New Life for an Old 86 VFR700
Discussion in '1st & 2nd Generation 1983-1989' started by Dr.Инженер, May 17, 2019.
  1. Dr.Инженер
    Dr.Инженер New Member
    Tennessee
    V3.1 finished around 10pm... took a few minutes to install the new bed and presto we are back in business. Even still it didn’t print right, which is probably due to bed height problems and I’ll iron that out tonight.
    I tested the L bracket for force to fail and it broke with some force. It will hold up in use but not for someone with a heavy hand, I’ll have to put supports on the L.. so V4 coming next....
  2. Dr.Инженер
    Tennessee
    V3.1 Aslo gear shape mishap- probably bed leveling issues. I’ll check the cad program to make sure and reprint later today...
    tsmitty likes this.
  3. chuntera
    chuntera New Member
    Connecticut, USA
    Kudos to your effort but...
    doesn't motion pro sell a tool like this ?
  4. Waylander
    Waylander New Member
    Waltham Abbey, Essex, UK
    It’s not about being able to buy one, its the challenge of making one
    And if a success, sell a few
    I would buy one that’s for sure
    VF1000F2 a work in progress
  5. chuntera
    chuntera New Member
    Connecticut, USA
    You could 3D print some lower fairing stays, those are impossible to find.
  6. Dr.Инженер
    Tennessee
    V4-Finished, beside handle, but done none the less. there were 4 failed attempts. First one was due to measurement error on my part. The other 3 were trying to find the right print orientation on the bed. Cost of the finished print is $1.00 :), filament only, not including metal rod stock and handle. Total cost for filament including ALL 6 failed attempts is $6.
    The print only is 31mm Wide by 79mm Length, weight 16g. The entire tool is 210.5g and 381mm Length. Works fine with no effects from heat or BURNING MY HAND.
    It was a Fun little project.
  7. Dr.Инженер
    Tennessee
    This is it, final version to be placed in the tool box for use when needed.... printed a handle last night and epoxied it together...
  8. Waylander
    You should sell those !
    VF1000F2F, in bits
    Dr.Инженер likes this.
  9. Dr.Инженер
    Tennessee
    I would absolutely love to make a few bucks and sell them at a quarter of the price motion pro sells them..... But....making, using and testing only one isn't a big enough sample size to validate their fit for use for others. I would need someone one who works on these bikes often to use one multiple times over the next couple months and feed back any failures or needed design changes.
    But if anyone wants the 3Dprint file and the dimensions of the metal stock I used to make it, they are welcome to it.
  10. Waylander
    No much use to me, don’t have a 3D printer
    VF1000F2F, in bits
  11. squirrelman
    have you used it successfully ? :thumbs:
  12. Dr.Инженер
    Tennessee
    It doesn'lt look like ALL BALLS and BikeMaster has the busing kit, seals only. I can find them in HARDRIVE. Anyone has advise on other companies?
  13. Waylander
    Pyramid motorcycle parts, I got mine from them, bushes and seals
    Not used anything else to compare against, but the seemed good quality
    VF1000F2F, in bits
  14. Dr.Инженер
    Tennessee
    As in did it melt into a pile of failed plastic in-between the cylinders or did is successfully adjust the screws as intended without burning the flesh off my hand? Yup it adjusted the screws as intended without burning the flesh off my hand. So success!
    Terry Smith likes this.
  15. Dr.Инженер
    Tennessee
    Need new hoses that connect both the vent and fuel tubes. All these brick stores carry is the thick wall tubes. Where can i get something a little thinner. Or is the only option the thick wall?
  16. Diving Pete
    Thick wall is reinforced for HP fuel lines - you don't need that lol....
  17. Dr.Инженер
    Tennessee
    agreed, where can i find thin wall?
  18. Waylander
    Search on eBay for thin wall Neoprene fuel hose
    Like this
    https://www.ebay.co.uk/itm/303530380710
    Not as thick as the original pipes, and very flexible, so mind out for kinks
    VF1000F2F, in bits
  19. Diving Pete
    You can get this but you will have to look about. As you have noticed the normal shops will only do car braided hose lines as they are all running HP fuel rails so need them.
    Im positive that your honda dealer can get it - with the part number - but its not cheap.. lol
  20. Dr.Инженер
    Tennessee
    Thanks....i found some on USPLASTIC.COM
