New (to me) 91 in need of serious help
Discussion in 'Mechanics Garage' started by rogersj3, Apr 30, 2010.
  1. donald branscom
    donald branscom New Member
    Guerneville CA
    Roger,
    There is a big difference between someone that can ride, and a mechanic.
    Just like some people can play the guitar very well, but are lousy guitar teachers.
    I am sure the folks at the garage know that until a diagnosis is made, the amount of time for the repair is unknown.
    #81
  2. Badbilly
    Johnny B. Good
    #82
  3. donald branscom
    Guerneville CA
    It is funny that you mention Johnny B Good because i am studying and practicing that song this week!
    Many people that teach that song on the internet fail to mention some very important info about that song.
    http://www.youtube.com/watch?v=AEq62iQo0eU
    #83
  4. Badbilly
    There's a film out where Chuck is telling Keith Richard he ain't playing his music right.. Keith is very patient.
    Once in awhile Chuck would cut loose on guitar and was a monster.
    I was always better at ringing bells than guitar..;)
    #84
  5. tinkerinWstuff
    #85
  6. crustyrider
    crustyrider New Member
    North Country, New York
    If your itching to get the bike done, look into aengine out of a wrecked one....might get you up and running. Then take your time with the rebuild...
    #86
  7. tinkerinWstuff
    If money is any factor at all then you're probably best off putting that old motor on the shelf and taking crusty's suggestion. I have a 3rd gen motor on the shelf right now waiting for me to come across the right crankshaft and other parts to fall in my lap. A "proper" engine rebuild will run you a minimum of $700 in parts (bearings, rings, gaskets, seals, etc.). You can find solid running motors for $400.
    I've been over this road. As much as it'll piss Donald off - throw another motor in the bitch and get on with riding. You can take your time later rebuilding your spare motor if it gets your rocks off.
    #87
  8. tinkerinWstuff
    Your clue that Donald has not tore one of these down.
    #88
  9. tinkerinWstuff
    Bad idea. Has little to do with the Cc's of the motor and most everything to do with the tank, carburator, and fuel line orientation.
    #89
  10. tinkerinWstuff
    This is an all aluminum frame (except the tail) without any paint.
    The start switch only runs the starter relay. Operation is similar to a starter solonoid in a car. Resistance is futile - or has nothing to do with the switch with this particular case.
    All this talk about tearing motors down and glued piston rings is a bit premature. The engine moves as shown in the youtube video so this just isn't the case. When using car battery and jumper cables, where was the negative cable connected to? Has the integrity of the ground wire been verified as mentioned earlier? Could you have purchased another weak starter motor?
    Get the spark plugs pulled, pull the timing cover off the side, turn it over by hand, and stop all this speculation.
    #90
  11. Badbilly
    It's about time somebody pointed out that aluminum is not a conductor.
    #91
  12. tinkerinWstuff
    Not what I'm saying - considering the engine itself is aluminum.
    As a matter of fact (in best Donald voice) even concrete conducts electricity and can conduct enough electricity to kill a person (50ma passing through the heart). That's why all the pads where you fuel up your vehicle are concrete - to conduct electricity and help prevent static buildup.
    Though aluminum itself is an excellent conductor, its oxides are not. Where aluminum oxidizes (connections between motor and frame), connections and conductivity become very poor, causing overheating and power loss.
    Your post on the horse race back on page 2 or some shit cracked me up Billy.
    #92
  13. Badbilly
    Yep. Those rubber engine mounts are crappy conductors too. I'm really glad those pads where I get gas are concrete too. Asphalt wouldn't be good at all. Dirt might be good. The worst would be Teflon.
    IMO what we can perhaps say is that the guy with the funny voice is up and running and others are not, technical skills aside.
    There's always shit at horse tracks.. Some is the real thing and some is BS from the tout sheet.
    #93
  14. donald branscom
    Guerneville CA
    Aluminum will conduct electricity like most metals but it is not very good.
    There was a time when they wired houses with aluminum wires but many houses burned down when the wires got hot from trying to conduct through corrosion or the wire broke off from being bent at the back of the box and work hardened.
    They had to rewire many houses. Cost millions.
    By the way - never buy a distributor cap made with aluminum contacts.
    They get that white aluminum chloride powder (corrosion) inside and will not work very well. Aluminum cap contacts and copper plug wires next to each other=high corrosion potential),Always buy and insist on copper contacts.
    Some day all the houses will reclaim copper wire from houses and sell it.
    If you see that white powder on your aluminum engine, spray it with WD40.
    And you will see it (corrosion) on alternator cases on cars too.
    Aluminum case ,copper windings bad combo. Better to have a steel case and copper windings like it used to be.
    If you have a ground going to your motorcycle engine put the copper fitting on a steel bolt and a plastic washer between the aluminum engine and the copper fitting.
    You should have a ground going from battery ground to engine, and a ground from battery ground to motorcycle frame for safety.
    #94
  15. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    Found this on the all knowing internet,
    Copper-Versus-Aluminum Conductors
    On another note, my first house was wired with aluminum wire and I tell ya, you ain't see anybody so happy to sell a house as I was when she finally closed.
    And just to keep the ball rolling on this thread, I believe that when we pick through the wisdom offered so far, and if I may be so bold as to offer a summary, you need to determine if the engine cranking issue is due to internal engine friction from corroded engine internals or inadequate cranking torque caused by a shitty starter or other electrical issues.
    Pull the plugs and inspect the cylinder walls. If the walls are visibly corroded, full stop and start planning the overhaul or engine replacement. It sounds like this engine was exposed to some elements which have caused severe corrosion as evidenced by the seized carbs. If the cylinders look ok, squirt some oil in there and turn it over a bunch of times by hand. It should turn over easy with the plugs out. If it is still tough to turn over by hand you have something else causing trouble inside. Pull the cam covers and the clutch cover to see if you can find to problem without a full tear down. I wouldn't be surprised if the clutch was dragging a whole bunch. After this you will need to open her right up.
    Anyway, keep digging and let us know what you see.
    Hang in there!
    #95
  16. rogersj3
    rogersj3 New Member
    Cincinnati, Ohio, United States
    Gentlemen, we have signs of life. Removed plugs, added Mystery Oil, rocked in 5th, cranked it manually - still seemed a little hard. Thought, "Meh, why not" and pressed the starter button. I'm now covered in mystery oil and couldn't care less. Will report back once things are assembled again.
    EDIT: decided that there was no need to rush and that it would be best to let the oil sit for a few days anyway. Still stoked!
    #96
  17. donald branscom
    Guerneville CA
    The Rogers mystery!!! SOLVED!!! LOL...LOL...
    Aren't you glad you stuck with it?
    The #2 post on this thread by adamjenkins, Mystery oil first because it sat for 5 YEARS!!
    #97
  18. rogersj3
    rogersj3 New Member
    Okay, well now I'm sad. Screwed the spark plugs back in and the bike returned to its traditional acts-like-it-has-a-dead-battery really-hard-to-crank-over form. So, now what? Am I stuck doing the engine rebuild now?
    #98
  19. tinkerinWstuff
    No. You have a problem with either the starter itself, the battery, or the main battery cables. Something isn't able to handle the load.
    #99
  20. rogersj3
    rogersj3 New Member
    Tink, I'm at a loss. Unless the magical eBay starter is bad (not out of the question)...
    Here's the deal, I just tried activating the starter from an external battery with jumper cables. The battery in my running Ford Ranger was connected to jump leads (both terminals) and the negative terminal clamped to the bikes frame just aft of the fuel tank where there is a little vent (bare aluminium here). I momentarily touched the positive lead directly to the starter's post (I had previously removed the starter wire from the motor) and all I got was some sparking. No cranking action occurred. What are the possibilities based on this information? Another bad starter?
