new engine wont start
Discussion in 'Mechanics Garage' started by secretsix, Jan 15, 2010.
  1. secretsix
    secretsix New Member
    north wales
    iv've just tested the intake air temp sensor an im not getting any resistence or continutity will this stop it from starting ??
    #41
  2. secretsix
    north wales
    persisence paid off in the end
    at last i 've got it running the proleml was the socket arrowed in the picture the little flap inside the socket had broken off ,it was the black an white wire so none of the injectors would work when the plug was put together,
    i fixed it with a bit of silver foil shoved in the hole plugged it together an fired up
    ive got an old set of injectors somewhere il take the loom off them an change it
    thanx for all your help
      File size:
      111.1 KB
    #42
  3. steven113
    steven113 New Member
    Pensacola FL
    Congradulations! That was a tough one to find! Thanks for posting up the solution!
    #43
  4. TOE CUTTER
    Glad you got it fingered out!
    #44
