New to VFR world and new VFR owner
Discussion in 'General VFR Discussions' started by nejimmy, Aug 13, 2011.
  1. Metallican525
    Metallican525 New Member
    Rockville, Maryland
    Being as how the inside of the tanks are not sealed to begin with I would say not necessarily. Depending on how good of a job the chemical he used to remove the rust does, he may be ok just keeping fresh fuel in her and gettin down the road. I would say that sealing the inside of the tank is a great preventative measure as long as you use the good/correct kit. There are newer kits out now that are resistant to ethanol which is now at 10% nearly everywhere in all gasoline. Older kits/chemical sealers were not designed with this in mind and can/probably will melt off the inside of the tank and clog EVERYTHING.
