I have parted one of these out and done some wiring repairs on gen 5 , they are a little on the busy side as far as wiring goes. I have this same thing happen to me from time to time and just in the last month as well, I was sure all was well but after banging my head against the wall had to back track and triple check wiring connections. Not just insure they were correct but hat the pins were undamaged and still locked in the plugs. Last one got me for a bit of time and it was a pin that slipped out of the plug when I connected it and only found it with a close visual inspection.
  9. secretsix
    north wales
    thanx for your input i'll do that today this is really driving me round the bend
  10. secretsix
    north wales
    does any body know where the engine stop sensor is its on both wiring diagramaes ive got but i cant find it anywhere
  11. TOE CUTTER
  12. secretsix
    north wales
    so your saying the engine stop sensor is the tilt switch
  13. TOE CUTTER
  14. TOE CUTTER
  15. secretsix
    north wales
    thats great info by the way mines a gen 5
  16. TOE CUTTER
    I think I knew that before I started reading and got gens , time of day, and which way was up kinda turned around.
  17. DGW
    DGW New Member
    Camarillo, Ca.
    This might be a long shot,but when I changed out my thermostate and put the throttle bodies and gas tank back on I somehow twisted the fue line and put a kink in it so no fuel got thru. It took a while for me to figure this out and the fuel pump made its noise and the bike turned over it just won't start. The kink wasn't noticed until I started to take the tank off agian.
  18. secretsix
    north wales
    no its not that ive checked thanx anyway
  19. dizzy
    dizzy New Member
    MN
    The engine stop relay is under the seat...connector colors are black/white, black/pink, black, and red/orange.
    Really, the easiest way to troubleshoot this might be to go directly to the ECM connector, unplug it. Find the black/white and solid green wires. When the key is turned on and the handlebar stop switch is in run, probe the connector carefully for VDC on those wires (positive to black/white, negative to solid green). If you have it, it verifies all the fuses, bank angle sensor, the engine stop relay, and all the associated wiring, and you can begin to look elsewhere (fuel pump, neutral or kickstand switch, etc.) If not, verify via continuity if the solid green is providing a ground to the ECM, and begin working your way back to the stop relay, etc. to see where you're losing power.
  20. secretsix
    north wales
    hi there i've done that test an im getting voltage as you said with the positive goning to the black an white wire but the fuel pump relays not kicking in , i've tried changing the relays but still no joy
    ps i pulled the plugs on the injectors today an what did i find water in three of them so thats water in the engine water in the fuel tank an now the injectors makes me think this bikes been for a swim
